Safe Tread Depth for Snow and Winter??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mbrogz3000, Dec 13, 2017.
  1. Dec 14, 2017 at 8:08 AM
    Muddinfun
    Muddinfun Well-Known Member
    I put studded snow tires on my TRD OR wheels. At the 1st hint of snow or ice, I am going put them on the truck. After the snow is gone, I'll pull them back off. That way I'm not wearing out the studs and if I slide into a curb, in the snow, I don't destroy a $250 TRD beadlock wheel.
  2. Dec 14, 2017 at 8:19 AM
    Pigpen
    Dan
    Northwest Montana
    I sipe and stud my new tires. I run them in winter only until they wear past the siping. Then I pull the studs and they are summer tires. I buy a new set, and repeat the process. I just switched from Toyo M55 to Dean Backcountry MT.
  3. Dec 14, 2017 at 8:45 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If I were you I’d be getting new tires.
    Your asking an overly complex question that doesn’t have the same answer for all types of tires. You run highway tires not A/Ts or MTs which would probably do better with more treadwear in the snow.
  4. Dec 14, 2017 at 11:38 AM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    These trucks are just so light in the rear cuz of the composite box. I drive in winter conditions 6 months of the year and let me tell u, after using studded winter tires for 6 years now I would never consider not using them.
  5. Dec 14, 2017 at 11:44 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    My ST MAXX have done well in Montana summer and winter thus far. That's a cheap price too!
