Satoshi zip tie mounts???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grizzlytravis, Jul 11, 2011.
  1. Jul 11, 2011 at 9:09 AM
    grizzlytravis
    grizzlytravis [OP] Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    Where can i buy thes ziptie mounts/anchors I see ppl using for satoshis?
  2. Jul 11, 2011 at 9:10 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
  3. Jul 11, 2011 at 9:19 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    any hardware store..ace hardware, lowes, home depot, etc... you can even find it at walmart...
  4. Jul 11, 2011 at 9:23 AM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    I found pack of 10 at Lowes right next to the zip ties. I removed the the sticky double sided foam tape that the mounts had on there so that I had a nice flat surface. Then used Plastic epoxy to glue the mounts down to the back of my satoshi grill. They hold great! Just make sure not to use too much epoxy to fill in the holes where the tip tie threads through. I found it best to barely dip the mount in the epoxy so that you made sure the holes didnt get filled then mount to grill. Once that first set of epoxy dried, use a toothpick and place more epoxy around the edges of the zip tie mount to make sure its really held down good.
  5. Jul 11, 2011 at 9:33 AM
    Tomasb1339
    Tomasb1339 Baddest Taco in Marin
    Thomas
    SF Bay Area
    09 Taco 4x4
    6" Pro Comp Red Badges Satoshi Grille Westin Bull Bar
    I just used nuts and automotive goop. I put the nuts on thier side and ran the zip ties thru them. They hold better than plastic IMO
  6. Jul 11, 2011 at 9:35 AM
    grizzlytravis
    tampa florida
    08 taco 5 lug
    Lol wow thanks guys
  7. Jul 11, 2011 at 9:38 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Don't need them... some strategically drilled holes work perfectly. I did mine over a year ago with zero issues and build my grills with this method. Quick, easy & inexpensive...:cool:
  8. Jul 11, 2011 at 1:28 PM
    pojo82
    pojo82 Well-Known Member
    Josh
    NE Wisconsin
    06 TRD double cab
    flowmaster exhaust, URD cold air intake, URD MAF calibrator, Thorley Headers Billy 5100s set to 2.5 lift in front, Billy shocks with add a leaf in the rear Wet Okole seat covers
    what he said, i just used the foam tape that was on them and after a couple months all but two loosened up and i had to reglue them all
