Rumble/Vibration when deaccelerating between 20-15 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaZL, Oct 24, 2015.
  1. Oct 24, 2015 at 7:34 PM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    2013 Regular Cab 2WD 5 LUG
    When deaccelerating from 20-15 mph, the truck will sounds like it is rumbling/vibrating. Comes from the front/middle of vehicle. Promptly stops after exiting this speed range. Believe it to be coming from drive shaft?
    I have noticed the problem is intermittent and seems to get worse in wet conditions. does not happen at all times and seems to happen more on certain roads then others. DOES NOT happen on the highway at all even when getting on and of exits. Does not matter if braking or not. Any ideas as to what it is?
  2. Oct 24, 2015 at 7:40 PM
    gearcruncher
    Canadain bumper technician
    mileage ? auto or manual ?
    Turn the truck off in neutral and coast at the speed where you feel the rumble . Do you still get the rumble ?
  3. Oct 24, 2015 at 7:50 PM
    TacomaZL
    Illinois
    40,000 miles, Automatic Transmission.
  4. Oct 24, 2015 at 7:51 PM
    TacomaZL
    Illinois
    I'll have to switch to neutral tomorrow, cars parked and people are parked behind me. Watcha thinking it is?
  5. Oct 25, 2015 at 5:57 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    By shifting to neutral and cutting the engine it will isolate the engine from the problem. If it doesn't rumble etc with the engine cut it would more likely be an engine problem. If it still does it with the engine cut it is more likely a drive line issue.
    TheTrooper and gearcruncher like this.
  6. Oct 25, 2015 at 9:13 AM
    TacomaZL
    Illinois
    Just drove around for ten minutes, of course it only happened once. It happened so fast I couldn't tell for sure if cutting the engine stopped it or no. I'll post again when I can actually tell for sure what it is. If it is the engine, what could it possibly be? Or is it too general to have an idea of what it is.
  7. Oct 29, 2015 at 4:01 PM
    TacomaZL
    Illinois
    Sad to say, after several days of driving the problem has only occurred about 5 times and STOPS when the truck is switched into neutral. Any idea what it could be? Something major?
    @Jimmyh
    @gearcruncher
  8. Oct 29, 2015 at 4:09 PM
    Pigpen
    Dan
    Northwest Montana
    Shifting into neutral takes the load off of the drive line. It could easily be a u-joint going bad. Do you service the truck yourself? Has the drive shaft been greased at regular intervals?
    Krazie Sj likes this.
  9. Oct 29, 2015 at 4:13 PM
    TacomaZL
    Illinois
    2WD trucks (to my understanding) do not have zerk fittings on them to be hit with a grease gun. I admittedly have never confirmed this with my own two eyes but have heard this info from other members and trusted it to be true.
    With 40,000 miles on the truck, isn't the driveline still covered under warranty? Or would this most likely be something they'd make me pay for?
  10. Oct 29, 2015 at 4:15 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It's $35 to fix it yourself. Take the drive shaft off and check for play. All you need is a jack stand and some wrenches and socket set. Very easy to do, and it'll be a definitive yes/no as to where the rumble is coming from.
  11. Oct 29, 2015 at 4:30 PM
    TacomaZL
    Illinois
    Luckily I have all those tools all ready.
    Don't I need to mark off the driveshaft with whiteout or something before I take it off?
    Also, if I find play, what do I need to do? Replace the U-Joint?
  12. Oct 29, 2015 at 4:47 PM
    Pigpen
    Dan
    Northwest Montana
    The driveshaft is balanced and should not need to be marked, though it is a good practice to do so. It insures that you put everything back together the same as it was. Just mark one bolt front and rear.
    Take a look at the u-joints, the zerks will be visible if they are there. I think i do remember reading in the past that some models have no zerks.
    Drive shaft could be off balance - either a weight missing, or something stuck to it. Very unlikely though.
    Have you changed anything on your vehicle that could create a vibe? lift/ level, airbags, new wheels/ tires...?
    Edit: Keep in mind that it's very difficult to identify the location of a vibration or sound from the driver's seat. A vibe resonates through the entire vehicle.
  13. Oct 29, 2015 at 4:50 PM
    TacomaZL
    Illinois
    Bigger Tires (FROM 215/70R15 TO 235/75R15) and Rims with different offset than stock. However the problem existed prior to these mods as well. I have a 5 lug if that is relevant at all.
