Running A Spacer on One Wheel
Discussion in 'Wheels & Tires' started by afd23a, Apr 28, 2011.
  1. Apr 28, 2011 at 2:10 PM
    afd23a
    afd23a [OP] Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've got a question for the wheel gurus. Is it okay to run a thin wheel spacer on only one wheel?
    Here's my situation:
    My truck was recently in an accident and the driver's side front wheel was cracked. The insurance company is only paying to replace the damaged wheel. The wheels on my truck are 15x7 Eagle Alloys Series 146. The problem is that the specific wheel model number hasn't been made in three years or so and they are hard to find. Eagle Alloy had one left in the country but it was a "display model". I had the body shop get the wheel and it came in last week. So I hear today from the body shop that this wheel rubs the brake caliper when it's mounted. Like the backspacing/offset is not perfect. The solution they are proposing is to use a thin spacer (1/8"-1/4") so that it won't hit the caliper. They claim that this will not cause any long term problems and it will ride like before. According to the lady at the body shop this isn't that uncommon with aftermarket wheels. Eagle Alloy won't claim that the wheel is defective without it being returned to them and then inspected by their people. I don't like the idea of running the spacer, but my only other option is to buy a new set of wheels which I was hoping I wouldn't have to do and prolongs my truck being in the shop.
  2. Apr 28, 2011 at 2:19 PM
    sgeezy
    sgeezy Active Member
    Shelton
    PB ARK
    SCRATCH n SNIFF
    2.5" rough country lift, Billy 5100's up front, 31X10.50x15 BFG KM2 tires, 15x7 Black Crager 397 series soft 8 wheels. One 15" kicker L7 Subwoofer in ProBox. 2000 watt volfenhag amp. K&N Cold air intake. And 266K miles
    I don't see the problem with running a wheel spacer on only one wheel. Your best bet would be to measure the difference on that one wheel compared to the others and space it accordingly so that, that specific wheel has an equal backspacing as the others.
  3. Apr 28, 2011 at 2:21 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Not an expert on this, and don't really have any specific reasons, but I would never run a wheel spacer on one wheel. I would also be concerned that the one wheel you have is off in more ways than just that if none of your others rub the caliper. something is just not right.
  4. Apr 28, 2011 at 2:22 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    No, just shave the caliper
  5. Apr 28, 2011 at 2:25 PM
    afd23a
    The Dynamo of Dixie
    That's what my gut is telling me. I don't know if anything is really wrong with running one spacer but it just seems kind of sketchy.
    I suggested that and the body shop was very adamant that they will not do that.
  6. Apr 28, 2011 at 2:29 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i would get in touch with the insurance co. and explain what is going on, that you CAN NOT get a direct replacement rim that works and hopefully they will get you 4 new rims
  7. Apr 28, 2011 at 2:37 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    It shouldn't hurt anything. With that small of a spacer, you will not be changing the geometry enough to ever notice. But why not just put a small spacer on the other side to even it out?
  8. Apr 28, 2011 at 2:37 PM
    afd23a
    The Dynamo of Dixie
    I asked the shop about that early on because they hadn't found a replacement wheel yet and were afraid that they wouldn't be able to find one. According to the body shop the insurance company will only pay to replace the damaged wheel and not an entire set. However the amount the wheel is valued at can be applied to a new set of wheels.
  9. Apr 28, 2011 at 2:39 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The Eagle 146's are side-specific?!
  10. Apr 28, 2011 at 2:41 PM
    pudge151
    Sean
    Connecticut
    good point cant you put the new wheel on the rear or try the other side
  11. Apr 28, 2011 at 2:44 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
  12. Apr 28, 2011 at 2:57 PM
    PreRunnerSeth
    Apex, NC
    besides the toyota lugs are pretty damn short to begin with. you would lose another 1/4" of thread bite if you use a spacer like that.
  13. Apr 28, 2011 at 3:00 PM
    KPT
    09 Prerunner
    Shameless plug :D
    http://www.tacomaworld.com/forum/wheels-tires/119883-wheel-studs-too-short-what-do.html
    I'm not buying this side-specific thing. How are you supposed to rotate your tires if your wheels are side specific? What is different on the hubs/calipers on each side of the truck that would make having a side-specific wheel necessary? Why aren't all other wheels that fit tacomas side-specific if these need to be?
  14. Apr 28, 2011 at 3:04 PM
    afd23a
    The Dynamo of Dixie
    You're right they're not side specific. It can go on the front or rear either side. If they put it on the rear then when the tires are rotated it will go up front. The spacer will have to travel with it so that it clears the caliper.
  15. Apr 28, 2011 at 3:07 PM
    afd23a
    The Dynamo of Dixie
    Good plug. I already run E/T lug nuts so that the wheels are get centered on the hubs.
  16. Apr 28, 2011 at 3:10 PM
    KPT
    09 Prerunner
    I guess I'm confused as to why one wheel would need a spacer but the others did not :notsure:
  17. Apr 28, 2011 at 3:12 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Have the insurance buy you a whole new set of wheels!! tell them your wheel never had a spacer or the caliper shaved and still want it that way.. Thats why you pay them every month.. have them keep the 3 old ones. Thats what i would do.
  18. Apr 28, 2011 at 3:33 PM
    afd23a
    The Dynamo of Dixie
    It's because the replacement is out of spec. It's the same model number as the originals but it sounds like the offset is different.
  19. Apr 28, 2011 at 3:35 PM
    afd23a
    The Dynamo of Dixie
    Tried a little while ago. They aren't budging. It's the other driver's insurance that's paying in the end so I guess my insurance is afraid of not getting paid for the other three rims.
    I'm going to try this again tomorrow morning.
  20. Apr 29, 2011 at 2:47 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    did you have them try the stock wheels to see if it hits if you have them or have them try that wheel on the r/f to see if it hits on the caliper
    sounds like somthing else may be wrong if its the same wheel as the rest
