Ruger Mk III Issue found
Discussion in 'Guns & Hunting' started by airsoft_warrior, Jun 14, 2010.
  1. Jun 14, 2010 at 8:37 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I took my mk 3 hunter to a gun smith because even with the ammo it liked it still jammed ever couple of shots. He found that the feeding ramp is too short from the factory and that it is a factory defect. Has anyone else had this issue. He is going to see how much they will charge to ship it out to Ruger for me. And if they will charge for the repair. though they shouldnt because it was factory defect. It is a $450 gun. It should be made right for that price but i know things happen. I am done with my rant. comments welcome.
  2. Jun 14, 2010 at 8:48 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Nope mine has never jammed :D
  3. Jun 14, 2010 at 9:12 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Smart ass.
  4. Jun 14, 2010 at 9:12 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Always here to help :p
  5. Jun 14, 2010 at 9:13 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    yep hehehe:rolleyes:
  6. Jun 15, 2010 at 6:10 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    I have the MK III 22/45 and I was kinda noticing the same thing. I've only put a couple hundred rounds through it though, so it's not even broken in yet.
  7. Jun 15, 2010 at 12:33 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    A friend bought a really nice MKIII Hunter.
    Wouldn't feed for shit.
    Back to Ruger.
    don't know what the results are...just got it back.
    I'm liking my Buckmark more and more.
    Never take the Rugers out anymore.
  8. Jun 15, 2010 at 3:19 PM
    2 tacomas
    2 tacomas Slightly Sane
    Northern VA
    2006 TRD Sport 4wd -Sold
    I've lost count....
    I'm sure Ruger will make it right for you. I love my Mark III 22/45 hunter and have never had any major issues with it. It's eaten several thousand rounds with no problems at all....I actually just gave it a good cleaning this past weekend.
  9. Jun 15, 2010 at 6:54 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    My friend took his dad's and used my magazine and nothing happened. with mine what happens is the first couple shots the bullets line up just about right but on the 3rd or 4th shot it hits the nose of the bullet on the ramp and jams. He tried to fix just the ramp but it is part of the barrel so the whole thing will need to be replaced.
  10. Jun 15, 2010 at 7:02 PM
    jpg366
    jpg366 Well-Known Member
    TX
    09 Prerunner SR5
    Try a different magazine.
  11. Jun 15, 2010 at 7:08 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    its the same with every mag. I have tried all three of mine and all 4 of my friends.
  12. Jun 15, 2010 at 7:28 PM
    2 tacomas
    Northern VA
    I've lost count....
    Hmm...
    That's really weird that the first few shots line up fine but then it jams- if it was bent you think it would right after the first shot. Has it always done this (from the very first magazine you put though it) or did it only start doing this after the first time you disassembled/re-assembled it? If the gun gets dirty enough it can have problems ejecting shells cleanly but other than that you shouldn't run into too many other issues due to fowling.
    Are you sure you didn't bend or break something in the gun when you where trying to clean it a while back? I remember you posting about having problems putting it back together and I think you had to use a hammer to get it apart after your initial attempt at putting it back together.
    Either way, if it's having this problem consistently Ruger should be able to duplicate it and fix it for you.
  13. Jun 15, 2010 at 7:33 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    22 pistols will always be 22 pistols. Take it for what it is, and enjoy being able to afford to shoot haha. My sig mosquito gives me FTE's every now and then, but for the 12 bucks I pay for 500 rounds of ammo, i'm more than pleased.
  14. Jun 16, 2010 at 5:28 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Its been like that since I got it. I thought at first it was just because it wasnt oiled up and needed to be worked in but it happens with all ammo and any mag, and it is just mine that is doing it it seems like there is definitely something wrong. the reason its after the first couple of shots is because the first couple of shots the bullets sit at a high enough angle to miss the edge of the ramp but after the second or third round the angle has decreased some and it begins to hit the ramp.
    that is true however if every two shots I have to stop pull the bolt back take out the mag dislodge the jammed bullet that now cant be fired because the nose is screwed up, it is no longer fun. and it really sucks if I am hunting rabbits or squirrels with it.
  15. Jun 29, 2010 at 8:07 PM
    detnight
    detnight Well-Known Member
    David
    Texas City ,Texas
    Texas Edtion Sport Super White
    Bed cover, Borla exhaust,20in wheels The TEXAS edition
    what ammo are you using. I have a MkIII Hunter and have several thousand rounds thru it without one jam. If you are using stingers or yellow jackets they might jam because the case is a little bit longer.
  16. Jun 29, 2010 at 8:15 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I have a MKII and I've had a couple thousand through with no problem.
  17. Jun 30, 2010 at 3:24 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Neither, I used all kinds. every kind i used still gets jammed. The cheap stuff, expensive stuff, high power stuff speciallty load stuff, super sub sonic, hyper sonic. it all acts the same.
  18. Jul 2, 2010 at 9:38 AM
    FlawedXJ
    Paul
    NorAla
    Try polishing the feed ramps?
  19. Jul 2, 2010 at 3:28 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Basically what is happening is that the top of the nose of the bullet hits the bottom of the ramp and digs in and causes the gun to jam. It has hit hard enough in some cases to actually split the bullet.
  20. Jul 2, 2010 at 3:46 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you keeping the gun cleaned?
    We have a MK II and only a couple times has it ever jammed up in years. That was usually due to poor rounds.
    Have you ever lubricated the mag to make sure its springing up properly?
    (I'm just guessing)
