Saggy Rear
Discussion in '1st Gen. Tacomas (1995-2004)' started by wgrippo, Jul 29, 2008.
  1. Jul 29, 2008 at 6:05 PM
    wgrippo
    wgrippo [OP] New Member
    Pacifica, CA
    '03 Tacoma Double Cab 4WD
    hi,
    i recently purchased a 4WD '03 Tacoma Double Cab with 80k miles. it has a camper shell and the rear sits slightly lower than the front. loading it up makes it worse, of course.
    what tips do you have for raising the rear just an inch or so? i know some off-road types like the front of their trucks higher, but i personally like a stance with the rear up a tad. do you recommend add-a-leafs? or replacing the leaf springs all together? spacers? how can you know how much height you'll gain - i don't want to add 3" to the rear.
    thanks,
    -Wilder
  2. Jul 29, 2008 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    I would just get an AAL. :)
  3. Jul 29, 2008 at 6:39 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    you could do a 1" spacer from toytec. I did, after doing the AAL. Because the back sat even with the front, so I put in the 1" spacer to get it about 1" higher then the front.
  4. Jul 29, 2008 at 6:42 PM
    ETaco23
    Evan
    PNW
    ofcourse doing just the AAL might give you the right hight your looking for. It should give you about 2".
  5. Jul 29, 2008 at 7:07 PM
    wgrippo
    Pacifica, CA
    thanks, that sounds good. i'll give the AAL a try first. are there different brands of these? any recommendations? where to buy?
  6. Jul 29, 2008 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOnger is a better ride. If you have a spring shop in your area, have them make you one. :)
  7. Jul 30, 2008 at 4:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What Chris said...
    Take your truck to a local spring shop and have them look at your truck. Ask them to give you a quote on making you a custom AAL to help the sagging.
    Then - compare the cost - to the price of buying an entirely new leaf pak. But remember, if you buy a new leaf pak - you'll have to get a set with a paticular amount of *lift* in it to support the weight.
    Do some research and see what other people have done with a cap & sagging. See what options others have gone with and if those options continue to work for them.
  8. Jul 31, 2008 at 6:11 PM
    wgrippo
    Pacifica, CA
