RTT mattress replacement
Discussion in 'Off-Topic Discussion' started by Little Lion, Feb 10, 2020.
  1. Feb 10, 2020 at 10:46 AM
    Little Lion
    Little Lion [OP] Well-Known Member
    2018 Barcelonian Sport MT
    Hi friends.
    My 5 year old Tepui foam mattress expired. Mould, tears, depression, it was time to go.
    I am considering replacing it with a 3” mattress from a local supplier here on Vancouver island. For $290(CAD),
    it’s half an inch thicker than the luxury mattress offered by Tepui. ($319 CAD)
    Also considering air mattress from MEC reactor 10, $299(CAD)
    anyone ever put a 3 inch mattress in their roof top tent?
    I camp in cold weather sometimes too, so wondering if air might be superior in that way.
    thoughts?
    thanks!
  2. Feb 10, 2020 at 10:55 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
  3. Feb 10, 2020 at 10:57 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Me to I haven't used my new Smittybilt XL RTT but putting a better mattress in right away for my 51 year old screwed back.
    Little Lion[OP] and zippsub9 like this.
  4. Feb 10, 2020 at 10:58 AM
    eon_blue
    Azusa, CA
    Air mattress would definitely help to reduce the weight of the tent over the back of the truck which would be nice...those thick foam mattresses are heavy AF.
  5. Feb 10, 2020 at 11:45 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    One would think with all the air down and up onboard air options that air would be the way to go. I just hate the way it transfers movement on air mattress. It is myself, dog, son and wife. My wife rolls out a supplemental pad on her side, but we have never tried closing it up in the tent yet.
    Little Lion[OP] likes this.
  6. Feb 10, 2020 at 11:50 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Wonder how a memory foam mattress would be
  7. Feb 10, 2020 at 11:56 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    sounds magical....you know you’re old when you get excited about mattresses!
    MY50cal and Little Lion[OP] like this.
  8. Feb 10, 2020 at 12:00 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Damn Skippy
  9. Feb 10, 2020 at 12:04 PM
    DrFunker
    DrFunker Well-Known Member
  10. Feb 10, 2020 at 12:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  11. Feb 10, 2020 at 3:32 PM
    Little Lion
    DrFunker[QUOTED] likes this.
  12. Feb 10, 2020 at 3:36 PM
    Little Lion
    What would you suggest zippsub9? What made you change from the foam?
    Thanks
  13. Feb 10, 2020 at 3:38 PM
    Little Lion
    Great point! Didn’t think about that.
    Thank you
  14. Feb 10, 2020 at 3:45 PM
    DrFunker
    Would love to be able to do it.
    From the reviews I have read in other places, it is a really great pad.
    That price hasn't really moved much in years. That tells you something.
    I have a double Klymit now, which has been working out pretty well.
  15. Feb 10, 2020 at 3:59 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I’m here to learn. I am still on stock setup with my FSR High Country. I don’t think air would work for me but what a great vapor barrier for the cold. I built a diesel heater to pump in warmth and it sweats me out. The combustion chamber that the air runs over gets up to 155 C.
    I think I may look for a larger version of my wife’s setup. I think it is called a Serta rollout foam. Let me dig and find it. I would use it augment and not replace.
    here is what she got:
    https://www.amazon.com/Simmons-Beau...+rollup+guest+bed&qid=1581379334&sr=8-1-spell
  16. Feb 10, 2020 at 7:07 PM
    Little Lion
    Very humble “here to learn” ;) sounds like you’ve got a good system for you now though. What temp do you usually start using your heater at?
  17. Feb 10, 2020 at 9:50 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    In order to keep camping a “family” event I usually turn it on when temps go below 50 F. We don’t use sleeping bags. I used to sleep on a heated mattress pad with a heating blanket on top. This is awesome but requires a generator to keep up. I run a 1000w Honda out with a 100ft cord for that. I since switched over to solar and run the diesel heater instead now. We just use blankets still. I am south of the maple curtain and don’t suffer at all in the winter. My wife’s idea of camping is more Hilton and Hyatt than National Park.
  18. Feb 10, 2020 at 11:13 PM
    Little Lion
    That’s fantastic, happy wife happy life. Sounds like you play it safe :bananadead: Let us know if you end up getting that larger version of the foam !!
    zippsub9[QUOTED] likes this.
  19. Feb 11, 2020 at 6:24 AM
    billum v2.0
    billum v2.0 Well-Known Member
    Flyover Country
    '01 SR5 TRD Off Road Extra-cab
    Bone Stock
    Have been through several different RTT mattress/pad combinations.
    Tepui Kukenam RTT. OEM mattress was never a good fit for my back. Being a side sleeper, ended up with sore shoulders/hips after a couple nights. 1" memory foam topper over original mattress helped, but not enough. 2 1/2" MF topper over original mattress was better, but getting tent compressed enough to get travel cover on became a problem and the MF doesn't breathe, so sweaty nights if above 40° as well as stiff/hard below 30°.
    Removed OEM mattress and went with two ExPed Megamats (not the self inflating versions) so we could each set firmness and move around independently without transferring to the other's. Found ExPed's much more comfortable for both of us (she's back sleeper, likes softer mattress). But, the aluminum diamond plate floor in the Tepui transferred cold to the air mattresses much more than the OEM foam mattress and the tent compressed too much without some type of foam mattress inside. Futzed around with different solutions (different thickness MF toppers on the floor with ExPed's on top, etc, no mattress but stuffed closed tent with clothes/bedding to fill in dead space, etc.).
    Our best solution was a new Tepui standard mattress combined with the ExPed's on top. Nearing 60 total nights with this combination and although not as comfortable as our home bed, it is better than any hotel bed I've ever slept on and leaps/bounds better than original mattress or ExPed's alone. We do flip/spin mattress every few trips, although likely not needed with ExPed's providing support.
    In talking to other RTT folks in our search to find the perfect solution, became clear that it's a personal thing and their solutions weren't ours and vice-versa.
    zippsub9 likes this.
  20. Feb 11, 2020 at 6:55 AM
    Little Lion
    Thank you for the in depth description!
    Are you able to keep the ExPed’s deflated in the RTT when folded up? How is the inflating / deflating process?
    Is the Tepui mattress mainly there for thermal insulation - or does having foam under an air mattress somehow make things more comfortable?
    thanks again billum!
