SAS on 2wd taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dcrawfo1, Mar 8, 2011.
  1. Mar 8, 2011 at 2:22 PM
    dcrawfo1
    dcrawfo1 [OP] Active Member
    Donny
    Greenville, SC
    06 Tacoma SR5
    06 tacoma. 3 in fat bobs leveling kit. 235 tires
    alright im new on here and i just have a few questions. i have this master plan in my head and i'd love for it to work out lol. i have a 06 taco access cab 2wd auto. and i'd like to lift it and put some 33s or so on it. So i got this idea today to buy a set of toyota axles. (found a set frnt and rear, out of a 84, complete, $400) and just swap them under my toyota. are the 84 toy axles the same width as my current set up, or skinnier?? and info or links on this would be great! thanks
  2. Mar 8, 2011 at 2:51 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Do you know how to weld. Do you have a torch, welder, grinder, basic fab tools?
    Are you going to run springs or links?
    Steering box?
    Are you going to rebuild the axle? Do you know how? Do you have the tools?
    84 axle is 55 1/2"
    05 axle is 60"
    I also believe the 84 solid axles were passenger side drop.
    The Tacomas are driver side drop. Maybe I'm wrong?
    If you're not converting to 4wd then I guess that won't matter but then to me the swap makes no sense.
    IFS will handle better for everything you'd use a 2wd truck for.
    Maybe that won't matter anyway if you go through someone like marlin for a t-case.
    A narrow Dana44 out of a Wagoneer is about 62" and I believe drivers side drop, this would probably fit you better.
    Keep the stock rear. Don't forget you've got to match the gears.
    I'd read through Wyatt's (Awsumdc) sas, and go to TTORA and read all the SAS's. Then do a search on pirate and read more.
    If it was as cheap or easy as you make it out to be, I would have done it long ago.
    http://www.atarmor.com/writeups/SASwriteup.htm
    http://128.83.80.200/TACO/sasfaq.html
    http://www.tacomaworld.com/forum/solid-axle-suspension/138316-sas-quick-guide-cost.html
    I don't quite agree with his assessment of cost but I'd say you could be in the $5000 with leaves range damn quick.
  3. Mar 8, 2011 at 2:53 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    really cuz? 2 threads? its un necessary. If your having to ask about basics like that your not ready for a sas (Solid axle swap). You should do alot more research and reading before you ask questions. Read through here. dont ask questions on that site until you do or you will catch hell.
  4. Mar 8, 2011 at 2:53 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Why!? You have a 2wd why in the world would you do a sas! That's like throwing money away.
  5. Mar 8, 2011 at 3:04 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Ya I agree. Solid axle swap can be expensive and hugely labour intensive. Why on earth would you do this on a 2WD.
    Trade it in for a 4WD sounds like you will be a lot happier, that's what I did!
  6. Mar 8, 2011 at 4:54 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    How far is that SAS going to get you in 2WD?
    Don't waste your money on this project
  7. Mar 8, 2011 at 5:22 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Maybe he wants to convert to 4x4? Get a jeep wagoneer front axle
    Jojee117 likes this.
  8. Mar 9, 2011 at 12:16 AM
    dcrawfo1
    Donny
    Greenville, SC
    06 Tacoma SR5
    thanks kinkrider101 lol. i was thinkin of this in the long run. and yea sorry about the 2 threads. i put this one up then realized i should have put it up in the 5 lug section. sorry ill delete it if its that big a deal. thanks for all the input tho!
  9. Mar 20, 2011 at 5:15 PM
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Nothing wrong at all with doing on sas on a 2wd truck. infact, in many case's it's easier to do than on some 4wd trucks because of the electronics involved. I'm going to do a solid axle swap on my wifes '04 4.7liter 4Runner and it's 2wd. Going to make everything much easier than messing with te 4wd computer on the same truck. You just need to get a fully manual transfer case when doing this kind of swap r pay through the nose to put in an electronic one. Just my two cents ;)
  10. Mar 20, 2011 at 7:37 PM
    tacomakid96
    Phil
    Out n' about
    Will you marry me? :pray:
  11. Mar 20, 2011 at 11:58 PM
    dcrawfo1
    Donny
    Greenville, SC
    06 Tacoma SR5
    lol. yea if i were to go thru with this in the future i would do a manuel tcase. i hate all this electronic crap, its too much stuff that could mess up when you need it the most
  12. Mar 23, 2011 at 10:20 AM
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Depends.... what size dress do you ware?:p
