Scangauge II: Transmission Temp
Discussion in 'Technical Chat' started by billyjoe, Mar 22, 2010.
  1. Jul 12, 2010 at 5:19 PM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    I found these on TTROA or was it Toyota Nation posted as being for a Tundra, but might work for a Taco (I have not tried them yet)
    Altitude Gauge (Feet)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: FEEE00016B08
    NAM: Alt
    Air to Fuel Ratio (Lambda)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 006400800000
    NAM: AFL
    Air to Fuel Ratio (True Air to Fuel ratio)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 05BE00800000
    NAM: A/F
    Atmospheric Pressure (PSI)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: 000A00450000
    NAM: PSI
    Anyone know what the speed offset for the stock TRD Sport tires might be?
  2. Oct 5, 2010 at 1:10 PM
    ec8
    ec8 Newby
    Stuart
    I contacted ScanGauge today to check up on the Trans temp reading question to see if they had any new codes worked out. I asked about codes for an '06 Tacoma V6 and '05 4Runner V6 and they replied with:
    " [FONT=&quot]Thank you for your inquiry. Currently, transmission temperature is only available for Ford, GM and some VW vehicles via the X-Gauge feature. The X-Gauge comes standard on the ScanGauge II and allows you to program extra gauges into your unit for your vehicle. Our engineers have found two codes in order for the ScanGauge II to display transmission temperature for Toyota vehicles, however they are very experimental so there is a possiblility that the codes may not work. [/FONT]
    [FONT=&quot] [/FONT]
    [FONT=&quot]TXD: 686AF101B4[/FONT]
    [FONT=&quot]RXF: 044105B4[/FONT]
    [FONT=&quot]RXD: 2010[/FONT]
    [FONT=&quot]MTH: 000703E8FFD8[/FONT]
    [FONT=&quot]NAM: TFT[/FONT]
    [FONT=&quot]or[/FONT]
    [FONT=&quot]TXD: 68 6A F1 01 B4[/FONT][FONT=&quot]
    RXF: 04 41 05 B4 00 00
    RXD: 28 08
    MTH: 00 09 00 05 FF D8
    NAME: ATF[/FONT][FONT=&quot] [/FONT][FONT=&quot][/FONT]
    [FONT=&quot]Please let us know the results of the these codes for your vehicle and if you have any further questions"
    Anyone try these codes and see what they get?
    [/FONT]
  3. Oct 5, 2010 at 5:28 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Sorry, no go on my 2010. I triple checked both entries in my SGII. Neither one shows a value being returned in gauge mode.
    ETA: I googled for a while and found these exact codes listed on tacomaterritory.com, claiming someone on a tundra site got them from the SGII folks. This was in August of 2009. Sorry, again. No go.
  4. Oct 6, 2010 at 4:40 AM
    ec8
    ec8 Newby
    Stuart
    Ok, thanks anyway, guess they aren't looking too hard to add this to their x-gauge abilities. Would have bought one if they worked for this as well.
  5. Oct 6, 2010 at 7:37 AM
    SCFirefighter
    Stephan
    Cary, NC
    I sent a friendly reminder to the folks at SG to see where they were up with their ancient promise to support TFT readings.
  6. Dec 26, 2010 at 9:55 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    if first gens use PWM how come my scangauge says its ISO
  7. Oct 28, 2011 at 12:03 PM
    andrew862
    andrew862 Well-Known Member
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    Downey SST Tonneau, DeeZee Bed Mat, TRD Exhaust, ScangaugeII
    Transmission temperature for 2010+ tacos. Enjoy!
    Transmission Temperature 1 (Degrees F) 2010+
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 (Degrees F) 2010+
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
    It’s theorized that TF1 is the pan temperature, while TF2 is the converter outlet temperature so TF2 will fluctuate much faster than TF1 will.
    DrFunker and Trouble_The_Tacoma like this.
  8. Oct 31, 2011 at 8:41 PM
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    Does anyone have the SG2 codes for MAP sensor? For 2010+ tacoma
  9. Oct 31, 2011 at 8:48 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Sub'd ... want to get a S/G later.
  10. Oct 31, 2011 at 8:48 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    As far as I know, when a car has a MAF, it does not have a MAP. So the tacoma does not have a MAP... so no code for it.
  11. Mar 30, 2014 at 10:15 PM
    lchizz
    lchizz New Member
    Seattle
    05 Taco DC, White 6" fabtech 35" BFG M/T
    6" FabTech suspension lift 17" wheels 35" BFG M/T Leer 100XQ matched canopy
    Hey everyone, I've had a scangauge in all my cars. I just picked up my 05 Taco and wanted to find out if anyone has found a code that works for TFT?
    Thanks!
  12. Apr 7, 2014 at 8:14 PM
    Scamper
    Scamper Active Member
    Soggy NW
    PreRunner in Spruce Mica and Leer canopy
    Post #27 above worked a treat for my 2013 Prerunner.
    Thanks, Andrew
  13. Aug 14, 2014 at 11:41 AM
    Shaggy1911
    Shaggy1911 Member
    Virginia
    14 TRD Sport DCLB
    Post #27 above worked for my 2014 Sport.
    Thanks, Andrew
  14. May 13, 2015 at 5:49 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  15. Nov 21, 2015 at 6:50 PM
    #35
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Does anybody know why my Scanguage pulled my trans temp on my 99 Prerunner but won't pull trans temp on my 99 4wd?
  16. Jul 14, 2016 at 12:22 PM
    #36
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    any update? I want to buy a scan gauge but SG cant confirm that it will work reading trans temps with my 2005 tacoma prerunner with 4.0
    thanks
  17. Jul 16, 2016 at 8:41 AM
    #37
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Works on my 05 Tacoma 4x4 w 4L.
  18. Jul 17, 2016 at 4:48 PM
    #38
    blazze2005
    South Jersey
    yup still wont work on the pre-runner for some reason...Not sure why it only reads it on 4x4's
  19. Jul 21, 2016 at 10:25 AM
    #39
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    For you guys that are able to get transmission temp readings on your Scanguage. Can you check your software version. I currently have 2 guages. One is a 3.15 version and the other is a 3.17 version. Neither will read the transmission temps when in xguage mode. Website says to send unit to them for a $25 update. Want to know what software versions are working for you all. Thanks!
  20. Sep 26, 2016 at 4:48 PM
    #40
    chilioil.514
    chilioil.514 Well-Known Member
    2003 Tacoma TRD Prerunner 4-Door
    Prodigy P2, Alpine 235BT, Hayden Aux Trans Cooler, Scan Gauge II
    The codes for TFT worked on my 2003 Tacoma PreRunner.
