Satoshi mess up/ grill choice opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJ5685, Sep 11, 2011.
  1. Sep 11, 2011 at 11:36 AM
    JJ5685
    JJ5685 [OP] Well-Known Member
    NC
    08 TRD Off Road v6 sr5 4X4
    pioneer stereo, 10" rockford fosgate punchgate sub, custom box, bull bar, custom trd decals
    I am just about done with my satoshi and when i pulled the tape off there is a edge of primer showing that didnt get painted (just my luck). It doesnt look bad from a few feet away but up close it sure does. I might sand and paint it again if it keeps bothering me when I get it finished. for now Ill going to try a paint marker. (its hard to see the primer, most of what looks like it in the pic is just a glare)
    and which grill mesh do you think I should go with. I drawn these and am getting a metal shop to cut them out for me.
  2. Sep 11, 2011 at 11:41 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    If it it's going to bother you, then I would definitely just redo it now - you know you will just end up redoing it later if that's the case.
    As far as the design, I would just go with the tried and true TOYOTA emblem.
    I would also be sure not to make it too big, otherwise it will look a little weird. I think the size and placing of the TOYOTA emblem in the standard Satoshi looks perfect and would make it match that as close as possible.
    That's all just my opinion, of course.
    Fink
  3. Sep 11, 2011 at 11:46 AM
    JJ5685
    NC
    I made TOYOTA big to do something thing like the ford raptors grill. I might make some more choices before i get it cut. I want something unique rather than just a ordinary satoshi.
  4. Sep 11, 2011 at 11:52 AM
    Fink
    Orlando, FL
    Makes sense - if you are going to do it like that, I would space the letters out a little bit more and take up the full grille.
    Fink
  5. Sep 11, 2011 at 11:59 AM
    JJ5685
    NC
    i'll try it. the hard part is getting the exact dimensions of the grill with the rounded corners, and the sides of it are bowed out just a little. I wish I had a template
  6. Sep 11, 2011 at 12:05 PM
    ILLINOISTACOMAGUY
    ILLINOISTACOMAGUY Well-Known Member
    Darryl
    ILLINOIS
    2005 SR5 SPORT
    WeatherTech Digital floor mats front and rear. Ventvisors, Hood protector, Towing package, Bed tiedowns, Wheel to Wheel steps,
    try a piece of poster board to make a template and you will be able to trim it a little at a time till you get what you want...I like the Toyota emblem personally.
  7. Sep 11, 2011 at 12:16 PM
    Sierra4x4
    Sierra4x4 Member
    Glenn
    Reno, NV
    11 Tacoma TX Pro
    Cat Back Exhaust, 3" Lift Kit
    I like the TOYOTA one, reminds me of the 1st gens for some reason
  8. Sep 11, 2011 at 12:18 PM
    Fink
    Orlando, FL
    Fink
