Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Mar 13, 2018 at 12:18 PM
    #281
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Yes it is indeed still an issue with 2018's.
  2. Mar 13, 2018 at 3:22 PM
    #282
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    No. Just use heater hose, no problems. My 4runner has the same issue, so I did this mod on it too, no problems.
  3. Mar 13, 2018 at 3:33 PM
    #283
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    Is this even a real issue at all though. As I’m under the car, I’m just thinking to myself, water gets everywhere under here...
    Bubbles and Riding Dirty[QUOTED] like this.
  4. Mar 13, 2018 at 3:42 PM
    #284
    Riding Dirty
    PlastiDip
    This is true. But, where the ac line drips is is directly on the front of the frame, and it drops whether you run the ac or heat, so it’s the slow water drip that never stops. Premature rust starts in that area, so for $15 and a few minutes of time, it reduces my risk of premature frame rust as well as my fluid film protection.
    AZJuice and Intrepid like this.
  5. Mar 14, 2018 at 4:27 AM
    #285
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    Been wanting to try this mod but just haven't gotten around to it. Not sure the exact route I want to go since I've seen different guys in here go about it a little differently. Anyways, fluid film. How exactly did you apply that, and what exact areas did you put it on? Does it make it super messy underneath, like does it attract dirt all over it? If I lay under my truck to change the oil, am I gonna get this stuff all over me?
  6. Mar 14, 2018 at 6:39 AM
    #286
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    - spray from can or use gun
    - everything underneath, inside rockers, tailgate, and bottom of doors, fenders, wheel wells
    - not super, but yes, a bit
    - yes
    - not unless you wipe all of you all over the bottom of your truck, it does not drip
    CodyH.[QUOTED] likes this.
  7. Mar 14, 2018 at 7:50 AM
    #287
    Riding Dirty
    PlastiDip
    ^^what @jtifm said, except that I covered the exhaust system so it wouldn’t smoke everywhere after using fluid film.
    Yes, it’s a little messy, but doesn’t drip. Messy is better than rust.
  8. Mar 22, 2018 at 7:12 PM
    #288
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    Thanks for the great write up @Uptown2k ! Did this fix today. Since I bought my truck in October, I haven’t run the A/C yet, so the frame is clean. Fix took 25 minutes, and much of it was pulling & reinstalling the wheel.
  9. Mar 23, 2018 at 3:59 AM
    #289
    CodyH.
    Cody
    Arizona
    Can you please describe what inside rockers means exactly? Lol that's probably a dumb question but I'm not 100% sure what that refers to. And also, you mean you actually put that stuff all over your tailgate? I've never seen this stuff in person so I'm trying to visualize it
  10. Mar 23, 2018 at 10:43 AM
    #290
    Riding Dirty
    PlastiDip
    Rocker panels. Remove the plastic instep protection/door sill pieces, there are holes that they snap into. Spray fluid film all in those holes. Ever see trucks rusting away just beneath the doors? They rot inside out, this can help prevent that. Your tailgate......remove the plastic panel lining the tailgate, the skeleton will be exposed, spray away.
    2016Tacoman and CodyH.[QUOTED] like this.
  11. Mar 23, 2018 at 11:59 PM
    #291
    jtifm
    2017 TRDORDCSB
    I get to the rockers from underneath, IIRC 8 rubber plugs about the size of a nickel. Using the aerosol can with the hose attachment that comes in the kit you can get inside the doors through the drain holes along the bottom, have your windows up when you do this or it will probably get all over them. Like Riding Dirty said, pull the plastic liner on the trunk, just be gentle with the screws when putting things together. They strip with little force, and I think there are two sizes to keep straight. Down side, that stuff will be weeping out the doors and tailgate for months. It is designed to creep, making stains (which wash off) everytime things warm up. Unless you wash about weekly, get used to looking at it.
    Riding Dirty and CodyH.[QUOTED] like this.
  12. May 18, 2018 at 4:42 PM
    #292
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    I’ve got 1500 miles on my 18 and these welds are already getting a bit rusty here. Just bought materials and doing this tomorrow.
    I’m in SoCal, AC is forever on.
    lshep likes this.
  13. May 18, 2018 at 4:53 PM
    #293
    808 FN-2199
    808 FN-2199 New Member
    2017 White Tacoma TRD Sport
    Living in Hawaii, this is the first mod i did since the AC is always on.
    lshep likes this.
  14. May 19, 2018 at 7:35 AM
    #294
    MunchTIME
    SD, CA
    I used 1 size larger clamp and ran the hose a bit further forward to keep it away from the exhaust. Blows my mind they haven’t done something about this yet
  15. May 21, 2018 at 10:31 AM
    #295
    rockrosa1976
    rockrosa1976 First time Taco owner
    Cincinnati
    2017 SR5 V6 4X4 DCSB
    Window Tint - August 2017 Predator Steps - August 2017 All Weather Mats - August 2017 Chrome Exhaust Tip - August 2017 Hitch Cover - August 2017 Center Console Organizer - September 2017 Bed Mat - September 2017 Nox Lux Blackout Overlays - October 2017 Nox Lux Tacoma Tailgate Inserts - October 2017 Pro Grill - December 2017 Clazzio Leather Seat Covers - February 2018 Rear Seat Cover - February 2018 Bed Netting - February 2018 Plast-Dipped Wheels/bumper caps - April 2018 A/C Drain Mod - May 2018 OEM Tonneau Cover - July 2018 LED Headlights/Fogs - August 2018 Glovebox letters - October 2018 TRD Pro Shift Knob - April 2019 Rigid Fog lights - November 2019 Goodyear Wrangler AT 265/70/16 - March 2020 Grill Lettering - May 2020
    15 minutes and done!
  16. May 22, 2018 at 7:05 AM
    #296
    Sone Taco
    Sone Taco Tacoma rules!!!
    Sone
    Rochester, NY
    2017 Barcelona red TRD OFF ROAD DCSB, 2005 Red AC 2.7 MT 190k mil, 1995 Maroon Reg cab 2.7 MT w/ 360k
    slowly but surely...
    F*ck yeah! Send that to Toyota engineers :annoyed:
  17. May 24, 2018 at 6:21 PM
    #297
    17TRD
    17TRD Well-Known Member
    2017 TRD OR 4X4 DCSB
    So has anyone had the hose clog up yet for whatever reason? It would seem a valid concern, and its been almost two years since some of you did this mod.
  18. May 24, 2018 at 9:58 PM
    #298
    Riding Dirty
    PlastiDip
    I’ve not had an issue yet, I even pulled mine off recently to check, all is ok.
    Norsemanvike and 17TRD[QUOTED] like this.
  19. May 25, 2018 at 3:46 PM
    #299
    TheyCallMeBruce84
    TheyCallMeBruce84 Well-Known Member
    NC
    2020 Tundra Limited CrewMax Barcelona Red
    I've not read thru this entire thread but I like your approach here. Can you share details on the parts used? Looks like much lighter clear tubing and a push on connector. Had to be cheaper too.
  20. May 25, 2018 at 9:09 PM
    #300
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Thanks for this. Needed something to do tomorrow.
