Sagging front after lift?
Discussion in 'Suspension' started by luk8272, Apr 7, 2008.
How many of us are experiencing Sagging?
  1. Sagging with 884
    0 vote(s)
    0.0%
  2. Level with 884
    0 vote(s)
    0.0%
  3. Sagging with other
    0 vote(s)
    0.0%
  4. Level with other
    2 vote(s)
    100.0%
  1. Apr 7, 2008 at 5:16 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Wanting to see how many have lifts that sag in the front after install. Let us know what lift you have, how many miles on it. If you corrected it let us know what you did to fix it. Seems that this may be focused on Toytec 884 coil springs. Tell us if you have the Rear spring TSB.
    I just installed the 3" toytec with 884 coils and 1.5" block and had the TSB done the day before I installed the lift. Max of 200 miles on the lift at this time. Still level.
  2. Apr 7, 2008 at 5:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    well...the closest option for me in level with other. i have extra lift in the rear for rake, but i have had no sag in the front w/ a 2.5" poly spacer. this was installed back in octoberish of 07 and prolly added about 6-8k miles to it since then as well
  3. Apr 7, 2008 at 9:48 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Same here... But truthfully tired of Ready lift leveler, but will be awhile til I install my FABTECH...
