Scangauge II and 2017 Tacoma trans temp gauge
Discussion in '3rd Gen. Tacomas (2016-2023)' started by awdvkd115, Jun 14, 2017.
  1. Aug 12, 2018 at 6:26 PM
    peavey02
    peavey02 Well-Known Member
    Alex
    NC.
    2017 Tacoma TRD Pro
    RCI rock sliders OVT Tune KO2 265/75/16
    This one?
    Carista OBD2 Bluetooth Adapter for iPhone, iPad & Android https://www.amazon.com/dp/B00YVHGTBM/ref=cm_sw_r_cp_apa_73nCBbATF87DC
  2. Aug 12, 2018 at 6:37 PM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2017 TRD Off Road DCLB
    V-LED low and high beam headlights. OVTuned
    Yes that one! Works great!
    peavey02 likes this.
  3. Aug 12, 2018 at 7:01 PM
    willhahn24
    willhahn24 Well-Known Member
    2016 Tacoma
    Has anyone installed this on a MT?
  4. Aug 12, 2018 at 7:06 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    vicali and jekerskel like this.
  5. Aug 12, 2018 at 7:11 PM
    jekerskel
    Zach
    Bellingham WA
    It would make no difference with the exception that a MT has no temp sensor.
    corgimas likes this.
  6. Aug 12, 2018 at 7:31 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Plus the $15 for the other app, then the $79 for the Toyota doodad.. plus your phone, oh- your going to need a cable for that, oh and a phone holder, and some stem lube..
    Sg price seems high until you start using it. Full support (I’ve asked a ton of questions to linear logic and gotten advice and support every time.) lifetime updates - I ended ‘buying’ a new board for my SG to get the newest version $20 shipped to Canada. Both our rigs have them and they come with to the next ones.
    Nu2taco likes this.
  7. Aug 12, 2018 at 7:49 PM
    mutely
    No need to get defensive, Just pointing it out, as it’s not normal to change monthly fee for these things, so it might catch someone unaware.
    vicali[QUOTED] likes this.
  8. Aug 13, 2018 at 9:19 AM
    willhahn24
    2016 Tacoma
    So if you have a MT you can't monitor the trans temp at all?
    I do a bunch of wheeling in 4 LO and always wonder if I am stressing the trans too much.
  9. Aug 22, 2018 at 4:40 AM
    peavey02
    Alex
    NC.
    2017 Tacoma TRD Pro
    If anyone using the SGII is interested in what gear your truck is in.
    Gear Position (State)
    TXD: 07002238B5
    RXF: C32100000000
    RXD: 2808
    MTH: 000100010000
    Notes: Requires firmware 4.22+
    habaneroTrd likes this.
  10. Sep 22, 2018 at 7:07 PM
    MrBob59
    MrBob59 Member
    2017 Tacoma
    IMG_0216.jpg Just been following this thread after getting a ScanGauge ll for my 2017 Tacoma to get the transmission temperature readings and I truly am not tech savvy but I was able to use info from here and wish to thank all for your tips because so far it looks like I got it set up right.
  11. Sep 22, 2018 at 8:46 PM
    17toyota17
    17toyota17 Well-Known Member
    17 Tacoma SR5 DCSB
    Was it an easy install?
    MrBob59 likes this.
  12. Sep 23, 2018 at 7:43 AM
    MrBob59
    MrBob59 Member
    2017 Tacoma
    Yes it was very easy to install...just plug it in to the OBD connector and route the cable to where you want to mount the gauge using the supplied Velcro. I am only going to use it when I tow my trailer.
  13. Jan 30, 2019 at 3:46 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    MT isn't filled with fluid and isn't getting as hot as an AT. Not necessary.
  14. Jan 30, 2019 at 4:32 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    You sure about that? I don’t think I’ve ever seen a dry gearbox...maybe you mean to say there isn’t coolant, just oil.
  15. Jan 30, 2019 at 5:13 PM
    #35
    specter208
    California
    I meant to say isn't completely filled with fluid like an AT is. The gears are of course splash-lubricated with gear oil.
    burntkat likes this.
  16. Jan 31, 2019 at 9:01 AM
    #36
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I tried this ^^ xgauge but it dosen’t work on my 2018 3.5L automatic.
    What does work for me is this one:
    Current Gear (1-6 only)
    • TXD 0701221AA0
    • RXF C462051A36A0
    • RXD. 3008
    • MTH 000100010000
    • Name CGR
    • Notes 4.42 Required
  17. Jan 31, 2019 at 9:18 AM
    #37
    peavey02
    Alex
    NC.
    2017 Tacoma TRD Pro
    Glad that one works for you. The other code works just fine for my 17. Gears 1-6.
  18. Jan 31, 2019 at 10:00 AM
    #38
    wiljayhi
    Jim
    3G, Tuned
    Toyota must have done something a little different from ‘17 in ‘18.
  19. Jan 31, 2019 at 11:40 AM
    #39
    peavey02
    Alex
    NC.
    2017 Tacoma TRD Pro
    It might have something to do with what version your ECU is.
  20. Jan 31, 2019 at 12:16 PM
    #40
    wiljayhi
    Jim
    3G, Tuned
    Likely that’s correct. The ECU was updated in late Dec. I don’t know what the new calibration ID is but I’m going to find out as doon as my OV Tune kit arrives.
    peavey02[QUOTED] likes this.
