S mode shifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kpinks, Mar 5, 2018.
  1. Mar 5, 2018 at 6:50 AM
    kpinks
    kpinks [OP] Well-Known Member
    Kevin
    Ottawa, Canada
    Tacoma TRD Offroad
    I am used to driving a stick, but I got a auto this time as my wife cannot drive a standard. My new Tacoma has the "S" mode where you can upshift and downshift. Is anybody familiar with these "S" mode shifting? I read what there is in the manual. So if I am driving 100 km/hr, can I just slip it from "D" to "S" mode to gear down or do I have to be stopped in order to put it in S" mode?
    Thanks
  2. Mar 5, 2018 at 6:51 AM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    You can use it on the fly, do not have to be stopped
    Dirty Harry likes this.
  3. Mar 5, 2018 at 6:51 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    just slap it over and its in 4th gear
    Kilokato likes this.
  4. Mar 5, 2018 at 6:57 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I use it ALL the time. When you learn it, you can drive your truck pretty much like you would drive the stick. S mode limits the trans to the highest gear that can be shifted into. So, in S-4 the trans will go from 1 to 4 but no higher. In S-1, it will stay in 1st. When I leave my steep down driveway, I'm in 1st. The same as I would be with a stick. When it levels out, I shift to 2nd etc. I have always used S mode for down shifts at stops. (2nd gen, and this one). I use ECT always if I will not be going over 60 MPH. I live in the country, with plenty of curvy back roads. It does better in those circumstances. I consistantly get 18 21 MPG. You do not need to be stopped to use it. Just shift away.
    Hope that helps.
    G.
  5. Mar 5, 2018 at 7:01 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    It would be nice if it showed what gear it was in. A lot of people get confused by seeing the 4. Even reviewers online think the truck is always in 4th gear, which it isn't. Also a lot of people think S stands for sport mode.
    Canadian Caber, NWTacoTime and DHerrm like this.
  6. Mar 5, 2018 at 7:03 AM
    Garyji
    Gary
    It does show what gear you are in. If you move the stick down once, it will be a "3".
    G.
    Dryfly24 and Kilokato like this.
  7. Mar 5, 2018 at 7:04 AM
    mootiger49
    its in 4th till you shift it.............
  8. Mar 5, 2018 at 7:08 AM
    Flyinbrianbmx
    Flyinbrianbmx Well-Known Member
    2016 Blue Tacoma SR5 Rockstar
    it's actually a gear limiter, so if you have it on 4 the truck will automatically shift 1,2,3,4 but not go higher than 4.
  9. Mar 5, 2018 at 7:10 AM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    By default yes but you can manually select first gear at every stop.
    This sort of thing is more of a gear range limiter though. You set what gear you want to be the highest and it will not upshift past that.
    Or you could try to use it like a tiptronic but it doesn't really work all that well.
  10. Mar 5, 2018 at 7:14 AM
    Garyji
    Gary
    Also, for those that would like to see the actual gear the trans is in at any time, you will have to "learn" your truck and then it's simple to compare the tach and speedo and know exactly what gear it's in.
    G.
    Jason2108 and rlj251 like this.
  11. Mar 5, 2018 at 7:40 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You could monitor it with a ELM327 and Fusion App with the enhanced PIDs.
    bshammer0 likes this.
  12. Mar 5, 2018 at 7:56 AM
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    Mine goes to 5th and 6th in the S mode. :thumbsup:
    old man 895 likes this.
  13. Mar 5, 2018 at 8:37 AM
    greengs
    AB, Canada
    What I mean is if you move it to S and it shows 4. It will show 4 if you don't touch it again, but the truck will shift to 3,2,1 as you slow down and stop all the while displaying 4.
    Not exactly, that's what I mean by confusion. It will go thought 1-4 even if you don't shift anything. You can be at a stop light and shift to 5. Truck is still in 1st gear though. It will shift through 1-5 as you start to move but all the while it will display 5 in the dash.
    Kilokato and Teegs like this.
  14. Mar 5, 2018 at 11:45 AM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    Apparently it's not really "manual mode." What I mean by this is, gear one allows you to use the 1st gear, gear two allows you to use the 1st AND 2nd gear, gear three allows you to use the 1st, 2nd AND 3rd gear, and so and so forth. I thought this was strange, because essentially in "Gear 6" you are driving in your normal D/automatic mode, being that if you floor it, the transmission WILL downshift for you while still maintaining your "6th gear icon." Someone please correct me if I'm wrong. I personally liked using the 6th gear (leaving it in 6th gear) when I first noticed my transmission "starting to learn my driving habits" because it was blowing balls in my opinion. Since then, however, I've learned to embrace the stock automatic transmission, and it actually has become fun to drive it, on top of saving gas. i average 21 mpg whether its a mix of highway and town driving, or any other variation.
  15. Mar 5, 2018 at 11:50 AM
    Julian
    Julian 92yota
    Julian
    Inland Empire, CA
    1992 Toyota Pickup DLX V6 Manual 4WD
    |• 255/80/R17 Toyo R/T Tires on 2nd Gen Tacoma Sport wheels| |•Bilstein 4600 Series Shocks|
    the manual mode and the ect power button together really help out the power out well.
  16. Mar 5, 2018 at 11:55 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    I keep my in S4 around town and S5 on the freeway. All with the ECT button on. Haven't noticed a measurable hit to fuel economy.
    You're basically killing the overdrive gears when you do this. Easiest way to stop the quick upshifts everyone bitches about.
    Mooseditty9 likes this.
  17. Mar 5, 2018 at 11:57 AM
    strktly_bodysurf
    By "killing" do you mean just taking them out of the equation, or do you mean you are ruining them?
    serious question
  18. Mar 5, 2018 at 12:01 PM
    skiploder
    FZJ80/XJ LS swap
    :thumbsup:
  19. Mar 6, 2018 at 8:23 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Using this method really livens up the truck.
    taco woodeye likes this.
  20. Mar 6, 2018 at 9:13 AM
    wedgefry
    wedgefry Active Member
    Jordon
    Vancouver, Canada
    2017 Tacoma TRD Off Road DCSB
    So it's not really an manual, but like others are saying it's just a gear range limiter?
    I was under the impression I would shift into S then start up or down shifting like a traditional manual transmission. I'm still a little confused lol
