Saw this on an old Rockford amp
Discussion in 'Audio & Video' started by 07TacoRidah, Sep 21, 2010.
  1. Sep 21, 2010 at 10:18 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    I was on CL looking around and saw a diagram somewhat like this on an old Rockford amp someone was selling. Wondered if you could do this to all 2 channel amps. I forgot what it was called, there was a name for it on the amp but can't find it anymore.
    From what I was thinking (since I have an AC truck), wiring my front speakers regularly to one channel ea. then bridging it like so with the rear sub ... given that this will actually work.
  2. Sep 21, 2010 at 10:21 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    What kind of amp, speakers and sub do you have?
  3. Sep 21, 2010 at 10:26 AM
    07TacoRidah
    I have a 10" kicker cvr right now, as for the fronts I'm not sure what I was going to get yet. As for the amp, for sure one that will be able to handle it all. CVR is dual 4 ohm.
    Mainly seeing if this way of wiring will work.
  4. Sep 21, 2010 at 10:27 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    Its called bridging, like you said.
  5. Sep 21, 2010 at 10:29 AM
    07TacoRidah
    well on the Rockford amp it was called something else. I know what bridging is, this was refered to as something diferent (your still wiring 2 reg speakers to their respected channels, then daisy chaining off where you would bridge for the 3rd speaker/sub).
  6. Sep 21, 2010 at 10:34 AM
    hookedontronics
    Jake
    Glenville, NY
    Bridging, your bridging the two channels for the third speaker
    I wouldn't recommend doing this with your front speakers though. Seems to me like you'd either be underpowering your sub or overpowering your speakers
  7. Sep 21, 2010 at 11:10 AM
    07TacoRidah
    damn n/m then I'm not down for that at all lol. thanks sorry about he inconvenience.
  8. Sep 21, 2010 at 11:17 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'd avoid that wiring configuration like the plague.
    I'm thinking the original drawing probably suggested an either/or case. Meaning that you'd either wire two subs (one on each channel) or bridge the two channels on the amp for either a single or dual sub setup.
    Unless I missed something, you can't run a sub per channel and then bridge the two channels with a third sub. That's like dividing by zero; we're not sure what happens but we're pretty sure it's not good.
  9. Sep 21, 2010 at 11:30 AM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    That wouldn't work if you are using your front speakers and a sub. normally you would have the LPF (low pass filter) turned on on the amplifier if you are running subs off of it and you would be sending the same frequencies to your front speakers. So if you have the freq. cut off at 100hz for example, you would only be sending 100hz or less to your front speakers.
  10. Sep 21, 2010 at 11:43 AM
    trlove
    trlove Member
    Harrisburg, PA
    17 TRD Sport
    It was called tri-way. As shown, a pair of normal 4 ohm speakers would be connected in stereo and then you could bridge an 8 ohm sub across the channels. Remember, when bridging the amp "sees" half the load (i.e., amp sees 4 ohms when an 8 ohm driver is bridged).
    To be most effective passive crossovers are oftened used.
  11. Sep 21, 2010 at 8:27 PM
    07TacoRidah
    BINGO!!!! so is it good to do on any 2 channel or was it just the case for the old Rockfords? I have a 2 channel right now that I can only bridge (my older brother used this amp in his old vehicle and lost 2 of the connecting bolts).
  12. Sep 22, 2010 at 2:23 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I guess it is time to show my age. Back in the late 80's and early 90's car stereo competitions were based on your amps power into 4 ohms speakers. (Almost all car speakers were 4 ohms back then and we also had no dual voice coil speakers either).
    So you would buy a 50w x 2 high current amp and go into the 100w and under class. Then, you would wire every speaker in your car up to this one amp using passive x-overs.
    The amps a remember most that could run this way were the ultra-high current ones. They were the Autoteck 9000 series, Orion Red Series, Phoniex Gold and Precision Power. Rockford Fosgate was the first amp to run a tri-mode that I remember but, Rockford was not the best. Orion Red Series or Phoniex Gold were the best.
    Anyway, I remember helping a friend install a competition system with one Orion Red Amp and twelve 12" subs and 4 pairs of MB Quart Mids and Highs. I think we ended up with a 1 ohm load on the mids and highs. And a one ohm load on the subs.
    These ultra-high current amps were good down to a 1/2 ohm level. I have been out of the stereo game for a long time, so I don't know if anyone makes this type of high current amp anymore but, it is amazing to see one of them work.
  13. Sep 22, 2010 at 2:27 PM
    Killer
    Mobile, Al.
  14. Sep 22, 2010 at 2:48 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    LOL I remember those days. In the early 90's, the shop I used to hang out at built a K5 Blazer with 16 Kicker 15's and 5 Orion HCCA 50's, 4 on subs and one on mids/highs. Only 250 watts........
  15. Sep 22, 2010 at 2:58 PM
    ItalynStylion
    Steven
    DFW, Tx.
  16. Sep 23, 2010 at 7:44 AM
    Killer
    Mobile, Al.
    See us old shits still have something to show you :D
    I am thinking about installing a ThrowBack system in my next car.
    I have 2 High Current mint Phoniex Gold MS 275 (capable of Tri-Mode). The MS 275 have consecutive serial numbers.
    I am looking to find a Phoniex Gold Cyclone Sub System (if you never heard one of these, do yourself a favor and look it up) http://www.audiojunkies.com/product/1006/phoenix-gold-cyclone-reviews
    I also have 2 pairs of old mint MB Quart 6.5 speakers (one pair is a component and one pair is a co-ax).
    Then, all I will be missing from my old system is Nakamichi Cassette Player Head Unit, Fosgate Pre-Amp, AudioControl EQ and AudioControl X-Over. I think I will move up to a Nakamichi CD Player this time around though.
    As you can tell, I miss the old days of car stereo! :cool:
  17. Sep 23, 2010 at 7:52 AM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I just got a kicker zx100.2 amp to power my components and it has this configuration listed in it. I agree with most everyone else though and would not use it. This amp only puts out 100 watts anyway haha.
  18. Sep 23, 2010 at 8:42 AM
    Killer
    Mobile, Al.
  19. Sep 23, 2010 at 9:24 AM
    Killer
    Mobile, Al.
  20. Sep 23, 2010 at 1:01 PM
    07TacoRidah