  14. Oct 29, 2015 at 4:53 PM
    Pigpen
    Dan
    Northwest Montana
    All info is good info. I've had sealed u-joints go bad within a year on the one ton. No reason you couldn't see the same in 40K
  15. Oct 29, 2015 at 5:35 PM
    TacomaZL
    Illinois
    Alright everyone, thank you very much for all the help.
    My last question is if there is a write up on here for the 2WD taco? If not, any good sources of info detailing the job?
  16. Oct 29, 2015 at 9:31 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Park, chock tires. I like to jack one rear tire up so I can spin/align the drive shaft when you go to put it back on.
    Get another jack under the drive shaft and start undoing bolts. Rest undone end on jack stand then do other end. If yours has a carrier bearing do that first before the flange bolts.
    Press out (beat with a socket+bfh) busted cardon. Press in (beat again with socket+bfg) new cardon. Reinstall in opposite order.
    Very good write up on here with pictures for 4wd. Only mark the drive shaft/flange if you replace the cardon. Otherwise you should be fine. You don't need to mark the Transmission/diff flange+drive shaft. It isn't balanced in relation to those.
  17. Oct 29, 2015 at 10:02 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Some do have Zerk fittings, My 2012 Prerunner does have three zerks and yes the power train is covered until 60K Miles. Ypou never know for sure unless you look. Note: They also do not grease the u joints during the free service.
    I grease mine every oil change and pump until I see new grease come out all four bearings..
  18. Oct 29, 2015 at 10:08 PM
    TacomaZL
    Illinois
    Thanks alot Jimmy for the reply, I will check the driveshaft for zerks and to confirm that it is in fact the u-joint causing the issue.
    Do you agree with the drive shaft/ ujoint prognosis or do you believe there's a chance it's the engine.
  19. Oct 29, 2015 at 11:02 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It could be a u-joint or the carrier bearing or simply the pinion angle to the drive shaft. I know some have issues with the drive shaft angle.... A complex issue.
  20. Oct 30, 2015 at 4:48 AM
    gearcruncher
    Vibrations
    Have you greased your driveline ?http://www.tacomaworld.com/forum/tec...rks-total.html
    Does the truck vibrate in park or neutral and does the vibration change with accelarator pedal ?
    Does the truck vibrate while holding the brakes and hitting the gas - Automatic ?
    Does the truck vibrate in neutral at a stand still ?or coasting in neutral ?
    Does the truck vibrate in 4x4 ?
    Does the truck only vibrate in 2 wheel drive ?
    Does the truck vibrate with the serpentine belt removed ?
    Does the truck vibrate cold or hot ?
    Does the truck vibrate if you select nuetral and coast to a slow roll without using the brakes ?
    Does the truck vibrate as you are braking ?
    Does the truck vibrate with weight in the truck or empty ?
    Does the truck vibrate while upshifting ? Have you checked your trans fluid ?
    Does the truck vibrate while downshifting ? Have you checked your trans fluid ?
    When was your last transmission fluid service ?
    Now that you have a lift kit installed the truck vibrates . Did you cancel your drive line angles ?
    Have you looked at the condition of your tires ? Toyota says to rotate every 5000 miles .Tacoma tires must be road forced balanced using the Haweka adapter on the tire machine [​IMG]tsu00296.pdf
    When was the last time you rotated your tires ?
    Have the balance weights fallen off the tires ?
    The proper and only way to test for bad universal joints is with the driveshaft removed . You cant tell if the universal joints are seized or tight spots with the driveshaft on the truck . You may see play in the universal joints , but you wont be able to properly check the u-joints without removing the driveshaft .All it takes to create a vibration is one seized universal cup and there are 4 cups within each joint .
    With this said , you cant tell if that cup is seized with the driveshaft connected .
    Removing the driveshaft and manipulate each universal joint by hand from side to side feeling for tight spots as you go
    If you beleive its bad motor mounts or transmission mounts , grab a big pry bar and pry at the mounts to see if the rubber is torn or weak .
    Link to transmission servicing https://www.tacomaworld.com/threads...sions-write-up-your-4-speed-automatic.325531/
    http://aftermarket.federalmogul.com/en-US/Technical/Documents/Driveline FAQ's.pdf
