Running 285s without CMC?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scubasteve671, Apr 24, 2018.
  1. Apr 25, 2018 at 7:33 AM
    #41
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    PNWskibum likes this.
  2. Apr 25, 2018 at 8:02 AM
    #42
    tincup33
    tincup33 Well-Known Member
    Beaverton, OR
    2021 TRD S AG DCSB
    I'm running an Icon stage 2 kit with 17x9 -12 Fuel Rippers and 285/70/17's and the only rubbing I had was taken care of with my heat gun. No cutting anywhere.
    Key-Rei likes this.
  3. Apr 25, 2018 at 8:16 AM
    #43
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Just chop the thing. It's the right thing to do.
  4. Apr 25, 2018 at 8:21 AM
    #44
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    What’s shop?
  5. Apr 25, 2018 at 8:21 AM
    #45
    scubasteve671
    scubasteve671 [OP] Professional Beer Drinker
    Barf
    17 TRD OR ACCESS CAB
    2.5 Icon coil overs, Icon AAL 285s on black rhino rims
    Are you running UCAs? ?
  6. Apr 25, 2018 at 8:22 AM
    #46
    MMoreno16
    MMoreno16 Cupcake Forest Ranger
    Los Angeles
    2018 TRD OR DCSB
    not sure the truck would move without UCAs :D
    MGMTaco17 likes this.
  7. Apr 25, 2018 at 8:23 AM
    #47
    scubasteve671
    Barf
    "Stock"? u happy? . :anonymous:
    MMoreno16[QUOTED] likes this.
  8. Apr 25, 2018 at 8:28 AM
    #48
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Alignment specs are important to get clearance too, you want as close as you can get to 0 camber 0 toe and +2.5° to +3° of caster.
  9. Apr 25, 2018 at 8:39 AM
    #49
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Of course.. I’m not one of those ppl that don’t run UCAs :anonymous:
    I’ll say this tho, Dakar leaf pack and ucas are totally worth the investment.
    remgu2000 likes this.
  10. Apr 25, 2018 at 8:47 AM
    #50
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    RSG Offroad on Colfax
  11. Apr 25, 2018 at 9:53 AM
    #51
    KanPanic
    State of Jefferson
    2018 OR
    Excellent I already have an appointment scheduled.
    upTOPOverland_Drew likes this.
  12. Apr 25, 2018 at 9:58 AM
    #52
    upTOPOverland_Drew
    Drew
    Littleton, CO
    did you schedule before or after i told you?
  13. Apr 25, 2018 at 9:59 AM
    #53
    KanPanic
    State of Jefferson
    2018 OR
    Talked to them last week. Thanks for the recommendation! :thumbsup:
  14. Apr 25, 2018 at 10:18 AM
    #54
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    I ran 285s (MTR Kevlar) on rims with the proper backspacing on my 2010 with no CMC and no rub ever. Offroaded the truck pretty hard. I did however do a CMG, a cab mount grind. If you look at the cab mount, the metal on the bottom is “folded” up on the front, all i did was grind off that fold which is maybe 1/4 inch. Good to go. I had a OME lift and spc UCA. First 886 coils then switched to 887s. I prefered not to cut the cab mount especially because it wasnt necessary at all. The front cab mounts are as beefy as they are because they are designed to stop your front wheel from penetrating the cab and pin your legs in case of a frontal impact.
    I myself had a head on collision with my 2010, both vehicles traveling at hwy speeds. My front wheel was ripped off and destroyed against the cab mount as designed, the cab mount took the full impact. It was bent back a few inches and started to seperate from the frame. When I saw that i was extra glad I didnt do a CMC, especially a super agressive one like some people do. Its more than just a cab mount. Watch the 2017 toyota tacoma driver side overlap IIHS crash test on youtube and you can see the front cab mount in action.
    JoeRacer302 and hiPSI like this.
  15. Apr 25, 2018 at 11:05 AM
    #55
    swissrallyman
    Just had a look at the front cab mount on my 3rd gen, wow what a difference from the cab mount on the 2nd gens. Way bigger now.
    Joe23 likes this.
  16. Apr 25, 2018 at 11:19 AM
    #56
    upTOPOverland_Drew
    Drew
    Littleton, CO
    bigger as is more or less space for wheels?
  17. Apr 25, 2018 at 11:58 AM
    #57
    swissrallyman
    Bigger towards the rear. Front looks the same as on the 2nd gens
  18. Apr 25, 2018 at 12:53 PM
    #58
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    What notch # is your 6112 set on?
    Mines set on max notch #6 (going 9 months w/o any issues) and been researching on fitting 285/70/17 with 0 offset FN fx wheel and SPC LR UCAs.
  19. Apr 25, 2018 at 2:08 PM
    #59
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    its even bigger towards the front. The shop that did my CMC told me the same and mentioned he had a lot more to cut off than he does on 2nd gens.
  20. Apr 25, 2018 at 8:07 PM
    #60
    KiteGuam
    KiteGuam The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
    I'll watch
