Run to the Hills! - Jason's Completely Stalled Colorado GTFO Build
Discussion in '1st Gen. Builds (1995-2004)' started by jubei, Apr 17, 2016.
  1. Apr 28, 2020 at 11:11 AM
    #2461
    jubei
    jubei [OP] would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’d be lying if I said that the thought hadn’t crossed my mind at times :oops:
    But there is an awful lot of nostalgia with it for me, and since I don’t need to sell it for truck parts I’d rather keep it and turn it into a sweet little crawler someday. I know Jeeps get nothing but hate and derision on here (with some justification), but I’m cool with that. I know mine isn’t the typical douchebro Jeep, and I’m at least slightly less douchey than most Jeep owners :D
    Digiratus likes this.
  2. Apr 29, 2020 at 10:39 AM
    #2462
    Wulf
    Wulf no brain just damage
    rock raisin
    for sure :D
    I've had a few of them jeep things
  3. Apr 29, 2020 at 11:08 AM
    #2463
    jubei
    NoCo
    Stuff. Also things.
    Thanks, Jake!
    Is the CJ-7 the one that is still around? They’re both pretty kickass!
  4. Apr 29, 2020 at 11:12 AM
    #2464
    Wulf
    rock raisin
    yeah, the CJ is still sitting in my parents' back yard in GJ
  5. Apr 29, 2020 at 11:24 AM
    #2465
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I don't mind Jeeps but they have to be 99 or older haha. Those are pretty sick looking
    jubei[OP] likes this.
  6. Apr 29, 2020 at 11:32 AM
    #2466
    jubei
    NoCo
    Stuff. Also things.
    This!
    BYJOSHCOOK[QUOTED] likes this.
  7. Apr 29, 2020 at 11:37 AM
    #2467
    Wulf
    rock raisin
    interesting cutoff... they made TJs with the same body style from 97-06(?). Are TJs out now? :D
  8. Apr 29, 2020 at 12:12 PM
    #2468
    jubei
    NoCo
    Stuff. Also things.
    I like the TJs as well. They were the last ones to run the 4.0L, weren’t they?
  9. Apr 29, 2020 at 12:17 PM
    #2469
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Well I didn't know the last cutoff of them so I just assume anything after 2000 sucks. It's easier for me haha
    Wulf[QUOTED] and jubei[OP] like this.
  10. Apr 29, 2020 at 12:23 PM
    #2470
    Wulf
    rock raisin
    They were, pretty sure Jeep killed off the inline 6 because it wasn't very easy to modify to meet modern emissions standards
  11. Apr 29, 2020 at 12:37 PM
    #2471
    jubei
    NoCo
    Stuff. Also things.
    Yeah, the new V6 is pretty underwhelming based on the few times I’ve driven my dad's newer Jeep.
    My 71 has ZERO emissions gear and never has as far as I know. The current incarnation with with my little Buick 231 V6 has headers dumping straight into little Flownasty mufflers and then dumping straight out to the side :p
    Wulf[QUOTED] likes this.
  12. Apr 29, 2020 at 9:19 PM
    #2472
    Wulf
    rock raisin
    I bet it sounds pretty badass with that setup :D
    jubei[QUOTED][OP] likes this.
  13. Apr 30, 2020 at 4:36 PM
    #2473
    jubei
    NoCo
    Stuff. Also things.
    It’s different, but I do like it :D
    I’m currently reading up on the Dana 44. I want to replace the front D27 and the narrow 44 in the back.
    I kinda want to swap the shittastic T-14 3-speed for a basic TH350 and a mild shift kit too. Just need an adapter from Novak so I can keep the D18 transfer case.
  14. May 9, 2020 at 5:24 PM
    #2474
    jubei
    NoCo
    Stuff. Also things.
    Got seven of my eight jack stands off of the floor and made use of this awkward corner in the shop. Also managed to fit in my shop stool so it’s not taking up floor space either.
    rngr, Datsik, Fuergrissa and 11 others like this.
  15. May 9, 2020 at 5:36 PM
    #2475
    Wulf
    rock raisin
    You sure you don't want to swap to a Dana 300 with a 4:1 kit?
  16. May 9, 2020 at 6:13 PM
    #2476
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I’m completely stealing this idea!
  17. May 9, 2020 at 6:34 PM
    #2477
    Phessor
    Phessor Well-Known Member
  18. May 9, 2020 at 8:26 PM
    #2478
    jubei
    NoCo
    Stuff. Also things.
    The 300 is a great case, for sure, especially with the 4.1s.
    It really depends on how crazy I want to go with it. I just need to read up a lot more on what will fit, which drives everything on these early CJ5s. The short wheelbase is one of my favorite things about it, but it makes it tough to keep the drivelines and other stuff happy.
    I may just rebuild the D18 with 3.15 gears, add the overdrive back, swap the front to a D30 with disc brakes, and wheel it as is...
    Do it!
    With the door from outside right there it made that corner completely useless. It’s so much better now and getting back the floor space was really nice.
  19. May 9, 2020 at 9:52 PM
    #2479
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Yep. I'm stealing this. Just in time as well. My dad and I are going to be ripping apart his garage pretty soon and reorganizing it.
  20. May 10, 2020 at 9:46 PM
    #2480
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    YJs FTW!
    jubei[OP] and Wulf[QUOTED] like this.
