Satoshi Body work help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by primer, Feb 16, 2011.
  1. Feb 16, 2011 at 4:05 PM
    primer
    primer [OP] Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    I'm making progress on my Satoshi grill. I bought the extra grill 2yr ago. Actually cut it apart in October. Now I'm in the putty/sanding phase. At this rate I'll finish about the time solar powered hovercraft replace the automobile...
    But seriously - I've hit a snag. I cut plastic pieces to fill the gaps and epoxied them in place. I'm smoothing things out with this:
    http://www.amazon.com/gp/product/B000P6US6U/ref=oss_product
    I'm new to this stuff, but would describe it as a fiberglass type body filler that is two parts, one being the putty, the other being a cream hardener.
    Things were going well. I have gotten one side nearly paint ready. I put a little more filler on the other side and went light on the hardener. I recognized that it didn't firm up right away. I decided to give it some time. That was 3 days ago.
    It is dry to the touch, but when I tried to sand it today it just gummed up. I can't really sand it down, but I can scratch little bits off with my fingernail. I'm hesitant to put more stuff on it. Would a solvent of some time take this off?
    I'm not sure how to fix this mistake.
    Any help would be appreciated.
    TL
  2. Feb 16, 2011 at 4:13 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I'm guessing not enough hardener was added.
  3. Feb 16, 2011 at 4:24 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    x2 scrape it off
  4. Feb 16, 2011 at 4:26 PM
    primer
    T
    OK
    Correct diagnosis. With that batch for some reason a thin liquid came out of the hardener tube. I wasn't sure how much of the thick stuff I should add. Turns out the answer is more than I did.
    Now - what do I do about it? I'm afraid to put another layer on top of that uncured stuff, but I suppose maybe the hardner in the new stuff might make it cure.
    Not sure. Need advice.
  5. Feb 16, 2011 at 4:59 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    You're going to have to scrape off the old crap. Do not put more on top. It'll most likely end up cracking over time. Just take a screw driver or a thick blade and scrape if off.
  6. Feb 16, 2011 at 5:08 PM
    primer
    T
    OK
    Damn. That's gonna be hard. I was hoping some solvent would help it wipe off.
    TL
  7. Feb 16, 2011 at 5:13 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    nope... i hit the same problem when i did mine this weekend.. scraped it off and put more hardener instead... works fine... im gonna resand and repaint mine this weekend because i missed some spots in the corner.
  8. Feb 16, 2011 at 6:07 PM
    primer
    T
    OK
    You aren't suggesting I just put more hardener on top of the stuff that's there are you. That doesn't seem right, but is seems like you are suggesting that.
    TL
