Scan Guage II mounting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeS., Jul 22, 2008.
  1. Jul 22, 2008 at 4:02 AM
    MikeS.
    MikeS. [OP] Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    How did ya'all run the cable for you SG? I'm planning on putting mine on top of the steering column. For right now I've got the cable ran through the little drop down box above the e-brake.
    I'm hoping to see pictures of other options.
  2. May 21, 2013 at 11:50 AM
    CloseYetFar
    CloseYetFar Member
    New Jersey
    2010 TRD Sport SR5
  3. May 22, 2013 at 11:47 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    One piece of Velcro hook tape to top of scan gauge and it fastens to headliner above the mirror.
    Cable tucks in under headliner, then down the a pillar and under dash to the obd port.
    2 screws to remove a-pillar trim. Use a couple tie wraps to secure cable away from airbag.
  4. Nov 20, 2014 at 12:36 PM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    I used double sided tape to get mine seated. I am not happy with the look. Anyone have a cleaner solution. I have a Mirror riser so above rearview is out.
  5. Nov 20, 2014 at 1:00 PM
    Sold My Subaru
    Sold My Subaru 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Doesn't get in the way of anything. You can see most the gauges while driving. Ran the wires through the tray below where it's mounted. Clean. Simple. Cost: $0.00
  6. Nov 20, 2014 at 1:01 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Mine is on top of steering column with a flat bungie. 4 years no problem. All gauge lights visible. Cable down to right of steering wheel and behind dash. Don't like the Velcro/sticky stuff.
  7. Nov 20, 2014 at 1:08 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Frenched into lower din slot under radio.
    Wired behind the dash.
  8. Nov 20, 2014 at 1:58 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    SoCal
    '22 GX460 Coming...'18 T4R ORP W/ KDSS, '13 Taco-Retired, & Spaceball One
    Mine's right next to the rear view. No wires exposed :thumbsup:
