Satoshi GrillCraft *How To* w/ pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Klipp11, Feb 18, 2010.
  1. Jul 19, 2010 at 9:54 AM
    #201
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I ordered mine end of September 09, finally got them around end of November, early December.
  2. Jul 19, 2010 at 8:43 PM
    #202
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    ABS plastic pipe is common at hardware stores, but it's the wrong shape. you'll need to find a bit of flat section to fill in the gap. it doesn't have to be perfect 'cause you'll be finishing it off with the putty. i'm sure you can find something around the house or the hardware store to fit the bill. just test the epoxy on the plastic before you put all the work in shaping it to make sure it'll bond the material you want to work with.
    gl
  3. Jul 25, 2010 at 12:41 AM
    #203
    Ace83
    Ace83 Well-Known Member
    TX
    SR5
    Bilstein Front shocks, Rough Country 3" lift kit, 5" black railway running boards
    im thinking going this route, gonna do the bottom as well.. quick question, does grillcraft have a stronger/more solid mesh than some other generic mesh.. I want a grill that doesnt get bent easily when you hit a bit solid
  4. Jul 25, 2010 at 8:29 PM
    #204
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    gc makes a solid product, you won't be disappointed. i can't comment on mesh though, 'cause i never checked any out. if cash isn't an issue, go with the gc.
  5. Jul 25, 2010 at 9:18 PM
    #205
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    has anyone done this mod on a 1st gen. tacoma? im thinkin about doing it.
  6. Jul 25, 2010 at 9:23 PM
    #206
    pinktaco808
    pinktaco808 Hot Steppa
    show pic of behind the grill what it looks like
  7. Jul 26, 2010 at 9:40 PM
    #207
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
  8. Jul 26, 2010 at 9:57 PM
    #208
    Krewblink
    Krewblink Well-Known Member
    Danny
    Long Beach
    05 toyo Prerunner
    Exhaust,Seat Covers, Intake
    sick write up good work
  9. Jul 27, 2010 at 4:46 AM
    #209
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Model hobby stores used to sell plastic sheets in 12"x4" sizes in different thickness, they may work.
  10. Jul 27, 2010 at 9:49 PM
    #210
    pinktaco808
  11. Jul 27, 2010 at 10:56 PM
    #211
    replica9000
    2019 T4R ORP
    I will try to get a picture when I can. Been living at work lately....
  12. Jul 27, 2010 at 11:35 PM
    #212
    pinktaco808
    thanks man
  13. Jul 28, 2010 at 10:53 PM
    #213
    pinktaco808
    any other ideals
  14. Aug 14, 2010 at 10:59 AM
    #214
    utmck
    utmck Well-Known Member
    When painting behind the "Satoshi" grill is there anything that is not ok to be painted? I don't want to paint something that could hinder functionality.
  15. Aug 14, 2010 at 4:23 PM
    #215
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Ok, for some reason I haven't bumped into any grillcraft and/or satoshi thread before, and I THOUGHT I've seen it all by now lol.
    I want! NOW! :)
    What's the diff between this method and 'satoshi'? Where do I go? Is the mesh hand cut to fit the grill, and where do I get it? I'm loving this result.
  16. Aug 14, 2010 at 5:14 PM
    #216
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    This is a satoshi. He just didn't use fiberglass cloth, he used pieces of the center section that you cut out.
    You can go to a local metal shop and get some mesh material or get some from http://www.customcargrills.com/
    Depends on what material you use, how you'd cut it.
  17. Aug 14, 2010 at 5:30 PM
    #217
    SCFirefighter
    Stephan
    Cary, NC
    Gotcha. Thanks. I wondered about the level of DYI on this one since there is also a grillcraft.com site floating around where you can buy it (fully done?).
    Anyway, I looked at customcargrills.com and now I wonder what mesh to get.
  18. Aug 14, 2010 at 6:40 PM
    #218
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    if you want to recess (satoshi) the grillcraft or mesh, you'll probably need the weekend because you'll need to patch and finish the holes left in the grill surround when you cut the two plastic cross pieces out of it.
    if you simply want to install the grillcraft flush at the front of the grill surround, it will fit perfectly and will only take about 1/2 hour to install if you have the right tools. you wouldn't need to patch and finish the holes because they'll be hidden behind the grillcraft unlike the satoshi version.
    you don't have to use a grillcraft if you find another type of mesh you like better. personally, i like how the gc looks and know it's a solid product :cool:
  19. Aug 14, 2010 at 7:35 PM
    #219
    SCFirefighter
    Stephan
    Cary, NC
    Thanks. So the thing that makes it a Satoshi is the recessed mounting. I like that though. I got time. Thanks :)
  20. Aug 14, 2010 at 7:51 PM
    #220
    Larry
    Larry CARL
    CARL
    This thread rocks big time. Super duper props to you guys who have done this mod.
    Unbelievable!
    I'm impressed...and I'm not easily done so.
    I'm not usually one for mods of this type...but talk about an inspiration...
    I also like the variations of grill materials and badging. Awesome!
    If I keep this new Tacoma for a while...and get the time (between work...family...other business...trying to find time to fish...I'm also a book reader...and playing guitar...and somewhere in there I find time to eat and sleep...)...I just may give this a go.
    I think I'd get another grill to work on other than the one on the truck. This would allow the time...my truck is my DD. And...I'd probably want a color matched grill instead of the chrome one that's on my truck for this mod. My opinion only.
    Again...
    Super job y'all have done here...Thanks for sharing. Subscribed.
