SAS... DONE !!! :D
Discussion in 'Solid Axle Suspension' started by Yota_dvl, Feb 9, 2011.
  1. Feb 10, 2011 at 10:56 AM
    #41
    Yota_dvl
    Yota_dvl [OP] Well-Known Member
    Jesse
    Central Utah
    03' Ext cab 4x4
    SAS KIT - trail-gear 5" lift alcan springs greasable shackels gears front 410 rear 411 Kicker subs 3,000 mile drive to Alaska, 3,000 back "Mod" rear diff breather
    just kept the rear at 411, so took the front down to 410, since its a dd but the shop said that if that seams too low that come in and they'll change them both out to a higher gear for lunch to to shop and 100 :D
    thanks for the warnings and your concern but i'll take my chances. btw leafs have settled another inch, now im just 1.5 illegal after hittin trails today im pretty sure its goona go down i little more. ill trim the fenders abut after going so i dont over trim and make it look like shit, ...and in the state of utah they dont give a shit about lights and bumpers.. its frame to ground and mudflaps and fender flares.
    future mod list- exo cage, bushwacker fender flares, HID lights on my light bar, hood off tacoma hood with a scoop, single shaft rear drive line, airlockers up front so i dont have to get out to always put it in 4wd, and bumpers (try makin them look like this guys front and rear though.)
    [​IMG][​IMG]
  2. Feb 10, 2011 at 11:13 AM
    #42
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Air Locker in the front will still need the hubs locked manually.
  3. Feb 10, 2011 at 1:30 PM
    #43
    Yota_dvl
    Jesse
    Central Utah
    03' Ext cab 4x4
    :( really... so now on i always gotta get out to throw it in 4wd?
    ... o well i can use the exercise
  4. Feb 10, 2011 at 1:49 PM
    #44
    Dark Knight
    Jeff
    NC/SC
    the ARB Air Locker will lock the two axles in the differential, you will still need to manually lock your hubs at each wheel to fully engage 4x4. Only use the Arb Locker when needed for extreme terrain. 95% of the time just locking the hubs in 4x4 will be fine. Plus, you will find that when the locker is on in the front, turning will be a chore. If you hubs are not locked while shifter is in 4WD you are not actually in 4WD.
  5. Feb 10, 2011 at 2:02 PM
    #45
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    You can get auto locking hubs.
  6. Feb 10, 2011 at 7:50 PM
    #46
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Pricey drive flanges is the term. Poly performance sells them. :D It requires work though to put them in, and different outer stubs IIRC. 30 splines, instead of 19.
  7. Feb 10, 2011 at 8:27 PM
    #47
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this pic looks like you have a shitty white snorkel!
    Sweet truck though :cool:
  8. Feb 10, 2011 at 11:42 PM
    #48
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yeah...you need to LOCK your hubs.
    Hubs locked = front axle shafts are always turning.
    Unlocked hubs = front axle shafts are not turning.
    You can be in 4wd via the transfer case and have the aRB locked but it aint' doing shit for you if your hubs aren't locked.
    Keeping the hubs unlocked is a good idea for daily driving & such. With my jeep (GW D44 in it), if the hubs were locked and I drove it around...I'd have a slight vibration from the front axle shafts turning all the time.
  9. Feb 12, 2011 at 1:46 PM
    #49
    Supra TT
    Eric
    Indiana
    Any updates?... Still working correctly? Also with your gear ratio being so high, how's the power?
  10. Feb 12, 2011 at 1:47 PM
    #50
    tecate12
    tecate12 Fuuaaaaaaa!!
    Martin
    El Paso,TX
    Tina: The EPT Blue Beast
    K&N Cold Air Intake, pioneer AVH-4200 DVD, WT floorliners, colormatched engine cover, Westin Bull Bar with driving lights, N-FAB step bars, Rear TSB, Bilstein 5100's @ 1.75, 265/70/17 Dick Cepek MUD COUNTRYS on 17" Black TRD sport wheels, Satoshi Grill, Custom TRD tire valve Caps, and still coming...
    what a beautiful toy to play with!
  11. Feb 12, 2011 at 8:07 PM
    #51
    Yota_dvl
    Jesse
    Central Utah
    03' Ext cab 4x4
    yeah that pic bugged me cause of that, its a grain shoot thingy to drop grain into train cars, it was the only un touched snow and clean place that looked good for taking pics.
    everything is working amazing, the power well it turns the tires and i havent noticed to much of a difference on mpg but actual speed, it'll still do my average speed of 75 on the freeway with rpms just near 3.5 shiftin point is near 4 at worst when i punch it. other then that i just need a longer run way to get up to speed then i used to ( almost double :( )
    FLEXING PICS http://www.tacomaworld.com/forum/solid-axle-suspension/139698-some-flexing-pics.html#post2730837
  12. Feb 17, 2011 at 7:58 PM
    #52
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    So, what to you think about the 5" springs after things have settled? still too much? would the 3" be good enough for 35's ya think?
  13. Feb 18, 2011 at 1:48 PM
    #53
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    Biggest pieces of shit ever :D Don't get auto locking hubs...stick with the Manual. The truck looks good bro! It will settle down some more trust me...A selectable locker up front is nice but even locked steering won't be that hard...nothing a little hydro assist can't help with! :) But definitely get some armor bro...a nice front bumper, some sliders, and a rear bumper!
  14. Feb 18, 2011 at 1:59 PM
    #54
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I think 3" would be fine hell with some modding you can fit 35's on a IFS and i just might do that with my next set of tires :D
  15. Feb 21, 2011 at 1:34 PM
    #55
    SiRMarlon
    Marlon
    Los Angeles
    Canon 5D MarkIII
    The 5's will settle down, you still have to break them in...plus if you ever decided to go bigger tires you won't have to cut and clearance as much. Because trust me one day you will go bigger then 35s...it happens to everyone! :D
  16. Feb 21, 2011 at 2:08 PM
    #56
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    37's FTW!!
  17. Feb 21, 2011 at 2:25 PM
    #57
    SiRMarlon
    Marlon
    Los Angeles
    Canon 5D MarkIII
    40's son!!! :D Plus if you still think the 5's are to big it's not that hard to take a leaf out...then the pack will break in faster, be way more flexier and if they get to soft you can always throw that leaf back in :) it's a win win dude. But trust me...with the SAS you want something nice and flexy! Give your leafs some time bro...you just got that bitch! :) Take a trip down to MOAB go play over at BFE and break her in right!
    Man sometimes I really miss Utah! :(
  18. Feb 23, 2011 at 12:55 PM
    #58
    jeepmor
    jeepmor Well-Known Member
    Stumptown
    You will never go back to IFS. Congrats.
  19. Feb 23, 2011 at 1:02 PM
    #59
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    you were the guy that made the thread about the tire carrier in your bed, the off center one right?
    lol
    sweet truck
  20. Feb 24, 2011 at 3:49 PM
    #60
    Yota_dvl
    Jesse
    Central Utah
    03' Ext cab 4x4
    correct i was... it served its purpose but looked ugly as shit but now tryin to figure out a mixture of a headache rack with spare tire holder that doesn't look bad, but doesn't cost too much.
