Running J59 Deaver Springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruben526, Feb 27, 2018.
  1. May 24, 2018 at 7:32 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I really have no idea about the 881's. When I did mine I just wanted as close to stock lift as possible and the 880's were it. I didn't measure but I suspect I got 2" of lift up front since they say 1.5" for a V-6. Probably closer to 3" considering the worn out stock springs with 150,000+ miles on them. I think the 881's are just a little stiffer.
    TheDamaso likes this.
  2. May 25, 2018 at 5:00 PM
    TheDamaso
    TheDamaso Active Member
    Damaso
    98 Tacoma 2.7 4x4
    Awesome! You sir are a scholar and a gentleman. I’m getting real ready to shoot!!! But I live in an apartment soooo now I gotta figure out where to park my truck to install all this lol
  3. May 27, 2018 at 8:06 PM
    TRVLR500
    Wyoming
    I live in an apartment as well. I head over to another state where I have a red-neck friend of mine and his red-neck buddies. Whenever I have something major it's beer and cash for them. They did my suspension for me in his garage. I basically just supervised. Had to make sure they greased and torqued everything right.
    It would have taken me a couple of days cussing and swearing if it wasn't for those guys. One guy could do it in a day, probably even half a day with the right tools if he's a younger guy but not me.
  4. May 27, 2018 at 8:39 PM
    TheDamaso
    Damaso
    98 Tacoma 2.7 4x4
    Ayyyy I know exactly what you talking about...except I was the Beaner getting payed with beer back home in Texas lol
  5. May 30, 2018 at 8:08 PM
    TRVLR500
    Wyoming
    Well, if your young and spry you could knock out the front one day and the rear the next day. I was lucky. No rust on any of my bolts. Everything just came right out with the air wrench. I could have re-used the front and rear bolts for the rear springs but had new ones just in case and went ahead and used them. If yours are really rusty it'll be some work to get it apart from what I have read.
  6. Jun 9, 2018 at 2:57 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Proformance: Magnaflow K&N CAI Billet grille Suspension: Fox 2.5 Coil-overs with DSC Total Chaos UCA Deaver j59 Leaf Springs Bilstein 5100 0"-2" Rear Shocks
    Kiloyard, I just installed my Deavers. I now have the "stink bug" look weere the rear sits higher in the back. Do you have that look, if so, did you correct it or left it alone?
  7. Jun 9, 2018 at 3:01 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 325k miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Hmm, I didn't get a stink bug on mine because I had the front lifted with adjustable height coilovers to level it. What are you running up front?
  8. Jun 9, 2018 at 3:10 PM
    2004Taco
    Long Beach,CA
    I have FOX 2.5 coilovers with DSC. Since I installed the Deavers, it sits about 1" higher than before. I like the way the front is set up but If I need to adjust them 1" higher, will that make the front end ride stiffer?
  9. Jun 9, 2018 at 3:20 PM
    Kiloyard
    Phoenix, AZ
    I don't know anything about the ride characteristics of your Fox setup (sorry, I'm a newbie), but it should be pretty easy to adjust them and test it out. My truck drives awesome with 1.5" lift front and back.
  10. Jun 9, 2018 at 3:33 PM
    2004Taco
    Long Beach,CA
    Yea, I'm fairly a newbie with FOX too, I haf spacers for a while. I'm not liking the rear sitting higher but I've been told that If I added some weight in the rear it should settle. IDK, still reading on the forms with this issue.
  11. Jun 13, 2018 at 10:34 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 Pre-Lander
    My buddy and I just installed some deavers on his 02 tundra and they creak like crazy. Can anyone confirm them getting less obnoxious once broken in?
  12. Jun 13, 2018 at 12:37 PM
    2004Taco
    Long Beach,CA
    My Deavers creak. I was told to shoot them with Tri-Flow or WD-40 but I haven't done that yet. I'll do it today to confirm.
  13. Jun 13, 2018 at 12:42 PM
    LukeCC
    Luke
    2002 Pre-Lander
    Awesome man. Let me know. Thanks
  14. Jun 13, 2018 at 1:32 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Why is this?
    I was considering the Deavers, and then using the shackles I current have, which are ~1" longer than stock. The 1.5" of lift from the J59s probably won't quite enough for me since I will be running pizza cutter 33's so I'll have 2.5" or so in the front, and want it level (ish). I'm not doing leaf blocks to level it.
  15. Jun 13, 2018 at 4:04 PM
    #35
    jbrandt
    Sacramento, CA
    I would think you should use a dry lube, like teflon or something. oil lubes will just make dirt stick to them.
  16. Jun 13, 2018 at 5:34 PM
    #36
    LukeCC
    Luke
    2002 Pre-Lander
    Yeah that would make sense.
  17. Jun 14, 2018 at 7:28 PM
    #37
    TRVLR500
    Wyoming
    J59 Deavers do add about 1-1.5" of height. Mine did. I also screwed up and bought 1" longer rear, greasable shackles so I ended up with more lift than I wanted. That was about two years ago. It hasn't caused any problems and I keep about 450 lbs in the back all the time so I don't get the stink bug look. I'll be replacing the shackles with the standard length some time this summer.
    Believe it or not my J59's never squeaked at all until I hosed them down with Fluid Film. Then they squeaked like crazy until the Fluid Film wore off. Yes, it's true. Go figure. They are totally silent these days.
  18. Jun 14, 2018 at 7:32 PM
    #38
    TRVLR500
    Wyoming
    If you want 2.5" out back the J59's and those 1" longer shackles will give you exactly what you want.
  19. Jun 15, 2018 at 8:09 AM
    #39
    jbrandt
    Sacramento, CA
    This is what I figured, @Anthony250 just said you shouldn't run lift shackles and I'd like to hear why he says that...
  20. Jun 15, 2018 at 4:30 PM
    #40
    Kiloyard
    Phoenix, AZ
    Probably just a preference. I've read that you want the shackle to be perpendicular to the main spring when at rest and a longer shackle would force a narrower angle, wouldn't it?
