Scangauge 2 Removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 503TRD, Feb 4, 2011.
  1. Feb 4, 2011 at 6:01 PM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Hey so I got a couple quick questions, I just got my ScanGauge 2 last night..so far I'm liking it though I haven't decided where to mount it(thinking on steering wheel/column), anyways was just wondering how to remove the Scangauge plug from the OBDII, do you just pull straight out(or wiggle a little and pull?) until it comes out? I did that the first time but I just wanna make sure how to do it correctly, because I don't want to somehow break anything...or is there a little tab I push in and then pull(kinda like what plugs into the gauge itself). Oh and also, is it fine to keep it plugged in and shut off the truck and get out? Or does it stay on? And last thing, what did you do with all the cord if you mounted it on the steering column?
    Thanks in advance
  2. Feb 5, 2011 at 5:42 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    This is where I mounted mine...
  3. Feb 5, 2011 at 5:42 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I never had a problem just pulling it out. You can check other vehicles for codes and then just push it back in. So pull it out, push it in, pull it out, push it in etc.:rolleyes:
  4. Feb 5, 2011 at 7:08 AM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
    That's what she said...:D
  5. Feb 5, 2011 at 10:56 AM
    george3
    new jersey
    tacoma
    You are correct sir !;)
  6. Feb 5, 2011 at 11:01 AM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Alright cool thanks guys I just wanted to be safe. But for anyone who mounting it on top of the steering column, what did you do with all the extra wire?
  7. Feb 5, 2011 at 11:03 AM
    george3
    new jersey
    tacoma
    I just coil it up with a wire tie behind the dash under the steering wheel.
  8. Feb 5, 2011 at 11:34 AM
    JKD
    JKD Well-Known Member
    I put mine "temporarily" in the little cubby hole to the lower right of the steering column. I coiled the wire behind it to hold the scangauge up so I could see it. Easily visible and stealth from the outside. I liked it enough I bought Velcro and attached it there permanently.
    The only times I've taken it out is when it goes in for dealership service, and I don't remove the wire, I just unplug the scangauge itself and take it with me.
