Sarter won't stop running until battery disconnected?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowest, Oct 4, 2010.
  1. Oct 4, 2010 at 10:09 AM
    bowest
    bowest [OP] New Member
    2000 tacoma
    :(Is this a bad solenoid/motor starter or something else?
  2. Oct 4, 2010 at 10:13 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Welcome to TW. I don't have a 1st gen, but it sounds like the solenoid.
  3. Oct 4, 2010 at 10:40 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Solenoid stuck on.
  4. Oct 4, 2010 at 10:41 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
  5. Oct 4, 2010 at 11:33 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Yup. Solenoid. My Friend's 97 Celica did this.
  6. Oct 4, 2010 at 6:51 PM
    humtaco
    humtaco Well-Known Member
    Does the starter try to turn the engine over as soon as you reconnect the battery without using the ignition switch? If so it could be a bad relay.
  7. Oct 5, 2010 at 3:51 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Solenoid is stuck, try smacking it with a hammer to see if it stops.
  8. Oct 5, 2010 at 3:57 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    gotta be som' ta doo wit yee starter. Jee try hittn it wid an ax hanel ?
  9. Oct 5, 2010 at 3:59 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    could be where a wire was chewed on by squirrels too. Had that happen also
  10. Oct 6, 2010 at 8:45 PM
    CrunchyTaco99
    CrunchyTaco99 Well-Known Member
    Joe
    North Georgia
    99 TRD Tacoma
    33x12.50 Pro Comp M/T's All-Pro Coils, UCA and 3" leafs.
    Your contacts are bad! They wear and get stuck open. Search some of the Toyota 4X4 sites for a tech write-up. Mine did the same thing. These trucks are prone to do it. I bought the cheap new contacts (maybe 6 bucks?) but I could switch them out the starter stuck open one day and burnt up before I could disconnect the battery. I had to buy a new starter.
