Safari vs Airflow Snorkels
Discussion in 'Performance and Tuning' started by Frogsauce, Jun 18, 2013.
  1. Jun 23, 2013 at 7:52 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Sub'd. Trying to decide between the two also.
  2. Jun 24, 2013 at 6:52 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    stuck doing this on the side of the road drying everything out because the snow packs in the hood. when enough packs in the hood, the rest will drop down into the tubing. once the water builds up enough it'll get sucked into the filter. when the filter gets saturated enough it'll start sucking water in toward the engine soaking the MAF sensor. and a wet MAF is an unhappy MAF :(
    eventually disconnected the tube and ran a while so the rest of the water would get pushed out of the tube and not in my filter
    you could turn the hood backwards but when driving at highway speeds you run the risk of creating a nasty vacuum that could damage the engine (debatable, but i don't want to run that risk)
  3. Jun 24, 2013 at 7:13 AM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I'm assuming the safari has the same heavy snow issue?
    Sounds like a donalson is preferred for heavy snow and dust.
    Another thing I thought about was it catching on tree limbs. Just have to drive carefully I guess. Or use limb risers that attach somewhere above the top of the snorkel.
  4. Jun 24, 2013 at 7:22 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    when wheeling, that is another reason why people turn their hoods around backwards. the branches will roll over them easier. in the bush, it'll prevent leaves and what not from getting in there as well
  5. Jun 24, 2013 at 7:36 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I think if I went with either of them I would cut them a bit shorter.
    Also, I'm forgetful, so I would probably wire myself up a dash light as a reminder that it is turned around.
  6. Jun 24, 2013 at 7:41 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Welp...that just convinced me.
  7. Jun 24, 2013 at 8:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The airflow comes with warnings all over it that turning it backwards at speeds greater than 15mph can cause damage...
  8. Jun 24, 2013 at 8:05 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    ^this
  9. Jun 24, 2013 at 8:14 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Yeah, that's why I would probably wire up a dash light. Run it off the seat belt warning chime power since that starts going off for me around 15 mph. All speculation at this point, but I would have to do something.
  10. Jun 24, 2013 at 8:38 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Which Donaldson did you go with?? I'm looking at the flow rates for the TopSpin and I think that's the one I want but I'm not sure.
  11. Jun 24, 2013 at 8:53 AM
    hcoulby
    hcoulby Well-Known Member
    Barry
    Baltimore
    TRD Off Road
    I find it kind of funny that a snorkel lets you cross rivers but not winters. Surprised there is no add on we can do for it?
    Would we have the same problem in heavy rains traveling at speed?
  12. Jun 24, 2013 at 9:03 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yup. Read up above and you'll see that you need a Donaldson hood for the snorkel and you're ready to rock.
  13. Jun 24, 2013 at 9:04 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    10" w/ 3.75" inlet
    sierra expedition part # PBH000254
    donalson part # H000821
    Rated Flow HR: 330 CFM (9.34 CMM)
    Camel51 and DistortedAxis like this.
  14. Jun 24, 2013 at 9:09 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    these hoods are designed to have the water drain out the sides of the hood. so when most water/rain hits inside of the hood, it will hit the walls and exit through some channels. both safari and airflow have these designs.
    so under normal situations, the water never gets in the tube.
    the issue i had was with the wet snow that accumulated in the back of the hood blocking those channels and the only place for the snow to go to was to fall/melt into the tube.
    so it definitely varies depending on the severity of the weather you're dealing with and the type snow/rain
    Camel51 likes this.
  15. Jun 24, 2013 at 9:10 AM
    #35
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]All Safari Charge Air Rams feature a highly effective water separator system built right into the air ram in order to remove rain water from the incoming air stream - thus ensuring safe engine operation through[​IMG] even the most torrential tropical storms.[/FONT]
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]An added benefit of the unique Safari Charge Air Ram is that it can be rotated to any position. This means great peace of mind for those who plan to travel in cold or high altitude conditions where heavy snow falls are anticipated. By rotating the air ram to face away from the prevailing wind/direction of motion, the air ram delivers additional protection from the choking effects of snow build-up inside the air intake.[/FONT]
  16. Jun 24, 2013 at 9:13 AM
    #36
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    airflow:
    The Air Ram
    Air entering the Air Ram swirls violently, creating a cyclonic effect. The heaviest particles are ejected by the centrifugal force to the periphery of the swirl. There, they hit the vertical ribs where air pressure takes over to eject them out of the four slots at the base of the Air Ram. At this point, the air pressure pushes them out. The finer particles that are not ejected are removed by the vehicle air filter.
    Comparison: not all Air Rams are equal in performance.
    It is preferable for the Air Ram to have an open face without a screen because the screen deflects the airflow. The surface ratio of the open face to outlet aperture must be a minimum of 1.4:1. If the ratio is lesser, it will be insufficient to create the cyclone action that separates heavy contaminants effectively. Approximately 30% of the incoming airflow (above 25kph / 15mph) is used in the separation process. At Airflow, we ensure that the Airflow range uses a minimum of 1.4:1 for the 3” air ram, 1.7:1 for the 3.5” air ram and 2:1 for the cold air induction air ram. Any deflection of the incoming airflow must be avoided since it dramatically affects efficiency.
    Deflections may be caused by:
    1-Air Ram situated in close proximity to the bonnet/hood of the vehicle,
    2- Air Ram with a curved or foiled roof,
    3- Turning Air Ram away from travel direction,
    4-Where Air Ram design makes the air go back on itself at an angle greater than 100 degrees.
    If the Air Ram is turned away from the direction of travel, it will lessen the necessary positive pressure. In extreme situations, at higher speed, a vacuum may be generated causing irreversible engine damage! Incorrect Air Ram design may cause excessive induction noise, lack of separation and air blocking by vortex at various speeds. This air blocking will limit airflow. This is a common occurrence when “looks” take priority over functionality. If the Air Ram is moulded on the body of the snorkel (for aesthetic reasons) it does not provide particle separation, thus all contaminants need to be removed by the internal air filter. This increases the maintenance cycle of the air cleaner. Furthermore, this configuration may cause a vacuum into the snorkel, thus increasing the risk of engine damage.
  17. Jun 25, 2013 at 5:32 AM
    #37
    hcoulby
    Barry
    Baltimore
    TRD Off Road
    It was tongue and cheek. I have read a lot about them and understand their purpose and limitations. I am just surprised by the heavy snow.
  18. Jun 25, 2013 at 7:12 AM
    #38
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Don't get that argument started. Everyone has an opinion, but it really boils down to what you want to do with your own truck and if you want to deal with the consequences of those actions.
    Let's get back to comparing the two companies...
    So it seems like the consensus is that:
    1. Airflow is easier to install (since it's made for Tacoma)
    2. Airflow may need a donaldson for heavy snow/dust
    3. Airflow has 4" diameter tubing (larger than stock).
    4. Safari is proven, Airflow is a bit new
    Any safari owners out there also have issues with heavy snow?
    Also, what was the diameter of the tubing on the Safari?
  19. Jun 26, 2013 at 7:15 AM
    #39
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    5. Safari states you can reverse the direction of the head without causing vacuum damage
    i wonder if that's because the top of the hood actually curves down before the opening...versus the airflow hood curves up to the top without curving back down before the opening?
  20. Jun 26, 2013 at 7:19 AM
    #40
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Looks like 3" to 3.5".
    Anyone with a safari having issues with heavy snow or dust
