SCAN GAUGE VS ULTRA GAUGE
Discussion in 'Performance and Tuning' started by WCJR, May 15, 2011.
  1. Jan 15, 2014 at 6:26 AM
    #41
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    This is another option to consider if you have a smartphone.
    http://www.cravenspeed.com/obdii-connector/
    The app for the android is great (Torque) and monitors the same sensors as the ones mentioned earlier. Iphone uses the DashCommand app. Your smartphone will have a better display than the gauges mentioned and I believe the display is a bit more customizable. The software/app of the android and iphone will continue to upgrade along with the tech in our trucks so it won't become outdated (not saying the SG/UG will). Plus its cheaper than both!
    Just a thought.
  2. Jan 15, 2014 at 10:13 AM
    #42
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I wish there was a one size fits all.....
    Ultragauge I had didn't show trans temp and Thats very important to me.
    Scangauge only shows 4 parameters at a time (lame)
    Torque didn't have trans temp, and the Bluetooth dongle was always drawing power.
    Really..... Just gimme the trans temp option on the ug and I'll buy another happily.
    As it is the scangauge will only show 1 trans temp for my truck (2006) and I dont know if its pan or converter.
    Curious how accurate ANY plug in scanners Horsepower calculations are.
  3. Jan 16, 2014 at 7:16 AM
    #43
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    You can add the trans temp to the Torque app, its not a default setting.
    In the settings you can add various sensors, trans temp being one of them. This is only for automatic transmissions though, I do not believe the manuals have trans temp sensors.
    Also, I saw a write up somewhere on TW on how to get the dongle to turn off with the truck.
    Edit: Found the thread: http://www.tacomaworld.com/forum/technical-chat/145959-obdlink-bluetooth-permanent-install.html
    Tacomoon likes this.
  4. Jan 19, 2014 at 12:40 PM
    #44
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    iPhone users can use the Engine Link app to monitor sensors, including transmission temps.
  5. Jan 19, 2014 at 12:43 PM
    #45
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Do these things show CELs, or will it help show you what is triggering a CEL?
    I know you can run the code, but when it gives you 6 different possibilities, kind of hard to narrow it down without dumping money at part store.
  6. Jan 19, 2014 at 2:17 PM
    #46
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Buy yourself a factory service manual and follow the troubleshooting steps. They list step by step instructions what to test for and how. Don't just keep buying parts until our solves the problem.
    To answer your question it will not tell you the cause of the issue. It well only give you the trouble code.
    Jackstraw13 likes this.
  7. Feb 6, 2014 at 6:35 PM
    #47
    usaftaco4x4
    usaftaco4x4 Active Member
    Dean
    Spokane, WA
    08 Reg Cab 4x4
    BS 3in Spacer lift in front and blocks in back that i need to get rid of.
    Where is everyone mounting the UG? It seems the SC is a little easier to mount and not stick out. I have a 08 reg cab and was thinking about getting the UG but the more i look into it, the harder it is to conceal.
  8. Feb 9, 2014 at 7:10 PM
    #48
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    the Ultra gauge shows a lot of stuff.its neat to play with but really,i only use the engine temperature gauge,and the tach.
  9. Feb 9, 2014 at 7:12 PM
    #49
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    x2 love mine.
  10. Feb 15, 2014 at 2:40 PM
    #50
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    Which gauge did you get? The are three different choices.
  11. Mar 18, 2014 at 4:24 AM
    #51
    2012Tacoma
    2012Tacoma Active Member
    Canton Ohio
    2012 Toyota Tacoma DBL Cab 4x4 TRD Sport
    Interior: Brake Controller TRD Seat Covers Weather Tech Floor Mats Exterior- Goodyear Wrangler Dura-Trac's 275/65/18 Firestone Ride-Rite 5000lb air bags 50" CREE LED Roof Mounted Light Bar custom made no drill mounts.
    For anyone who wants to purchase a scan gauge two i found out how to get them for $119 shipped!!!!!
  12. Mar 18, 2014 at 4:30 AM
    #52
    2012Tacoma
    Canton Ohio
    I stand to correct my self! We can get it for $111.99 with free shipping!!!
  13. Mar 18, 2014 at 8:45 PM
    #53
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    damn for 111 i'd buy another one :)
  14. Feb 18, 2015 at 2:44 PM
    #54
    GeorgeP
    GeorgeP New Member
    George
    Atlanta
    Tacoma Prerunner Sport
    1st I mainly use my Ultragauge for gas mileage. I do a lot of traveling and accurate gas consumption knowledge is a good thing.
    I love the calibration feature. I already have it to an accuracy of .2 gal on a fillup.
    The MPG of the UG is resettable by the user when the user wants. I contacted SG and the ability to have one MPG reading over a multi-day trip was not possible, no problem with the UG.
    The UG gives me something I have wanted since my 96 Chrysler T&C bit the dust. A distance to empty reading. I also have a digital fuel level reading. These two with a modern GPS allows me to quickly decide whether to try to make a city which is 170 miles away without filling up. (Gasbuddy says the gas is much cheaper there) When the UG says 150 to empty, I am going to stop for a couple of gallons and then go.
    My vehicle is a 2011 Tacoma. I don't know if it is typical, but the speedometer is off about 5%. At a speedometer reading of 70 I am actually going 66-67. Today I reconfigured my UG to show MPH and guess what. The computer readout is dead on. I have contacted UG and if I can hook up a second UG with a OBD Y splitter, I am going to get a second one and use Velcro to mount it directly over the Speedometer with a 4 gauge page display.
    These are some of my reasons that I love my UG.
  15. Mar 28, 2015 at 3:10 PM
    #55
    TacomaPDX
    TacomaPDX Member
    Washington State
    2014 double cab V6 SR5
    Can you adjust it to tell you your actual mpgs with bigger tires and lift done?
  16. Mar 28, 2015 at 3:21 PM
    #56
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
  17. Mar 28, 2015 at 5:36 PM
    #57
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    How?
    I have had mine about a year and I also do the manual calc at the pump every week..seems to be 2 miles over on the UG.
  18. Mar 28, 2015 at 5:46 PM
    #58
    TacomaPDX
    TacomaPDX Member
    Washington State
    Thanks. Just trying to gather as much info as I can. Is there a detailed write up or instructions how to change stuff on it for bigger tires and lifts or is the instructions it comes with pretty cut and dry?
  19. Mar 28, 2015 at 5:53 PM
    #59
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    Can someone post pic of their ultra gage please
  20. Mar 28, 2015 at 6:02 PM
    #60
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
