Ruby Thunder-the 89 red 4runner v6
Discussion in '4Runner Builds' started by MurphyZ, Apr 20, 2010.
  1. Apr 27, 2010 at 6:22 AM
    MurphyZ
    MurphyZ [OP] Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    yeah when i get back i will have 2 or 3 weeks of R and R so i will order all the parts i need while over in the desert, help me with this list if you know of stuff i need.
    do you think it will be easier to just pull the motor and do all the work on an engine stand?
    i dont have a stand or cherry picker so i would have to buy one. i really want to mill the heads to accept a MLS gasket to make it bullet proof except i would have to then flush all the coolant and replace with some high dollar non-acidic type and replace and flush every 2 years max.
    timing chains
    port and polish
    mill heads to accept MLS gaskets if possible (do you mill both the block and the head? or just the heads) to get them flat. the tolerances are half of the gasket that comes on the 3.0l
    cams
    possibly rings(but i think the lower half is fine)
    hoses ill just by when i get back.
    headers from LCE (seem to be the best for heat xfer)
    what should i do about the sensors? replace them?
    also mandy will let me buy a 22re or 22r for a rebuild motor to play with while i wheel with the v6. then ill switch them and fix the v6 up something fierce.
    otherwise i would give it to you and just let you have it til it was done. just pay for the parts and your beer and wait. but the wife will let me buy more tools if i do it myself but it will take longer. so its a trade off
  2. Apr 27, 2010 at 8:58 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    sand castles hopefully if not ill be there
  3. Apr 27, 2010 at 10:10 AM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    Def. replace the timng belt.
    port & polish is not required, carbon removal is.
    Good idea to have the heads milled, hopefully you cann leave the block alone
    Cams should not need to be replaced unless you are just looking for more performance
    Anything that is rubber, like belts, hoses & seals I would recomend replacing
    The LCE headers are the best performance mod you can do to a 3.0
    If the sensors are working them leave them alone
  4. Apr 27, 2010 at 12:10 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    cool all the sensors are working right now.the engine light is on for the ecu not recieving a signal during cranking but that was not a hinderance.
    rob will you check the u pull it yards down there for a 22re with ecu and harness. i want one to build up and no one around us has one. or even a yunkyard. the ones i have called said i would need to come down and look.:( i think that was crap they know if they have them because they are worth big dollars.
  5. Apr 27, 2010 at 12:19 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Make sure if you re-do the v6 take it to a good machine shop. The heads have valve pucks on them that the cam rides over. Not just any hack can do that engine/heads. I had to take the guy the cams and all so he could adjust the valves. Then there were burnt exhaust valves he had to replace. The 3.0 isn't a cheap engine to work on.
  6. Apr 27, 2010 at 12:19 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    seeing all yall get these old 4runners really makes me want one! maybe in a year or so when My truck is paid off :cool:
  7. Apr 27, 2010 at 12:24 PM
    desertdude59
    I'd like to have one too just because the kids are getting older and growing
  8. Apr 27, 2010 at 12:26 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    mine has an exhaust valve sticking i believe. so i need to work on it but it will come out of the truck and be done on a stand. i have already worked on the plugs and it took me 3 hours to just get the plugs out because of #5 f the passenger side. so for the timing and heads ill just take my time. this is my first build so it will benifit me more to do so.
    gotcha on the heads.
    the junkyards around here only have , get this, clunker engines out of a toy pickup-seized the f up
  9. Apr 27, 2010 at 12:40 PM
    desertdude59
    Those plugs can be a pain. I had to have an aluminum insert put in for my spark plug #4 because the threads came out one time during a tune up. Not to be a buzz kill on the heads, but I've heard guys with 20 years have problems with those heads. Too bad you werent closer I'd send you to my buddy who did mine. I think if you replace a valve you have to shave down the valve and make sure the puck is the right size too for the valve clearance. Those pucks just come right out too so don't flip over the head. I did that the first time I ever did my motor during the tear down. Thank goodness it wasnt before the head job!
  10. Apr 27, 2010 at 3:29 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    i understand the headgasket problem, you can not use a MLS (multi. layered steel) gasket and that causes the problems because the metals heat up at different rates.
    i may be getting a 22re with ecu and harness and fuse box from a guy in GA... if i can get the price down. yay
    then i could pull the 3.0 out and do a good overhaul on it. hone, boar polish bearings,pistons,etc
  11. Apr 27, 2010 at 3:33 PM
    desertdude59
    Thats cool. Keep the 22re in there if you can. It probably will last you a lot longer. I looked for a MLS gasket for mine (3.0) and everyone said they dont make them. Good luck on the motor swap though!
  12. Apr 27, 2010 at 3:35 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    do you know a good price for all that? he wants 500 but somone else is selling them for 250-300 and the motor has sat (outside im sure) for at least a year.
  13. Apr 27, 2010 at 3:39 PM
    desertdude59
    If you can get a motor that hasnt sat outside that would be best. Couldnt really tell you a price though. Look around online
  14. Oct 11, 2010 at 11:25 AM
    PISSER
    PISSER "So to speak"
    Shreveport, LA
    Toyota Tacoma Sport
    Toytec 3" Coilover lift with rear blocks, Light Racing UCA's, Shorty radio antenna, Spidertrac 1.25" wheel spacers
    testin my signature
  15. May 3, 2013 at 6:52 AM
    #35
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    :( It didn't work
