Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Feb 24, 2021 at 7:32 PM
    #741
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    that catalytic converter, looks like a silver football, gets super hot, so make sure you try and keep the hose as far away from it as possible.
  2. Apr 7, 2021 at 1:07 AM
    #742
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    I just finished mine. I used a clamp and the 5/8 heater hose, hose is really short and I intentionally wanted it to have a more downward angle to make sure it drains. I just ran it straight down behind and in between the splashguard flap that has the 2 snaps close together. Video was about 2 minutes in to starting the truck. After trimming the hose at the angle I left it, water started draining out before even starting up.
    https://www.youtube.com/watch?v=Gkno2yHky34
  3. Apr 13, 2021 at 9:17 AM
    #743
    nickerhunter
    nickerhunter New Member
    2020 White TRD Offroad
    Does this problem still apply to the 2020 Tacomas? You would think Toyota woulda fixed it by now... and I don't want to read through all the posts. Thanks!
  4. Apr 13, 2021 at 9:40 AM
    #744
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Yes.
    massac78 likes this.
  5. Apr 13, 2021 at 12:58 PM
    #745
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Most likely Toyota will never "fix" the problem since they do not see it as a problem at all. o_O:annoyed:
    JJ Diablo, SandyTaco4x4 and massac78 like this.
  6. Apr 13, 2021 at 4:08 PM
    #746
    Great Dane
    Great Dane Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    Yeah, it does. I did the mod on my 2021 before I started driving it.
  7. Apr 13, 2021 at 4:18 PM
    #747
    Steve Armstrong
    Steve Armstrong Well-Known Member
    SoCal
    2021 TRD Sport DCSB
  8. Apr 15, 2021 at 11:07 AM
    #748
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Thanks for the picture showing the size 5/8 heater hose.
  9. Apr 16, 2021 at 8:49 AM
    #749
    tacopeter
    tacopeter My truck isn't modded. It's well optioned.
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    Doing this tomorrow! Only have ~700 miles on the truck but you all have me paranoid :rofl:
    Norsemanvike likes this.
  10. Apr 16, 2021 at 9:15 AM
    #750
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Just did this last night on my 21 TRD OR. The ac drain hose kept moving in and out of the fire wall as I was fitting heater hose over it. It had quite a bit of play in terms of in and out of the fw. Anyone experience this and should I be concerned?
  11. Apr 18, 2021 at 10:26 AM
    #751
    tacopeter
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    Yes, mine is the same. There should be a white line as a guide point as to where the hose should be to the firewall (I could be wrong) but the 5/8 house slides over it and held together by the clamp. Yours should look like mine.
    DSRamsey13 likes this.
  12. Apr 26, 2021 at 1:37 PM
    #752
    JDS428623
    JDS428623 Well-Known Member
    TRD OFF-ROAD Magnetic Grey 4door long bed
    It’s distilled water will it really rust? I did it as preventative but was doubtful it help anything
    JJ Diablo likes this.
  13. Apr 26, 2021 at 1:48 PM
    #753
    Otto-x
    Otto-x Well-Known Member
    Seattle, WA
    2021 Cement DCLB OR
    JDS428623 likes this.
  14. May 7, 2021 at 4:11 PM
    #754
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Put the 2ft 5/8 heater hose over the existing 4” drain. Put the hose clamp and ran it through the frame and tie wrapped it. Thank you to the people who pointed out this to us. FYI. Took 5 minutes
  15. May 10, 2021 at 5:06 PM
    #755
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    Did my mod yesterday...hardest part was getting those plastic rivets out. I ended up turning a Joe's Crab Shack peeler into a trim tool.
  16. May 17, 2021 at 8:17 AM
    #756
    troutarebeautiful
    troutarebeautiful Well-Known Member
    2021 Army Green TRD Sport AC/MT
    • Just did this mod. Thank you!
  17. May 27, 2021 at 7:35 PM
    #757
    Magiriano
    Magiriano Underdog by Doekter TUNED
    Alex
    Calgary, Alberta
    2022 4Runner TRD PRO 2023 Tacoma TRD PRO MT
    Westcott Front lift with Eibach Pro Coils, Icon AAL rear, 17" Rims on 285/70/17 Toyo Open Country AT3 Load Range E, Full PPF Clear Wrap, Diff breater relocation, Greenlane Offroad Stump Bumper, Greenlane Offroad full engine skidplate, Greenlane Offroad Transmission Skidplate, RA Motorsports Gas Tank Skidplate, DEFA Trickle Charger with Cab Heater, CBI DOM 120 Rock Sliders, Greenland Offroad cab height Box Rack, Sherpa Roof Rack with Baja Designs S8 Lightbar, Tailgate lock, Underdog Tune by Doekter TUNED
    Thank you kindly for the write up.
  18. Jun 1, 2021 at 5:10 AM
    #758
    Flatulator
    Flatulator Active Member
    2020 Voodoo Blue Tacoma TRD Off Road DCLB
    Dumb question: Is there any worry about having the extended hose length during the winter/cold weather? Has any one had any problems with that?
  19. Jun 1, 2021 at 5:20 AM
    #759
    Norsemanvike
    Escondido, CA
    None whatsoever. Just make sure that the hose is always pointing downward when you install it.
  20. Jun 10, 2021 at 2:15 PM
    #760
    TacoMan47
    TacoMan47 Member
    2021 MGM Tacoma SR V6 4x4
    Did Toyota change anything for 2021? I’m trying to follow OP’s routing, but he states to use “2nd hole” in the pictures. My 2021 SR only has 1. Any help would be appreciated.
