Running Taillight Out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Isaac77, Oct 1, 2024.
  1. Oct 1, 2024 at 8:42 AM
    Isaac77
    Isaac77 [OP] New Member
    Isaac
    2005 Tacoma Prerunner
    All my lights work just fine, even my running taillight on passenger side works, but my driver side running taillight doesn’t work and it’s not the bulb, any idea on what it could be or how I could fix this?
  2. Oct 1, 2024 at 8:46 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do the license plate lights work?
    Green wire is power.
    White/Black is Ground.
    We need to see what is missing.
  3. Oct 1, 2024 at 8:56 AM
    Isaac77
    Isaac
    Yea license plate lights work
  4. Oct 1, 2024 at 8:57 AM
    TnShooter
    Deogee
    STOCK
    Are the tail lights OEM?
    And are they LED?
  5. Oct 1, 2024 at 9:00 AM
    Isaac77
    Isaac
    They were OEM and the light was out and then I switched them to aftermarket LED thinking it was a bulb issue and it’s still out.
  6. Oct 1, 2024 at 9:05 AM
    MR5X5
    MR5X5 Well-Known Member
    Do you have a meter? Have you probed the socket for power? Is the socket shiny clean?
  7. Oct 1, 2024 at 9:08 AM
    Isaac77
    Isaac
    Well my brake lights work on that taillight and it’s the same socket so I don’t believe it’s the socket, is it possible for it to still be the socket?
  8. Oct 1, 2024 at 9:37 AM
    MR5X5
    Probably not. Curious if the LED is not getting sufficient voltage to fire.
    You might want to try swapping bulbs side to side to rule out a defect with the bulb.
  9. Oct 1, 2024 at 9:53 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You tried flipping the LED around? Filament bulbs don't care about polarity. LEDs being diodes typically work in only one orientation.
    The stock bulb is a 3157 dual filament bulb with two sets of contacts. Is the LED designed to replace a 3157 bulb with two brightness levels (running light and brake light)?
