Rub after off road bumper install
Discussion in '1st Gen. Tacomas (1995-2004)' started by chazjb, Mar 20, 2011.
  1. Mar 20, 2011 at 11:00 AM
    chazjb
    chazjb [OP] Well-Known Member
    James
    Oregon
    2015 DCSB Sport
    Hey guys so here is my problem. Yesterday I installed my elite plate bumper with an xrc8 which added ~150lbs minus the crap I took off. But now I have rubbing on the rear of the front fenderwell because the front dropped down from weight. I have a toytec 3" spacer in front and just wondering what your guy's thoughts would be on how to lift it back to 3". Coilovers? New shocks same spring? I'm kinda on a budget so I don't have a grand to spend but could spend around $500
    Thanks in advance for your imput... Oh and its a 97 ex cab 3.4l if it matters.
  2. Mar 20, 2011 at 11:17 AM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    a spacer?? :puke: but the best front and rear lift kit for the money is OME or eibach springs with 5100's both are 3" suspension lifts
  3. Mar 20, 2011 at 11:21 AM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    886's, Same thing happened with me.
  4. Mar 20, 2011 at 2:09 PM
    chazjb
    James
    Oregon
    2015 DCSB Sport
    Cant seem to find the OME 886 for my 97. Also what shocks are being run in these or in the eibach's? I did find that the 884, and 885 all have the spacer kit you can add on to them... will this give me a taller stance or will new shock accomplish this also? I want to still have three inch lift with bumper and winch. One more question... will adding these different springs rub on my 33/12.5 toyo M/T's causing me to have to get new UCA's also?
  5. Mar 20, 2011 at 3:40 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    OME's are not made to fit the Billies but some have done it, the eibachs were made for them, and i believe on the 1st gens w/ the added weight they need to be set at 1.5 w/ the eibachs and it should be around 3".
    The OME 886 are teh heave duty coils for added weight but will go along better with OME shocks, and the top plate spacer can be added to achieve the full 3" but not sure if thats with the 886's or 884's.
    I have the 5100's and eibachs at 0" and gained 3 1/4" of lift w/ no bumper and i paid right at 325 shipped for the billies and coils.
  6. Mar 20, 2011 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OME heavy springs for the first gens are the 882's..
  7. Mar 20, 2011 at 3:54 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    This^^^ Listen to him for OME stuff, idk anythign bout it.:eek:
  8. Mar 20, 2011 at 8:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id say 5100s and eibachs
    or OME...whatever :p haha
  9. Mar 20, 2011 at 8:43 PM
    chazjb
    James
    Oregon
    2015 DCSB Sport
    Ok thanks for your thoughts. any problems with tire rub on the spring itself with either of the OME or eibach's?
  10. Mar 20, 2011 at 9:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Simply replacing coils and shocks will not move the inside surface of your tire closer to the coil spring or UCA.
  11. Mar 21, 2011 at 1:33 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    i'm running my billy 5100's at 0 with the OME 882's and you def. get the 3" of lift with your bumper on.
  12. Mar 21, 2011 at 1:39 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I'm running 5100's and Eibachs set a 0 and got over 3" of lift my Elite bumper is not done yet :( so I can't tell you if you would rub but I do know the 620lb spring rate of the Eibachs should hold up your truck no problem.
    Now :worthless:
  13. Mar 21, 2011 at 3:08 PM
    chazjb
    James
    Oregon
    2015 DCSB Sport
    Ill take some this weekend and post em...
    After talking with a few different places I think im gunna go with the 5100's with the spacer I already have for now and maybe later on get some new springs.
    I really need a new job all I do is sit on TW and look a others posts then buy more stuff to do to my truck...
  14. Mar 21, 2011 at 3:09 PM
    chazjb
    James
    Oregon
    2015 DCSB Sport
    I didnt think so but some websites say that you can only run 265's with some of their kits... not sure why my only thought was tire rub.
  15. Mar 21, 2011 at 3:25 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    x2 on eibachs, really good set-up.
  16. Mar 21, 2011 at 11:27 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
