Scangauge II: Transmission Temp
Discussion in 'Technical Chat' started by billyjoe, Mar 22, 2010.
  1. Apr 5, 2018 at 8:30 PM
    #81
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    3hr drive from The Woodlands to Georgetown about 70degrees outside. Transmission was around 156-60 at speed limit. And then bumped up to 170 when I was pulling 90mph. Engine stays pretty constant around 186-190
    txtaco87[QUOTED] likes this.
  2. Apr 28, 2018 at 7:33 AM
    #82
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  3. Apr 28, 2018 at 10:17 AM
    #83
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
  4. Mar 12, 2019 at 10:30 AM
    #84
    Taco15Bob
    Taco15Bob Member
    Bob
    2015 S5 4 door Prerunner
    None
    I have a 2015 Tacoma Prerunner 4-Door SR5 4.0L V6 Towing Package.
    Post #27's Transmission temperature 1 - TF1 worked.
    Transmission temperature 2 - TF2 did not work.
    I'm happy with a basic transmission pan temp.
    I had a 2012 Tundra 4.7L V8 which had a transmission temp gauge in the dash gauge cluster, I have missed it because I tow a 21 foot travel trailer. Towing the trailer did not much affect the transmission temp with the Tundra, will see what it does with the Tacoma. Tacoma Scanguage II TF1 transmission temp runs between 145 - 150F, will see if it increases with the travel trailer, weighs about 5500lb. I live in Georgia (Athens), only have towed to the south from here, no mountains, Flatlander.
    I found this about transmission temps.
    http://transmissionrepairguy.com/transmission-temperature-gauge/
    "High fluid temperatures are ultimately what kills your transmission; it is estimated that around 90% of all transmission failures are due to excessive heat."
  5. Jun 7, 2019 at 11:26 AM
    #85
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @RUSSELLTACO im not sure if this is the thread that youre looking for
  6. Jun 9, 2019 at 12:11 PM
    #86
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    Using the codes in post # 27, I successfully programmed TF1 and TF2 into my SG II. Piece o' cake!. FWIW, my Scangauge is version 6.2.
    Trouble_The_Tacoma likes this.
  7. Feb 14, 2020 at 5:08 PM
    #87
    OAffinity
    OAffinity Member
    2007 toyota tacoma
    OME lift w/ bilstien shocks ARB front bumper Custom bed rack and roof rack
    Anyone know if these work for manual gearbox's? 2007 base dcsb 6M 4x4
  8. Feb 26, 2020 at 6:08 AM
    #88
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    Can I get transmission temp on my 2002 tacoma 4x4 3.4 v6? Thanks!! I did a search, but I haven't seen a clear answer. Thanks in advanced
  9. Jul 7, 2020 at 6:58 PM
    #89
    acbeer
    acbeer Member
    Iowa
    2007 Double Cab TRD Sport Long Bed
    Could someone post a video of how they setup Torque Pro to get accurate trans temps? I’ve read all the threads I can to try and get it to work. A quick video would be awesome with the PID formula.
    Thanks,
  10. Jul 8, 2020 at 7:00 AM
    #90
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Not sure, as this thread is on the Scangauge.
    You might have to do research in here:
    http://torque-bhp.com/forums/
    Then use this video where the user puts in custom PID for Torque Pro app, as an example for your application.
    https://m.youtube.com/watch?v=7y7ecGAvxX0
    DrFunker likes this.
  11. Jul 26, 2024 at 9:51 AM
    #91
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    I know this thread is extremely old but I’ve been searching everywhere and can’t find an answer.
    Does the 2006 have both pan and torque converter temps? Or is it only able to monitor the pan temp? I’ve tried a few codes for trans temp and have one being read but not sure where it’s reading from.
    Edit: I put in two different trans temp codes and took a drive, they were both different. One would go up when accelerating at first, then cool down, can I assume that one is the torque converter and other is pan?
  12. Jul 27, 2024 at 7:13 AM
    #92
    Trouble_The_Tacoma
    Conrad
    Id bet your assumption is correct. But im not sure if the 06 has it 100%. It took some fiddling and tons of time researching on here to get my TF1 and TF2 to work on my 15.y TF2 is pretty constant once it’s up to speed so I’m guessing that’s a pan reading.
  13. Jul 27, 2024 at 9:10 AM
    #93
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    Hmm okay. Why is it so hard to find codes? The website only lists trans temp codes for 2005-2010s so I have to go on a crazy search for everything else.
    TomTwo likes this.
