Rubbing issues...where and how to cut/chop...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SAIRS, Apr 11, 2012.
  1. Apr 11, 2012 at 10:21 PM
    SAIRS
    SAIRS [OP] Well-Known Member
    Kelly
    Utah
    Super White 2012 Double Cab LB TRD SPORT
    Icon Extended Travel Stage 1, Total Chaos UCA's, Dakkar leaf pack, Beefed DCLB Sliders with extended kickout and custom BSP, Beefed Custom exo-rear tube bumper, Toyota bed mat, tailgate theft mod. Front mudflaps removed, Access LE soft tonneau cover, Weathertech digital floor mat, Weathertech window deflectors, Weathertech license plate frames. future plans = diamond plate tailgate mod, Venture Shield, TRD supercharger...the dream goes on and on....
    So I have my Icon lift, TC UCA's, XD monsters, and 285 / 65 /18 Nitto Trail Grapplers installed on my 2012 Tacoma. I need to bump up the drivers side to offset the Taco Lean. I am getting some rubbing. It is actually hitting the fender corner closest to the passenger door.
    I've tried searching, but I am not coming up with the right threads to help me determine how and where to cut. Anyone have any pointers or threads to suggest?
  2. Apr 11, 2012 at 10:25 PM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Im running toytec 3" with 285/70/17 and only spot i rubbed was mudflaps...took em off and no more rub at all....factory tundra wheels and 1.25" spacers as well....maybe crank your front up a little more??
  3. Apr 11, 2012 at 10:29 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Look for rub marks, cut.
  4. Apr 11, 2012 at 10:30 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Make sure to have it aligned and ask them to push the caster as far forward as possible while keeping camber at 0*.
  5. Apr 12, 2012 at 5:26 AM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    Cranking the ride height up wont stop rubbing when the suspension cycles, assuming it will...:rolleyes:
    ^^This^^ Dont be scared.
