Sas, 00 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by usmcandrew, Jan 2, 2009.
  1. Jan 2, 2009 at 3:05 PM
    usmcandrew [OP] New Member
    Jan 2, 2009
    00 Tacoma SR5
    3" lift, 33" super swamper tires, performance chip
    I need help. I am working on my 00 Tacoma with the 2.7L and I am doing a SAS. I am going with the leafs and not the coil overs. I am getting the IFS Eliminator Kit from addictedoffroad.com I am in need of knowing if I will have to get a 2wd oil pan cause I was informed you had to for the 3.4L? Where can I get the correct front drive shaft? Should I try to find a 79-85 toyota front axle or is it fine to cut down a dana 44 from a 90's f250? I am Just having my brother collect parts so I can smothly do the swap in June when I get back from my deployment. Is there absolutly anything that I may be fogetting?
