Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Aug 4, 2020 at 7:53 PM
    #661
    Chip_311
    Chip_311 Well-Known Member
    Brian
    NJ
    2017 DCSB OR
    BFG KO2s Pro Grille Pro Skidplate Pro Fox Suspension DShackles F & R CaliRaised LED Bumper Baja designs S2pro / S1 CaliRasied Off-road Sliders Waterport R4T Arm Skids RCI Skids Weather tech Visor Front Camera SCS Wheels Rear Bumper Covers Maxtrax Recovery Meso Gas Hole/Turn Signals Pop n Lock Kit Extended Rear Breather Expedition Essentials TPAM Midland USA Comms Clazzio Leathers Victory 4x4 Mollie Garmin Tandem Mountain Hatch Bestop2 Thule Evo Rack
    Ran mine same way. Also did ext rear diff breather to behind taillight.
    C41n[QUOTED] likes this.
  2. Aug 12, 2020 at 7:07 AM
    #662
    TKitchTaco
    TKitchTaco Subs for work tacos for play
    Trent
    Jersey shore
    2020 AC SR SX super white
    Desert Does it Seat jackers LasFit LED headlight/taillight kit Plastidipped wheel emblems tailgate inserts
    Only 2k on my 2020 but went out and immediately bought the hose and clamp for this little mod. I'm currently leasing so I'm trying everything I can to keep the truck immaculate.
    Norsemanvike likes this.
  3. Aug 12, 2020 at 2:09 PM
    #663
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    So assume this is still a problem on 2020s? They didn't change/fix it? If so, guess I better go grab the stuff myself.
  4. Aug 12, 2020 at 2:11 PM
    #664
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    They did not change it. Did this mod with 7k on mine. No rust.
    deusxanime[QUOTED] likes this.
  5. Aug 12, 2020 at 2:13 PM
    #665
    deusxanime
    MN
    I've got about 300 on mine so far, so hopefully not an issue yet! Though since it is summer I've been running a/c pretty much everywhere I go.
  6. Aug 12, 2020 at 6:16 PM
    #666
    TKitchTaco
    Trent
    Jersey shore
    I noticed the other day, it was dripping onto the frame and rolling back about 4 inches behind the wheel well. Then went searching for a solution. Just did it this morning and it’s working well. Seems dumb that they poke it through towards the front end instead of routing it down and back from the factory
  7. Aug 13, 2020 at 6:42 PM
    #667
    fryrice
    fryrice Well-Known Member
    MA
    2020 MG Access Cab SR w/ SX pkg
    Wow glad I found this. Just picked up my 2020 and just added the 5/8 heater hose and got some clamps. With only 200miles on the truck, this is def the first mod.
    Thanks!
    Norsemanvike and C41n like this.
  8. Aug 14, 2020 at 8:01 PM
    #668
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    The Tacoma A/C drain tube has been this way forever. They must not think it's a big deal enough to change it because my '99 has the exact same drain as my '17.
    RCrumb and DAS Taco like this.
  9. Aug 18, 2020 at 7:52 AM
    #669
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Where exactly under the vehicle is this ?...is is easily accessible/visible?, thanks
  10. Aug 18, 2020 at 8:22 AM
    #670
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    First post has photos. The AC hose is behind the black flap on the passenger side wheel well. Its easier to access if you turn the passenger wheel to the left.
    DSRamsey13 likes this.
  11. Aug 18, 2020 at 11:54 AM
    #671
    deusxanime
    MN
    Well you can just open your hood and look down the firewall on the passenger side if you want to see it. Now actually doing the mod, pulling the flap off might be helpful, but if you just want to see to get an idea, just pop the hood.
    BSFord and DAS Taco[QUOTED] like this.
  12. Aug 18, 2020 at 12:33 PM
    #672
    DAS Taco
    DAS
    2017 TRD Offroad
    Thanks guys
    StayinStock likes this.
  13. Sep 7, 2020 at 5:46 AM
    #673
    TheLegend105
    TheLegend105 New Member
    Tim
    Central MS
    17 Tacoma TRD Sport
    Stock truck for now.
    New 3rdGen owner here, traveled to Nashville TN from central MS Last week to get a super clean 17 with 55000 miles on her. Did this mod last night after replacing the O-Rings on the Vacuum pump.
    Thanks for the write up, my first mod on the new truck, thankfully/surprisingly there was no rust that I could see.
    Side-Note
    Noticed a small oil leak after getting it home and after investigating further located the source, bad O-Ring on the vacuum pump from a previous repair of the emissions system. Tight work space but with some good help and a few choice words it’s something anyone with a little know how and mechanical aptitude can replace, saving a trip to the dealer and being without your Trk for who knows how long.
  14. Sep 7, 2020 at 10:36 AM
    #674
    QwickC
    QwickC Well-Known Member
    OH
    2017 Silver Tacoma TRD OR
    Thanks for the tip, just picked up 17 OR, did this fix today.
  15. Sep 10, 2020 at 1:38 PM
    #675
    Bigkracka
    Bigkracka Well-Known Member
    Tx
    20 Tacoma SR5 Crew Cab V6
    Did the ac mod to my 20 few days ago, thanks for posting. Doing the differential mod this weekend.
  16. Sep 11, 2020 at 8:31 PM
    #676
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Is the heater hose recommended due to being able to handle heat better, or was it just suggested because it happened to work?
  17. Sep 11, 2020 at 8:31 PM
    #677
    RedWings44
    Michigan
    What is the differential mod?
    deusxanime likes this.
  18. Sep 11, 2020 at 8:59 PM
    #678
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I believe this is the thread?
    I haven’t done mine yet. Because no rain here. Ever. And no water crossing. And I don’t drive anywhere anymore. But someday. Because? Why not.
  19. Sep 12, 2020 at 11:15 AM
    #679
    Bigkracka
    Tx
    Yep that thread. Glad I did mine cause when I pulled the original breather I heard a good bit of compressed air or vaccum. Maybe the original was defective? Checked the new one and got it installed.
  20. Sep 12, 2020 at 2:57 PM
    #680
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Yep, same here when I took mine out but I couldn't tell if it was sucking air in or pressure out. Either way, its a worthwhile mod due to pressure/vacuum in the diff at all times regardless if you wheel through water or not.
    daveeasa likes this.
