Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Aug 3, 2016 at 1:30 PM
    Uptown2k
    Uptown2k [OP] Well-Known Member
    Jordan
    2016 MGM TRD OR DCSB4x4
    I noticed a small spot of surface rust forming on the frame and noticed the a/c was draining right onto the frame and causing the issue.
    Not a big deal now as the truck only has 7k miles on it but over the years this could lead to a bigger problem.
    the a/c drain is on the passenger side firewall and is a very short tube pic is below. The a/c ends up draining out onto the frame and where the welds are rust is beginning to form.
    To solve the issue you will need 25" of 5/8" diameter heater hose (can be purchased at most auto stores) and some hose clamps (stainless steel 1/2"-7/8" are the ones I used) and two zip ties
    I found it easiest to access the a/c drain from inside the passenger side front wheel well. I removed the two clips at the top and folded the cover down for easy access. Put the clamp on the 5/8" hose and slide it over the stock drain all the way should fit nice and snug. Tighten the clamp, make sure you don't tighten it too much and restrict the water flow just enough to hold the hose in place. Now take the hose and thread it thru the 2nd hole as shown in picture. I placed one zip tie at top before hole and one at bottom to secure hose in place. Trim to your liking once it's in as you will most likely have about 1" much.
    I then bought some rust prevention paint and made sure to hit all the welds that could have been effective and also the rest around the bottom of the truck just to be safe.
    Hope this saves some people, it would have been the first thing I did to the truck had I known about the issue. Whole mod takes about 10 minutes tops
    Credit to TW member @moe2o4 for the post buried on another thread with the measurements for the hose
    lsrmath, econwatch, dpele and 292 others like this.
  2. Aug 3, 2016 at 1:32 PM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Fuck yeah nice
    blairrad, AFS, drvn and 14 others like this.
  3. Aug 3, 2016 at 1:38 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Thanks man! A nice little idea I had one day and just went with it and it works nicely!!!
  4. Aug 3, 2016 at 1:41 PM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    Those little ideas mean a lot for some of the members here. keep the thinking process going. Thank you!
    And that you to Uptown2k for making a thread for this mod.
    drvn, patkap41, Paultrd and 18 others like this.
  5. Aug 3, 2016 at 1:50 PM
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome Merel, anytime, that's why I'm here! :thumbsup:
  6. Aug 3, 2016 at 1:51 PM
    Uptown2k
    Jordan
    hopefuy the mods will make it a sticky thread so all new owners can address the issue as preventative maintenance
    igloolou, tpay, RC219 and 6 others like this.
  7. Aug 3, 2016 at 1:52 PM
    moe2o4
    Corey
    Pittsburgh PA
    Any chance we could get this in a Preventative Maintenance section? @MTgirl @sean266?
    outlawtacoma and ChadsPride like this.
  8. Aug 3, 2016 at 1:53 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    So these frames are rust prone?
  9. Aug 3, 2016 at 1:53 PM
    2016_dbag
    2016 POSTURD
    Great, now BlueT is gonna come back....
  10. Aug 3, 2016 at 1:54 PM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    The frame is treated but the welds will still rust.
    TRDSport10, maineah and smitty99 like this.
  11. Aug 3, 2016 at 2:01 PM
    Uptown2k
    Jordan
    Here's an after shot of same spot that was rusting
  12. Aug 3, 2016 at 2:32 PM
    moe2o4
    Corey
    Pittsburgh PA
  13. Aug 3, 2016 at 2:34 PM
    Uptown2k
    Jordan
    :thumbsup: Sweet I subd thanks again for the great idea
    moe2o4 likes this.
  14. Aug 3, 2016 at 2:37 PM
    moe2o4
    Corey
    Pittsburgh PA
    If I do anything to the truck it goes there!!!
  15. Aug 3, 2016 at 4:21 PM
    Norcali707
    Norcali707 Well-Known Member
    Rick
    Willits
    2016 MGM Tacoma 4WD Offroad DCLB
    Stock
    thanks for sharing with us... im sharin this tread in my FB group
    Uptown2k[OP] likes this.
  16. Aug 3, 2016 at 4:32 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    There's no coming back for BlueT!
  17. Aug 3, 2016 at 4:34 PM
    2016_dbag
    2016 POSTURD
    :rofl::rofl:
  18. Aug 3, 2016 at 5:32 PM
    Username:
    Username: I wear adult diapers at music festivals.
    CJ
    Pacific USA & Canada
    16 TRDS 6M w/ TRD Humidor
    "She's into malakas, Dino."
    nice post! kudos i say, kudos!
    Uptown2k[QUOTED][OP] likes this.
  19. Aug 3, 2016 at 5:35 PM
    2016_dbag
    2016 POSTURD
    @Uptown2k and @moe2o4 - thanks for giving me something to do while I drink beer in the garage on a Wednesday afternoon.
    Protip: Don't do this mod right after driving your truck. Unless you like molesting a hot exhaust pipe.
  20. Aug 3, 2016 at 5:48 PM
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome!
    Ya it's just a little hot after you drive it :rofl::rofl::rofl:
