Scangauge II: Transmission Temp
Discussion in 'Technical Chat' started by billyjoe, Mar 22, 2010.
  1. Dec 12, 2016 at 8:47 AM
    #41
    Ksinger4
    Ksinger4 Well-Known Member
    Dayton, OH
    2019 DCSB TRD Off Road
    2012 DCSB TRD Off Road Wrecked :(
    VE7OSR likes this.
  2. May 24, 2017 at 11:45 AM
    #42
    drecendez
    drecendez Member
    Danny
    2008 Prerunner SR5, DBL cab, Long bed, factory tow pkg.
    Hellwig air bags, Prodigy 3 brake controller
    I installed my Scangauge II yesterday in my 08' Prerunner. I mounted it on the steering column, below the speedo. I still need to perform the calibration by filling up my gas tank, but setting up the X Gauge for transmission temp was super easy. I highly recommend it. The codes fro the TFT are on the Scangauge website.
  3. Jun 27, 2017 at 11:53 AM
    #43
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Great find. Thank you, works in my truck (2015 TRD-OR 4x4, towing package).
    That being said, what's the standard operating temperature of the transmission? I know this is relative number due to climate, hills, transmission fluid and mods to truck.
  4. Jun 27, 2017 at 12:54 PM
    #44
    drecendez
    drecendez Member
    Danny
    Typically, on hot days 100 degrees or so it'll run 160-180 degrees around town. Towing 5,000lbs up really steep stuff it got up to 240, but only briefly.
  5. Jun 27, 2017 at 1:04 PM
    #45
    Clearwater Bill
    Billy
    Largo Florida
    tomwil likes this.
  6. Jun 27, 2017 at 1:06 PM
    #46
    Clearwater Bill
    Billy
    Largo Florida
  7. Jul 16, 2017 at 9:20 AM
    #47
    DrFunker
    DrFunker Well-Known Member
    Tried to program my gauge using the codes...no luck. :(
    Any suggestions?
  8. Jul 16, 2017 at 10:14 AM
    #48
    Trouble_The_Tacoma
    Conrad
    Year and 4x4? Also what codes did you try specifically?
  9. Jul 16, 2017 at 10:17 AM
    #49
    DrFunker
    2011 4x4 OR auto
    Tried the 3 trans temp codes and an altitude one (for shits n giggles).
    None have worked.
  10. Jul 17, 2017 at 9:21 AM
    #50
    Trouble_The_Tacoma
    Conrad
    What version software do you have on your scanguage? (how to find out - https://www.scangauge.com/support/upgrade/ )
    I have version 4.13 and used the following codes exactly..
    Transmission Temperature 1 (Degrees F) 2010+
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 (Degrees F) 2010+
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
  11. Jul 17, 2017 at 10:57 AM
    #51
    DrFunker
    Thanks. Will check what version I have.
  12. Jul 17, 2017 at 1:28 PM
    #52
    DrFunker
    Checked. It is version 4.42. o_O
    I am more confused now. It really should be working.
  13. Jul 17, 2017 at 1:47 PM
    #53
    Trouble_The_Tacoma
    Conrad
    Just confirming.. You are trying to code it in the XGUAGE section?
    Also, just learned you can change the color of the display! :bananadance:
    DrFunker[QUOTED] likes this.
  14. Jul 17, 2017 at 1:48 PM
    #54
    DrFunker
    Yes, in the XG area.
    Yeah, I like that color feature. Small thing I know, but they didn't have to do that. It is cool.
  15. Jul 17, 2017 at 1:50 PM
    #55
    Trouble_The_Tacoma
    Conrad
    I'm not super busy at work today so I've been going in and out to my truck to try and help you where I can. I got my ScanGuage2 used off a guy here at Tacoma World and it didn't come with a manual but I'm learning a lot via YouTube haha
  16. Jul 17, 2017 at 1:51 PM
    #56
    DrFunker
    Thanks. :hattip:
  17. Jul 17, 2017 at 1:53 PM
    #57
    DrFunker
    Oh Damn! Your codes are slightly different!! WAHOOo!:woot:
    A lead that looks promising.
    Will try them.
  18. Jul 17, 2017 at 1:55 PM
    #58
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Why are there two transmission temps?
  19. Jul 17, 2017 at 1:55 PM
    #59
    DrFunker
    One is the pan and the other is.....? Not sure. I will find that unless someone knows off the top of their head.
  20. Jul 17, 2017 at 1:56 PM
    #60
    Trouble_The_Tacoma
    Conrad
    From page 2,
    "It’s theorized that TF1 is the pan temperature, while TF2 is the converter outlet temperature so TF2 will fluctuate much faster than TF1 will.":notsure:
    DrFunker and TireFire[QUOTED] like this.
