Running 24v LEDs off two 12v batteries
Discussion in 'Lighting' started by 02TACOMA4WD, Aug 5, 2013.
  1. Aug 5, 2013 at 6:13 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Keep in mind, you will void any warranty from a battery if you run them in series, most of them explicitly state as much.
    I think I understand what you're recommending, keeping one battery connected to the truck normally and running a second battery in series and only running the power wire from the second battery to the lights. Not sure I'd trust that with the stock electrical system.
  2. Aug 5, 2013 at 6:14 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    You would have to completely isolate the first battery
  3. Aug 5, 2013 at 6:16 PM
    Pugga
    Massachusetts
    I think that's what the PAC unit is supposed to do, at least that's what I gathered when reading about it. Seems to be common for high powered stereo systems.
  4. Aug 5, 2013 at 6:22 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    It is easier for me to draw. Frame (common ground) negative of first battery, positive of first battery to vehicle, to negative of second battery, then positive of next battery to lights then ground lights to frame. That gives 24 v to lights and not the truck.
  5. Aug 5, 2013 at 6:28 PM
    Pugga
    Massachusetts
    Agreed, that's exactly what I said earlier, it's simply wiring 2 batteries in series which gives you 24V. Now how do you power the truck with 12 volts in there?
  6. Aug 5, 2013 at 6:30 PM
    Pugga
    Massachusetts
    OP, do you have your setup wiring like the PAC wiring diagram?
  7. Aug 5, 2013 at 6:34 PM
    02TACOMA4WD
    02TACOMA4WD [OP] Well-Known Member
    02 Tacoma TRD 4x4
    Yeah, The PO ran a wire from the accessory post to one of battery post on the PAC unit.
  8. Aug 5, 2013 at 6:53 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    The first battery powers the truck at 12v. Then tag the positive of that battery to the negative of the second battery (but do NOT connect that negative to ground , ie the frame) connect the positive of the second battery to the lights and then the negative of the lights to the frame.
  9. Aug 5, 2013 at 7:37 PM
    Aw9d
    Aw9d That one guy
    Wire both batteries to be in series and you'd get 24v.
  10. Aug 5, 2013 at 8:43 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    I'll give this a try tomorrow. Thanks for all the help guys!
  11. Aug 8, 2013 at 4:24 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    This worked!thanks everyone for their input and help:D
  12. Aug 8, 2013 at 4:27 PM
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    Glad it worked out for you
  13. Aug 10, 2013 at 5:58 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Using two identical deep cycle batteries in series will produce 24 VDC, but recharging the batteries from your vehicle's 12-volt charging system will be tricky. A better approach is to use a 12 VDC to 24 VDC Converter sized to supply the necessary current for your 24 VDC LED lighting.
