Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Aug 3, 2016 at 6:37 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    *waves magic wand*
  2. Aug 3, 2016 at 6:43 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Thank you @MTgirl!!!! :thumbsup:
    MTgirl[QUOTED] likes this.
  3. Aug 3, 2016 at 6:59 PM
    moe2o4
    Corey
    Pittsburgh PA
    You got your wish @Uptown2k!!!
  4. Aug 3, 2016 at 7:01 PM
    Uptown2k
    Uptown2k [OP] Well-Known Member
    Jordan
    2016 MGM TRD OR DCSB4x4
    Good stuff @moe2o4 hopefully this can help other owners. Thanks @MTgirl :thumbsup:
    moe2o4 likes this.
  5. Aug 3, 2016 at 7:02 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I am amazed that that level of rust was there for just after 7 months from an ac drain. What will winter bring ?
    Would undercoating have helped ???
  6. Aug 3, 2016 at 7:05 PM
    Uptown2k
    Jordan
    Well I'm in FL so the a/c is on all the time if that makes you feel any better :der:
  7. Aug 3, 2016 at 7:06 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    I've done this mod too, and for winter I'm gonna fluid film the crap out of the underside before bad weather sets in.
    moe2o4 likes this.
  8. Aug 3, 2016 at 7:08 PM
    2016Tacoman
    J
    Rather than undercoat ?
    Rather than fluid film once a year ?
  9. Aug 3, 2016 at 7:11 PM
    Riding Dirty
    PlastiDip
    Several people on here don't recommend it because undercoats tend to flake off after a while and rust, water and salt stuff accelerates and hides rust. I also think it may void warranty. Fluid film can be cleaned off at the end of the season.
  10. Aug 3, 2016 at 7:12 PM
    2016Tacoman
    J
    How often do you do the fluid film ?
    I have had jeeps for 25 years (original jeeps not chryslers) that didn't show that level of rust.
  11. Aug 3, 2016 at 7:15 PM
    Riding Dirty
    PlastiDip
    This will be my first time using it, so from what I gathered from others on here, it may depend on where you live. For me, just once should last me all winter, but somewhere like the rust belt might need to do it a couple of times. Others on this forum said 4 cans do the entire truck just fine. It's safe for plastics and rubber, and can be removed when no longer needed.
  12. Aug 3, 2016 at 7:15 PM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    I think if you follow the OP's recommendation of using rust prevention paint and then following up with an undercoat product, it should seal the area sufficiently.
  13. Aug 3, 2016 at 7:23 PM
    2016Tacoman
    J
    I am worried about the rest of the under body now, not just the ac drain outlet.
  14. Aug 3, 2016 at 7:26 PM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    The frame is already coated. The same procedure would hold true for other areas of the frame. I used this method on my "02 Ford ranger and never had an issue. Call it a maintenance thing.
    Riding Dirty likes this.
  15. Aug 3, 2016 at 7:30 PM
    #35
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    While rigging this up on my truck, I was thinking it was a strange place that rusted in the pictures that @Uptown2k posted. The A/C drip is much further forward (and up) from the location shown in pics. The only thing I could think is that while driving the water from the drip hit the frame and traveled down to the rust spot.
    Uptown2k[OP] likes this.
  16. Aug 3, 2016 at 7:32 PM
    #36
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I did this mod early on just for peace of mind since I use the AC year round. Simple and effective!
  17. Aug 3, 2016 at 7:48 PM
    #37
    Uptown2k
    Jordan
    That's exactly what happens it runs down and gathers there while parked also doesn't have to be driving
    2016_dbag[QUOTED] likes this.
  18. Aug 3, 2016 at 7:53 PM
    #38
    2016_dbag
    2016 POSTURD
    Makes sense!
  19. Aug 6, 2016 at 7:16 PM
    #39
    yray
    yray Member
    2016 Tacoma TRD Sport Crew Cab
    Thanks for the heads up OP, I didn't get rust on my frame but there were some deposits.
    Went to NAPA to buy the hose and clamp, it was $6 all in. I routed my hose down the frame instead, I get kind of antsy when I put hoses or wiring near moving parts. Tested it on and off road, so far so good.
  20. Aug 6, 2016 at 7:22 PM
    #40
    Uptown2k
    Jordan
    Looks great!!
