Rust particles in coolant?
Discussion in 'General Automotive' started by bobwilson1977, May 26, 2009.
  1. May 26, 2009 at 9:23 AM
    bobwilson1977
    bobwilson1977 [OP] Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I'm kind of OCD when it comes to truck maintenance. I always change the oil every 3,000 miles and the coolant every 50,000, or two years. I changed both yesterday. I've been using Long life, 150,000 mile coolant. The coolant looked pretty clean coming out, but when I flushed the radiator/engine, there was actually a little more rust and crap coming out the bottom than I've seen in the past. I usually do a 70% coolant, 30% water mixture so there shouldn't be much if any corrosion going on in there.
  2. May 26, 2009 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    That would be expected on a 13 year old truck.
  3. May 26, 2009 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. No biggie.
  4. May 26, 2009 at 9:48 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    that is one thing I have been meaning to look up how to do. I'm OCD on maintenance as well. My dad doesn't like it and told me the differential oil changes, tranny oil etc was a waste of money. I said "Coming from the guy whose dodge broke a front axel, driveshaft, and front wheel bearing (amongst other thing) arounf 60k"
