Rubber plugs for gaps in bed rail available now
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HCTacoGuy, Mar 9, 2016.
  1. Mar 11, 2016 at 12:47 PM
    KS Taco
    KS Taco New Member
    So I'm guessing they didn't need to cut my rails this far back when installing the factory cover?!?
  2. Mar 11, 2016 at 1:10 PM
    nismoz33
    nismoz33 Well-Known Member
    Nick
    Cincinnati
    2017 Quicksand Tacoma TRD Off Road DCSB
    Can I get a zoomed out picture so I know where these plugs go? I'm guessing this is only needed for factory covers?
    Sulley16 likes this.
  3. Mar 11, 2016 at 1:29 PM
    KS Taco
    KS Taco New Member
    Does this help?
  4. Mar 11, 2016 at 1:33 PM
    ksdindy
    ksdindy Well-Known Member
    2016 Tacoma TRD
    So these plugs are specific for these holes?
  5. Mar 12, 2016 at 11:48 AM
    HCTacoGuy
    HCTacoGuy [OP] Well-Known Member
    Homer City PA
    2025 Tacoma TRD Sport 4x4 Black
    Ready Lift SST 2.5 lift Method Black 703 17 x 8.5 +35
    Here is a picture of the plugs and of the space they are to fill. I don't have a star socket to get the rail off so I will get one tonight and let all know how it goes. I am a little skeptical at this point. There is a plastic plug in the end of each rail. It looks like when it gets slid out the plugs will push into the end of the rails but I am not sure of the fit just yet. I may have to trim s bit off the plugs to get a image.jpg image.jpg image.jpg good fit but won't know till I get the rail off.
    mr2r6 likes this.
  6. Mar 13, 2016 at 12:49 PM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    20160307_112733.jpg thats what i did
  7. Mar 13, 2016 at 6:24 PM
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    SMART! Yep, I laughed out loud and nearly spit on my screen when I saw $59. Beyond ridiculous.
    The gasket material is a great idea or maybe some black foam pipe insulation from Lowe's would work great, too, and you'd save enough to fill your tank up 2+ times.
    I don't mind paying a little extra for nice stuff for my truck but $59 for little rubber gaskets is insulting.
    I sold my factory tonneau and these stayed with the cover. Too bad Toyota didn't just include them with every truck sold.
    Motorshooter and CusterFan like this.
  8. Mar 14, 2016 at 12:59 PM
    HCTacoGuy
    Homer City PA
    Better yet if they made the rail an inch longer the gaps wouldn't be there.
  9. Mar 14, 2016 at 2:34 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    About the only thing I don't understand, is why the front rail higher than the side rails? That makes any cover not sit flush since the front bed rail is higher.
  10. Mar 14, 2016 at 10:03 PM
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    ** See follow-up below. **
    I got the plugs (62541-04010 and 62542-04010) and installed them tonight. Here’s a quick write-up if anyone is interested... hopefully this helps some folks decide which route to take. I have a canopy and water would literally run through the front gaps when it rained (driving or not), and I’m hoping to seal things up as much as possible. I went ahead and spent the $59 on these since I didn’t want to half-ass a bunch of sealant or calking all over the place (not hatin’ for those of you who went that route).
    1: Take off the front rail by unscrewing the T30 torx bolts.
    2: Figure out which plug is for which side (looking at these pictures will help). Once you figure that out, set the plug like so:
    This will give you an idea of how much you might need to cut and trim from the bed rail. My truck did not come with any bed covers, so my bed rails were not pre-cut.
    3: I used some painter’s tape to mask an outline of where I needed to trim.
    4: Pop off the entire bed rail. Simply pop out the rail by pulling up starting in the front and proceed towards the rear. The rail is held on by clips.
    5: Pull out your trusty Dremel. I used a Tungsten Carbide Cutter (9902)... It basically saws through anything. Get one if you don’t one one!
    6: Dremel away. I took my time and didn’t saw all the way to the painter’s tape so I didn’t trim too much off.
    7: After I got the first big chunk sawed out, I would do a test fit by placing the bed rail back on (only the front couple of clips needed to be clipped back in) and placed the plug next to the rail to see how much more needed to be trimmed. Repeat until perfect.
    8: Once enough of the bed rail was trimmed, I cleaned up the edges with a file.
    9: I could see there was a very small gap that water may or may not be able to seep through, so just in case I squeezed in some marine sealant (easy to take off down the road if needed).
    10: Put the plug in place. Tuck the plug under the lip of the bed rail.
    11: If all fits well, slap the bed rail back on.
    12: Reinstall the front rail.
    Here’s a picture with the canopy back on. Passenger side between the canopy (left) and cab (right).
    It’s a little ridiculous that there’s a gap in the first place, but I’m hoping this seals things up. We’ll see after a good rain... I’ll keep you posted.
    :cheers:
    FOLLOW-UP: Apparently the plugs by themselves did NOT stop water from coming into the bed. Last night I added some marine silicone sealant around the plugs and surrounding areas. We'll see if that helps after it rains. Kind of a bummer. I'll update when relevant.
    TacoPandaTRD, mrh2727, Wadar and 31 others like this.
  11. Mar 14, 2016 at 10:11 PM
    stan23
    stan
    Santa Clara, CA
    Awesome writeup!
  12. Mar 15, 2016 at 10:49 AM
    HCTacoGuy
    Homer City PA
    Job well done Adamr. I will not be modifying my truck in this manner. I contacted Extang and they are sending me the patches they have. If anyone is interested in the two plugs I have let me know.
    Wallbright and CusterFan like this.
  13. Mar 15, 2016 at 1:09 PM
    HCTacoGuy
    Homer City PA
    If you want to buy the set I have let me know. 59 for both and I will ship them for free.
  14. Mar 15, 2016 at 2:15 PM
    HCTacoGuy
    Homer City PA
    Ok 0210. Good luck
  15. Mar 16, 2016 at 8:44 AM
    #35
    nwAdamR
    Adam
    SW PDX
    Follow-up: Apparently the plugs by themselves did NOT stop water from coming into the bed. Last night I added some marine silicone sealant around the plugs and surrounding areas. We'll see if that helps after it rains. Kind of a bummer. I'll update when relevant.
  16. Mar 16, 2016 at 9:15 AM
    #36
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    Mine came with these already installed. Did toyota send out trucks with the cover and these not in place?
  17. Mar 16, 2016 at 10:23 AM
    #37
    HCTacoGuy
    Homer City PA
    This thread is for plugging the gaps when adding an aftermarket cover. I believe that all factory installed covers come with the plugs from the factory.
  18. Mar 16, 2016 at 10:24 AM
    #38
    16TacomaSport
    Jon
    Pittsburgh PA
    oh. I thought I read it was for the factory cover.
  19. Mar 16, 2016 at 10:24 AM
    #39
    HCTacoGuy
    Homer City PA
    Sorry to hear that AdamR.
  20. Nov 11, 2016 at 6:50 AM
    #40
    Shaun310
    Shaun310 Member
    Shaun
    2017 DCLB TRD OR
    I have a set of plugs if anyone wants to buy them. Purchased them from Toyota and then decided I didn't want to bother with them. $60 Shipped.
