Running compressor: Newb question
Discussion in 'Off-Roading & Trails' started by GIANTSteps, Jul 29, 2017.
  1. Jul 29, 2017 at 11:07 AM
    GIANTSteps
    GIANTSteps [OP] Well-Known Member
    Brandon
    Reno
    2017 Tacoma TRD Off Road Access Cab
    Added SnugTop cap and KO2's
    When using my ARB compressor off my tacoma battery, do I want my engine running? Already used multiple times with the engine off, but this would seemingly drain my battery after a while, no?
  2. Jul 29, 2017 at 11:17 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    You will never know when using the compressor with the truck turned off if it will start again until it doesn't. Then you will have air in the tires but no juice in the battery. I always air up or winch with the rig on.
  3. Jul 29, 2017 at 12:00 PM
    GIANTSteps
    Brandon
    Reno
    Thanks - I do appreciate it!
  4. Jul 29, 2017 at 11:47 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    You could hook up a volt meter.
    You could also look up the amp draw on the compressor, then check your battery's reserve power and do a guesstimate.
  5. Aug 1, 2017 at 2:01 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You might be able to set up a low voltage cut-off if using your primary battery, or have a secondary battery. A lot of overlanders are running 2 batteries.
    You could also just test it out at home. You should probably do this anyway so you have a good idea how long it takes to fill up, but also how to actually work the equipment. If you happen run out of juice while in your driveway, big deal, just get a jump from the wife/neighbor's car.
    But probably the easiest thing to do is just have the rig running while filling up...
  6. Aug 1, 2017 at 2:47 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    doesn't ARB say to only run with the truck running?
    When I had my dual arb it said run while using it.
    I know my Viair portable says to run the truck while hooked up as well.
    Regardless like posted above, I wouldnt run it without the truck on.
