Sanity Check - 2012 Regular Cab Base Backup Camera Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SixtyDashOne, Aug 5, 2016.
  1. Aug 5, 2016 at 12:23 PM
    SixtyDashOne
    SixtyDashOne [OP] Well-Known Member
    Collegeville, PA
    2019 Double Cab TRD Sport
    hey guys.. I want to install a backup camera in my tailgate handle of my Regular Cab. which has no pre-wired anything for a backup camera, I made up a little drawing as to how I think its wired, and just want somebody to check my wiring and see if it makes any sense, thanks!
  2. Aug 5, 2016 at 12:29 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Sup dude, I don't think our head units are able to display any live camera feeds in the radio.
    I have the camera installed (by me) in my 2013 RC 4x4 Tacoma. I tried tapping into reverse lights, I tried the pin method on the back of the radio. I tried it all. this guy (I forgot his name)-Tacoprerunner XX or something did the rear view camera in the rear view mirror. I have the temp/compass in my mirror already so I didn't want to go that route.
  3. Aug 5, 2016 at 12:37 PM
    SixtyDashOne
    Collegeville, PA
    Hello. As per the drawing, it states that its a pioneer aftermarket touchscreen
    jmaack likes this.
  4. Aug 5, 2016 at 12:43 PM
    ExplorHer
    ExplorHer Question Authority
    Near Vegas
    2016 AC, 4cyl, 5MT, 4x4, SRUP with some junk.
  5. Aug 6, 2016 at 4:10 AM
    SixtyDashOne
    Collegeville, PA
    Interesting. I originally thought that might be the case, but i wasnt sure
    Any other input fellers?
  6. Aug 8, 2016 at 6:11 AM
    SixtyDashOne
    Collegeville, PA
  7. Aug 16, 2016 at 4:47 AM
    SixtyDashOne
    Collegeville, PA
    last try before I scrap this idea, haven't found much else online :(
  8. Aug 16, 2016 at 7:34 AM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    2017 Sport DCSB Barcelona Red
    265/70R17 BFG KO2 on mayhem wheels, pro grille, 5100s wrapped in 887s, Icon AAL, KC 30”
    @Blais03 help this dude out. I know you did yours differently
  9. Aug 16, 2016 at 8:11 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD 5-speed
    No prob @LivinLoud. My cameras signal goes through the RCA to the radio. The cameras power wire goes to the reverse light power wire. the ground wire can be grounded to any ground (i used the reverse light ground wire) and thats all there is! i didnt have to screw around with a reverse signal gear wire inside the truck. My radio (also a pioneer touch screen) automatically goes to the back up camera when the camera gets power (when reverse lights are on it gets power). Also, Make sure your camera is in the correct RCA input on the radio. if your reverse lights are on the camera should be on. Hope this helps.
  10. Aug 16, 2016 at 8:25 AM
    SixtyDashOne
    Collegeville, PA
    Well thank you for the reply. Appreciate it. I guess i am just a little confused of how the radio "knows" when the car is in reverse? The rca cable carries a video input, no signals. There IS a reverse wire on the pioneer head unit harness, but since my regular cab has no reverse camera on it from the factory, it was never hooked up and is just hanging there hehe. Hence the confusion
  11. Aug 16, 2016 at 8:31 AM
    Blais03
    Nick
    Easthampton MA
    when the RCA has a signal, the display automatically changes to the back up camera. Thats how mine works anyway and mine is also a pinoneer
  12. Aug 16, 2016 at 9:18 AM
    SixtyDashOne
    Collegeville, PA
    well I certainly hope that is correct! I can test it with the wires loose real quick and see how it goes,., thanks for the tips guys!
  13. Aug 16, 2016 at 11:39 AM
    Blais03
    Nick
    Easthampton MA
    If you have any problems let me know I can try to help.
  14. Aug 16, 2016 at 11:59 AM
    SixtyDashOne
    Collegeville, PA
    i appreciate your efforts to help a brotha!
  15. Aug 16, 2016 at 12:27 PM
    ExplorHer
    Near Vegas
    When there is no power going to the camera, the camera does not output video.
    So when you have the camera powered off the reverse lights, and you put your truck in reverse, then the camera powers up and outputs video to the head unit. The Pioneer senses video coming in from the RCA, and puts it on the screen.
  16. Aug 16, 2016 at 12:28 PM
    LivinLoud
    TJ
    Western mass
    @SixtyDashOne Glad to help out, my brother ( @Blais03 ) did his differently than I did mine, as he was in the same situation as you with no factory camera. We both run pioneer touch screens, the only thing that may be a bit finicky, is when you hook up the parking brake wire to a switch, if you plan on trying to wire the head unit to play video while in motion. Pioneer units ask for a weird sequence of "on off on" to be able to view video. If you get to the point where you want to do that shoot one of us a PM or tag us in here!
  17. Aug 16, 2016 at 12:31 PM
    ExplorHer
    Near Vegas
    I too recommend the bypass.
  18. Aug 16, 2016 at 1:03 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    You might want to run power to the camera from a switch also, so you could view the camera at any time, not just in reverse.
    I think you could turn it on either way with a relay that allows two inputs.
    Just an idea.
  19. Aug 16, 2016 at 1:15 PM
    SixtyDashOne
    Collegeville, PA
    Interesting. I have the pioneer parking brake wire wired to a switch, but i do not wish to engage the camera when moving. I just want it on as "normal" (when i go into reverse).
  20. Aug 16, 2016 at 2:59 PM
    LivinLoud
    TJ
    Western mass
    Im sorry if my post was unclear, what i meant was when you are moving you could play videos (DVDs) if properly wired. I wasnt reffering to the backup camera. Otherwise you need to have the truck stopped, and do a parking brake sequence to make it properly play the videos (DVDs)
