Safe lift kit Pro Comp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mudthedoor, Feb 20, 2011.
  1. Feb 20, 2011 at 9:04 PM
    mudthedoor
    mudthedoor [OP] Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Im looking at a 3 inch pro comp lift kit and want to know if there would be any problems associated with the shorter lift kits. When i say shorter i mean lifts that use blocks and front spacers on the standard shocks instead of new coil-overs? Would i have problems with the CV or ball joints if i don't have somthing done like a front dif drop? \
    Thanks!
    edit:
    TheKit that I am looking at is the the shock and spring kit in comparison to the spacer lift kit. To see if the shock an spring kit is as potentially damaging to the truck has the spacer lift kit
  2. Feb 20, 2011 at 9:05 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
  3. Feb 20, 2011 at 9:05 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I've gotten sore tired of typing up the negatives of spacer lifts that now I just quote this from the Camburg website.:
    Also diff drops have shown to have almost no impact on CV angles of 2nd gens.
  4. Feb 20, 2011 at 9:10 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    well there ya go.
  5. Feb 20, 2011 at 9:13 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Ok well seeing how this isn't a spacer lift does all that still apply?:confused:
  6. Feb 20, 2011 at 9:17 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
  7. Feb 20, 2011 at 9:17 PM
    TexasTacoma37
    :confused: Your OP asked about spacer lifts....
    I wouldn't recommend the procomp shock/spring kit, but there are plenty of people on here who have it. It's been noted to be a pretty harsh ride.
  8. Feb 20, 2011 at 9:18 PM
    TexasTacoma37
    It's been 5 minutes....calm down there bud.
  9. Feb 20, 2011 at 9:33 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Good call I should have made it clear that I meant the shock and spring kit.
  10. Feb 20, 2011 at 10:17 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    You already know what im gonna say, GO FOR IT!!!
  11. Feb 21, 2011 at 12:28 AM
    tacoman007
    tacoman007 ignorance is bliss,
    Josh
    san diego
    07SR5ACCESSCABDEBAGED4X4
    alpine headunit,12'' rockford fosgate sub,ipod in g-box,drop in K&N, Marine decor,5100's front/rear,uniden pc68xl,radioshack PA speaker
    i like those trees in the backround!
  12. Feb 21, 2011 at 5:25 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    Hey thats a good price. I wonder how this front setup is compared to 5100's/OME springs?
  13. Feb 21, 2011 at 6:56 AM
    TexasTacoma37
    The shocks are of poorer quality. ProComps shocks are twin-tube while Bilstein and OME are monotube.
  14. Feb 21, 2011 at 8:55 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  15. Feb 21, 2011 at 9:02 AM
    tacoman85
    tacoman85 Active Member
    Erik
    Fort Worth, TX
    White TRD PRO
    I would go with ARB old man emu 3"
  16. Feb 21, 2011 at 9:08 AM
    socal4x
    socal4x Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    Bilstein=much better shock.
    However, if used with stock coils, you are preloading the coil, depending upon which level of lift you choose, so that can make the ride harsh.
    I have 5100s at 1.75, with stock coils, and I am happy. I had OME coils with 5100s at stock height, and found the OMEs to be much more firm.
    What I am wondering is whether or not that rear add-a-leaf in the ProComp kit is with or without rear tsb?
  17. Feb 21, 2011 at 9:26 AM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Without
  18. Feb 21, 2011 at 8:05 PM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Thanks for all the input guys.
  19. Feb 21, 2011 at 8:29 PM
    Blacktacoma23
    CO
    I dont think Pro Comp is as bad as everyone else on TW says
  20. Feb 21, 2011 at 8:30 PM
    Blacktacoma23
    CO
    X2
