Rust on Frame with A/C drain mod fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Uptown2k, Aug 3, 2016.
  1. Aug 9, 2021 at 9:19 AM
    #801
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    So when you do this mod do you have to jack up the truck and remove the tire or is there enough access if you turn the wheel?
  2. Aug 9, 2021 at 10:20 AM
    #802
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Tons of access, it was my first mod, I'm not mechanically experienced with autos in any way, from what I know of your skills, Mike, you'll be done before the first beer. Hardest part is deciding exactly what color and length of zip tie to use.
    I will add, though, that I avoided them for a long time but when doing my diff fluid I finally bought some rhino ramps. They are just right for getting a bit more space under the front or back of the truck as needed. Definitely not necessary but certainly nice to have.
  3. Aug 9, 2021 at 11:14 AM
    #803
    Taco_mike73
    York, PA
    Nice I have an old set of metal ramps I use for oil changes. That should work. Weather resistant Ties only come in black so that's a simple decision.
    daveeasa[QUOTED] likes this.
  4. Aug 9, 2021 at 3:47 PM
    #804
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Out of curiosity, when you did your diff fluid using your ramps did you have the truck level ?
    In other words if the front was up on ramps, was the rear raised up to the same height ?
  5. Aug 9, 2021 at 4:31 PM
    #805
    daveeasa
    David
    PNW
    My driveway is sloped to the point that the ramps made my truck close to level.
    However I did most of the changes with the nose / arse hanging just outside the garage door. Only the last rear diff topoff was with the ramps.
    JJ Diablo[QUOTED] likes this.
  6. Aug 31, 2021 at 4:24 PM
    #806
    Bob Jr
    Bob Jr Member
    Robert
    Southern NJ
    2019 Tacoma SR Access Cab
    installed rear speakers, 2" tow receiver
    As many know the AC condensate hose drips onto the frame. I've seen many versions of this mod but thought I'd share my experience in completing this mod.
    I used a 5/8" ID clear reinforced tubing, it's what I had. Videos I watched said to watch you do not crush the stock tube when tightening. This gave me an idea. I've used brass sleeve bushings on plastic pipe being used on compression fittings. I bought a 7/16" sleeve at a local hardware store for $1.89
    [​IMG][​IMG]
    I used this inside the end of the stock drip tube to keep the tube from collapsing when I tightened the hose clamp around the extension hose. It was a snug fit but that's what you want.
    [​IMG] [​IMG]
    Once the sleeve was in the tube, I had to heat the extension tube to flare the end a bit so it would fit easier over the stock tube. I used a propane torch and and a pair of long nose pliers to stretch the 5/8" ID tube slightly. Once this was done, the new tube fit over the stock tube. The hose clamp was placed so that it was over the area of the brass sleeve and tightened.
    The hose was routed through the brake hard line loop. I fastened it to the hard line with a zip tie. I used a heat gun to soften the tube so I could form it to the shape I wanted. I ran it on the outside of the frame as shown. I installed a hose / cable clamp with rubber insert to hold the end of the new drip hose.
    To fasten the clamp I used a 1/8" x 1/2" hex head self drilling screw into the frame. The hole was drilled and sprayed with undercoating before and after the installation of the clamp. Hose was cut below the frame to finish the job.
    Here is the final end result.
    I know it's a bit long winded but anytime someone has an idea, it pays to read several listings on it and it helps you form your own conclusion and sometimes improve on the idea.
  7. Aug 31, 2021 at 4:29 PM
    #807
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I normally go over areas that I see rust developing with some good ole Rustoleum and move on!
    I'm sure a bit of water dripping from the AC hose isn't any worse than driving in the rain or in puddles.
    CusterFan and JJ Diablo like this.
  8. Aug 31, 2021 at 4:40 PM
    #808
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    These people should be more worried about driving around in acid rain or through salted or brined roads, instead they are worried about pretty clean condensed water, that’s better than the drinking water in third world countries.
    Maybe we should tell them that driving around in the rain or having your truck outside in a rain storm is doing more harm to their frames than the drain tube is. :violent:
    Williston and JJ Diablo like this.
  9. Aug 31, 2021 at 6:08 PM
    #809
    Otto-x
    Otto-x Well-Known Member
    Seattle, WA
    2021 Cement DCLB OR
    that brass adapter is a great idea
  10. Aug 31, 2021 at 6:52 PM
    #810
    JJ Diablo
    JJ.
    CT
    That part certainly is pretty ingenious , and extending the hose may keep ac drips off frame when parked. But how does this help when you are driving? Water is still going to splash all over the frame the same as the stock drain. The moving air pressure assures that. Am I missing something?
  11. Aug 31, 2021 at 8:44 PM
    #811
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    The drain can drip water for quite a bit after you stop driving. With the stock drain it will just pool on top of the frame and sit there. Sure it may eventually evaporate, but if you're in a humid climate that may take a while. With the drain mod, any water that blows around on the undercarriage is also being blown off or more quickly evaporated with the airflow from driving. The undercarriage is much less enclosed than the stock drain area. FWIW, after I did the mod I checked around underneath the first few times after driving and didn't see any residual water on the undercarriage.
    JJ Diablo likes this.
  12. Aug 31, 2021 at 10:08 PM
    #812
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Also when you’re driving the hot exhaust system is right there inches away and it’s a drip hose not a garden hose so “splashing” might be more like light spatter spread over a larger area, some of which is SS , some painted underbody, and yes some frame but much less concentrated than before the mod.
  13. Sep 6, 2021 at 2:16 PM
    #813
    MidnightWizard17
    MidnightWizard17 Well-Known Member
    Ben
    Grand Rapids, MI
    2023 Subaru Ascent Touring *sadface*
    Core short-throw shifter, w/custom weighted knob. MESO side markers, Victory 4x4 roof rack.
    There's overkill and then there's this guy :D looks clean though!
  14. Oct 11, 2021 at 8:31 AM
    #814
    hotrodder636
    hotrodder636 Well-Known Member
    2020 Tacoma TRD Pro (MGM)
    Used this idea to extend my drain line past the frame rail. Not as fancy but it works. Used a modified .45ACP casing as the ferrule. Tygon tubing connected to the factory line then run down rail and zip-tied in place. Will eventually get the black hose as it should last longer than tygon.
  15. Nov 2, 2021 at 1:47 PM
    #815
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    This is why you do the mod.
    Montana_Actual and BOMBS like this.
  16. Nov 2, 2021 at 9:35 PM
    #816
    jfitts23
    jfitts23 jfitts23
    Jeremiah
    NC
    2021 Tacoma TRD OffRoad
    about to do mine. there is a puddle under my truck like that every time i park.
  17. Nov 2, 2021 at 10:16 PM
    #817
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    TacomaONT, Taco_mike73 and BOMBS like this.
  18. Nov 3, 2021 at 3:14 PM
    #818
    Azza2
    Azza2 Well-Known Member
    Yass
    AZ
    2021 TRD OR
    Looking into this mod, would spraying that part of the frame with undercoating serve the same purpose?
    Leaguer4 likes this.
  19. Nov 4, 2021 at 7:48 AM
    #819
    Taco_mike73
    York, PA
    I did this mod the other week when I reapplied fluid film. I really liked the brass insert idea but I wasn't able to find it at my local Lowe's. None of the old guys were working in plumbing that day and you can't ask the kids anything hard.
  20. Nov 4, 2021 at 7:49 AM
    #820
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    Yes, that's what I've done and it works without issue. Just make sure you have decent coverage.
    BOMBS and Azza2[QUOTED] like this.
