ScanGaugeII - 2016 Trans Fluid Temp Codes That WORK!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by damnfingers, Jun 15, 2016.
  1. Jun 30, 2016 at 4:51 PM
    #81
    damnfingers
    damnfingers [OP] Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    What do they charge if you stop by?
  2. Jun 30, 2016 at 6:15 PM
    #82
    KB3
    KB3 Member
    2018 Inferno Tacoma DBLCB OR
    Nothing!
    damnfingers[OP] likes this.
  3. Jun 30, 2016 at 8:39 PM
    #83
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Agreed! Great company to do business with and excellent customer service!
    As I posted previously here. I bought a new ScanGuageII Last week so I could monitor my trans temps but unfortunately these codes didn't work as the new gauge had an older version firmware. I sent an email explaining my issue, which version firmware I had and I attached a copy of my reciept. I received a reply from Cristina @ LinearLogic on Tuesday explaining that I needed v4.22 for these to work and that if i'd reply with my ship to info they will 2day priority mail a new unit to me with the lastest firmware and also include a postage paid return label so that I could send the other back. All on the honor system, no questions asked. I got the tracking info yesterday and it will be here tomorrow.
  4. Jul 1, 2016 at 4:23 AM
    #84
    damnfingers
    Gene
    Mississippi
    If only Toyota customer service was that good!
  5. Jul 1, 2016 at 1:13 PM
    #85
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    Kudos to linear logic,great customer service is not dead ! I bought a new scangauge 2 that must have been on the shelves awhile from advanced auto.
    The gauge had version 4.13 on it and the new tran temp codes would not work.Linear logic sent me a new gauge with version 4.22 on it at no cost very quickly.
    works great reading the tran temp now. Thank you Linear Logic !!!
    Fatback17, cctk2 and damnfingers[OP] like this.
  6. Aug 1, 2016 at 2:24 PM
    #86
    damnfingers
    Gene
    Mississippi
    Sorry I can't answer your question but that was the very reason I got rid of my UltraGuage and bought the ScanGauge. UG has the most useless website and WORST customer service I've ever seen.
    0uTkAsT likes this.
  7. Aug 6, 2016 at 11:54 PM
    #87
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Just to jump on the bandwagon: Linear Logic (ScanGauge) has excellent customer service and are very supportive of enthusiasts (such as figuring out the transmission temperature codes for us, and I've seen them do similar on other forums). That's why I went with the SGII for my Tacoma. Plus, as an embedded systems guy, I have a lot of respect with the interface design. It really is a thing of beauty how intuitive the menu system is considering the complexity and feature set of the system. By comparison, my stupid toaster oven takes 4 button presses to make toast.
    cctk2 likes this.
  8. Aug 7, 2016 at 12:31 AM
    #88
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    As a commercial pilot (airplanes and helicopters) I appreciate tools that assist with both monitoring as well as performance management. The SGII is such a tool.
  9. Aug 23, 2016 at 1:30 PM
    #89
    dinzzy
    dinzzy Member
    Greg
    2016 Tacoma TRD Sport
    Tow Package
    I just got back from Arizona. I was towing my 1670 lb tear drop in 108 degree weather up and down desert mountains on hwy 17. TF1 would run 194-199. The TF2 would stay within 2 degrees of TF1 unless the transmission shifted from 4th down to 3rd. It would jump quickly to 210-220 but would return quickly to within 2 degrees of the TF1 reading. Water temp never went over 201.
  10. Aug 23, 2016 at 1:37 PM
    #90
    damnfingers
    Gene
    Mississippi
    Thanks for that! Really appreciate the feedback!
  11. Aug 23, 2016 at 2:37 PM
    #91
    dinzzy
    dinzzy Member
    Greg
    Tow Package
    To clarify...the TF2 would return to within 2 degrees of the TF1 once the transmission shifted back from 3rd to 4th while in the "S" shift mode. Water temp was mostly in the low 190s and once went to 201 on a steep long grade with the a/c off.
    As long as the transmission stayed in 4th gear the two temps would stay between 194-197.
    Interesting enough being in the middle of a truck convey can be helpful too.
  12. Aug 24, 2016 at 10:51 PM
    #92
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    By far the highest temperature I have seen was 240 on TF2 while using CRAWL Control over a long stretch of sand up a slight hill. It seemed to stabilize slightly lower and then cooled right down once we got moving. Outside air temperature was probably in the mid 50's, but intake air was over 120 degrees due to the high engine load and limited air flow under the hood. If you think about how CC works, the torque converter has to be slipping quite a bit, so this seems like a reasonable outcome.
  13. Aug 24, 2016 at 10:53 PM
    #93
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My 2009 4cyl runs at 195 under light load so that looks normal to me.
  14. Aug 25, 2016 at 1:09 PM
    #94
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    is the tf2 temp the converter temp? ....thats how it was in my fj..i just wanted to verify this for the tacoma
  15. Oct 1, 2016 at 4:40 PM
    #95
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    anyone convert the codes and get em to work with the bluetooth obd2 & torque?
    seems 0701 isn't can or old obd2...hmmm
  16. Dec 1, 2016 at 10:08 PM
    #96
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    Just got my ~17 today (late Nov build). I get nothing (blank) for TF1 and TF2 when using the "codes that work" with my freshly updated SGII (v4.22).
    Any '17 owners get the codes to work?
  17. Dec 1, 2016 at 10:51 PM
    #97
    NorcalAP2
    NorcalAP2 Member
    yes, my 17 works with scangauge 4.22
    vinkon235 likes this.
  18. Dec 1, 2016 at 10:53 PM
    #98
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    It's easy to miss a character. I messed up the first time.
  19. Dec 1, 2016 at 11:15 PM
    #99
    Tharris242
    Houston, TX
    I have checked it like 10 times.
  20. Dec 1, 2016 at 11:27 PM
    #100
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    Bummer. Since it works for NorcalAP2, at least you have hope.
