Ruined Rim?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LarryJ, Oct 8, 2019.
  1. Oct 8, 2019 at 6:08 PM
    LarryJ
    LarryJ [OP] '97 Tacoma SR5, Auto, V6 - Virginia Beach
    Didn't bother to look on the backside of the set of rims that I bought today. Is this one with the gouge in it ruined, or can it be simply be ground out.
  2. Oct 8, 2019 at 6:09 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Is that from your calliper?
  3. Oct 8, 2019 at 6:19 PM
    LarryJ
    ...that I bought today. Haven't been on my truck.
  4. Oct 8, 2019 at 6:23 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Doesn't look all that deep from here.
    LarryJ[OP] likes this.
  5. Oct 8, 2019 at 6:28 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Won't be noticeable once installed on the truck. I wouldn't worry about it.
  6. Oct 8, 2019 at 6:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Blend out an area with a flap disc and measure the remaining thickness vs. the surrounding undamaged area. :notsure:
    LarryJ[QUOTED][OP] likes this.
  7. Oct 8, 2019 at 6:53 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    This. Except use a wire cup instead of a flap disc. Flap disc may take away more than necessary, could end up needing a ton of wheel weights to balance that one.
    Running Board Man likes this.
  8. Oct 8, 2019 at 7:00 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    My experience is a wire cup can remove loose paint and corrosion scales, but will struggle with removing the base metal. Here we have a groove made by a bad ball joint or a stone trapped between the caliper and the wheel. The idea is to blend out the groove without deepening it, to provide a more gradual transition and alleviate the stress concentration. Better to use a flap disc for it.
  9. Oct 8, 2019 at 7:08 PM
    LarryJ
    OK. how thin is too thin to use safely.
  10. Oct 8, 2019 at 8:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Depends on how hard you go off-road. :p Use your own judgment (say, -10% from original thickness as a rule of thumb).
  11. Oct 8, 2019 at 8:53 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Run it as is
    06trdtaco and gotoman1969 like this.
  12. Oct 10, 2019 at 1:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As long as it holds air and can be balanced .
    From the picture it does not look deep.
    I have deeper gouges on the outside on some wheels .
    If this is going to keep you awake nights then don`t use it
  13. Oct 10, 2019 at 4:31 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    I would be tempted to just pretend it's not there and use them as-is. I can't imagine it would have a noticeable impact on balance or structural integrity.
  14. Oct 10, 2019 at 9:51 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Kinda looks like a casting imperfection that may have gotten ground down?
