Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Jul 29, 2019 at 1:46 PM
    #541
    montucky taco
    montucky taco Well-Known Member
    Blake
    Lehi, Utah
    2020 Quicksand TRD OR MT
    No kidding. Thanks
    KY_Rob likes this.
  2. Jul 29, 2019 at 2:15 PM
    #542
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    :rofl:
    Ya just never know around here...
    montucky taco[QUOTED] likes this.
  3. Jul 29, 2019 at 2:26 PM
    #543
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I had done this on my last Tacoma, but haven't yet on my 2019.... I guess because for North Texas we've had a relatively mild spring and summer (so far) and I haven't run the AC much. I'll get around to it along with the diff breather deal.
  4. Aug 1, 2019 at 12:11 PM
    #544
    blackmist27
    blackmist27 Well-Known Member
    17 Tacoma TRD Pro
    Leer shell 100XR
    Thanks for this write up... i will be doing this little mod today on my baby.
  5. Aug 5, 2019 at 3:26 PM
    #545
    staplegun
    staplegun Well-Known Member
    Thanks - THIS will be my next mod
  6. Aug 13, 2019 at 11:15 AM
    #546
    mrb1218
    mrb1218 Afterburner
    B
    Albuquerque
    19 Cement Tacoma MT DCSB || 18 White T4R ORP Non-KDSS
    By not owning the truck yet, this might sound stupid. Do you have to remove the passenger side wheel to have access? Can you just turn it? Also, how difficult is it to remove those 2 clips without breaking them? of course lol
    I am picking my 19 up next week and I am planning to do this mod as soon as I get it back to my place (4hr drive). Or did they extend the drain hose on the 19? I highly doubt it.
    KY_Rob likes this.
  7. Aug 13, 2019 at 11:25 AM
    #547
    KY_Rob
    Rob
    North East Ohio
    It’s easier to remove the wheel, but I guess you could just turn it all the way to the left.
    Removing the clips is a piece of cake. I used my $5 clip removal tool from Harbor Freight, but you can do the same thing with careful use of a flat head screw driver. They’re intended to be used as an access point, so they’re fairly robust.
    I spent more time gathering up and putting away tools than I did actually doing the mod.
    mrb1218[QUOTED] likes this.
  8. Aug 13, 2019 at 11:31 AM
    #548
    mrb1218
    mrb1218 Afterburner
    B
    Albuquerque
    If I were home, removing the wheel wouldn't be a problem as I've got the jack, impact gun and all the tools :yay:. But I will try turning the wheel all the way and see if I can do it. Thanks for the quick response
    KY_Rob[QUOTED] likes this.
  9. Aug 13, 2019 at 11:39 AM
    #549
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    I didn’t even turn my wheel and they are 33’s.. It was extremely easy just taking off the little cover that hides it and reaching around it. I also just twisted and pulled the clips by hand and they came out in one piece easily.
    CusterFan and mrb1218[QUOTED] like this.
  10. Aug 13, 2019 at 11:41 AM
    #550
    mrb1218
    mrb1218 Afterburner
    B
    Albuquerque
    I like it!
  11. Aug 13, 2019 at 11:48 AM
    #551
    NiH
    NiH Active Member
    I did this over the weekend, have any of you had any issues with the heater hose popping off the AC drain? Just curious as it was kind of a pain to get in there and since it's not see through I can't exactly tell how far in the hose went before I clamped it. So far so good for you guys?
  12. Aug 13, 2019 at 1:22 PM
    #552
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Wheel removal not needed or clips. I ran the hose from below and I reached over the top and attached the hose. I lubed the hose so it would go in easier then clamped it.
    CANVagent and mrb1218 like this.
  13. Aug 13, 2019 at 1:32 PM
    #553
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Exactly how I did it. With stock wheels and tires there's plenty of room with the wheel turned and easy access from under the hood.
  14. Aug 13, 2019 at 2:41 PM
    #554
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    If you do break one or 2 you can buy the push pin type at your local O'Reilly's. Or a body shop would probably sell you a couple.
  15. Sep 10, 2019 at 8:57 PM
    #555
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2021 Cement TRD OR DCSB
    Truxedo Pro X15 tonneau, front tinted windows
    So it's been a few years. What do your frames look like now?
  16. Sep 11, 2019 at 5:34 PM
    #556
    JayTRD88
    JayTRD88 Well-Known Member
    Jay
    19 Tacoma TRD Sport
    Was thinkin maybe just spraying some coating to protect where it drips, i dunno if i can trust a hose not getting clogged up or whatever. I usually wash my car once a week anyway (or try to at least,, depending on the weather) like a quick wash spray down, specially on winter times just to get the grimey snow off the truck...anybody live up north having not done this and hows the frame?
  17. Sep 12, 2019 at 9:44 PM
    #557
    JimmyoNY
    JimmyoNY Active Member
    Jim
    2019 Tacoma
    I've done this on other cars I've owed. It seems that a lot of cars just dump the a/c condensation out without regards for where it lands. My son has a 98 crv that rusted through the sub-frame right where the water dripped down over the years. I had to replace the sub-frame with one I got from the junk yard. it wasn't a fun job. I'll do the taco tomorrow.
  18. Sep 13, 2019 at 1:14 AM
    #558
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the forum from Eastern North Carolina.
    It's a simple, easy mod that anyone can do in a few minutes. I can't imagine why anyone would not do it.
  19. Sep 13, 2019 at 7:23 AM
    #559
    Tarvis
    Tarvis Well-Known Member
    Travis
    Bel Air, Maryland
    2018 Metallic Gray SR5 Double Cab
    Got this done on my 2018 with 7000 miles last night. I didn't like the way it torqued the heater hose going through the holes so I just zip tied it off in a different spot but the result is the same. Hopefully no issues with where I tied it off, but I'll check on it every once in a while. Great idea doing this... I didn't have any rust forming yet but it definitely would have happened.
  20. Sep 13, 2019 at 6:08 PM
    #560
    JimmyoNY
    Jim
    2019 Tacoma
    I'll probably do it tomorrow, I've done all my own work on all my cars for over 20 years. I'm pretty sure I can handle it. :thumbsup: Thanks, I'm up north in the land of snow and road salt, fighting rust is a year-round job.
    StayinStock likes this.
