Running 24v LEDs off two 12v batteries
Discussion in 'Lighting' started by 02TACOMA4WD, Aug 5, 2013.
  1. Aug 5, 2013 at 4:36 PM
    02TACOMA4WD
    02TACOMA4WD [OP] Well-Known Member
    02 Tacoma TRD 4x4
    I've come into a problem with re-wiring my 24v LEDs. The previous owner was running five 24v LEDS off of two 12v batteries and a battery isolater and some how getting it to work. I've been trying to do the same way he did it and can't seem to wire it correctly. If anyone can give me some tips it would be much appreciated
    Also the battery isolator is a PAC-200 and the lights are truck-lite 24v 7" ten diode pattern
  2. Aug 5, 2013 at 4:37 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  3. Aug 5, 2013 at 4:38 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    That's what I'm saying Lol
  4. Aug 5, 2013 at 5:34 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  5. Aug 5, 2013 at 5:41 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
  6. Aug 5, 2013 at 5:44 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can run car batteries in series to create a 24V system, this is what people who are restoring old vehicles with 24V systems do. Since the rest of the truck is 12V, that's not really a viable option. Your next option would be a convertor that will step 12V up to 24V but it will take away 1/2 the amperage. Depending on how much power you need, the convertors might not work for you. It'd be a whole lot easier to just get a set of 12V lights that actually work with the truck's electrical system.
  7. Aug 5, 2013 at 5:45 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    You can also just run the lights on 12v... they just won't be exceptionally bright ;)
  8. Aug 5, 2013 at 5:48 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    These lights were already on the truck when I bought it and the previous owner had them wired a certain way for them to work. I decided to rewirethe lights and now I cannot figure out how the PO had them wired
  9. Aug 5, 2013 at 5:49 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    They barely flicker with 12v....
  10. Aug 5, 2013 at 5:50 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Was there no transformer box or something for them you might have disconnected re-wiring them?
  11. Aug 5, 2013 at 5:51 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    They were hooked up to a PAC-200 battery isolater
  12. Aug 5, 2013 at 5:54 PM
    Pugga
    Massachusetts
    Is this how you have your PAC unit wired? I'm not overly familiar with how it works but I think I sort of get the idea of how it's supposed to work
    http://archive.pac-audio.com/instructions/PAC-200.pdf
  13. Aug 5, 2013 at 5:55 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
  14. Aug 5, 2013 at 5:57 PM
    Pugga
    Massachusetts
    Is that how you have them wired, like in the PDF?
  15. Aug 5, 2013 at 5:57 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    No transformer needed just wire the batteries in series to get the 24V. You only have to run one wire (fused) between the batteries for the lights and can leave the isolator in place. It just won't isolate the light circuit.
  16. Aug 5, 2013 at 6:01 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    With this still allow 12v for the truck?
  17. Aug 5, 2013 at 6:03 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    Yes. Just run the one 24v series circuit to the lights. Leave the rest as is.
  18. Aug 5, 2013 at 6:04 PM
    Pugga
    Massachusetts
    No, I don't believe you can put the batteries in series, run 12V for the truck and 24V for the lights. Should be one or the other unless you add some hardware.
  19. Aug 5, 2013 at 6:06 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    So one wire from positive to negative of the other battery and from the positive to the lights then from the lights to the negative of the first battery. Just make sure you fuse it.
  20. Aug 5, 2013 at 6:13 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    Thinking about it. If the first battery is common grounded it might not work. Yeah disregard. If the first battery is common grounded it won't work.
