ScangaugeII fuel fillup adjustment: 11.6%!
Discussion in '4 Cylinder' started by supralight, Oct 12, 2009.
  1. Oct 12, 2009 at 6:57 PM
    supralight
    supralight [OP] Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    For those who got ScangaugeII, I've got a concern about the adjustment I've got to do with my fist fillups. To get the correct amount of fuel burned (when at fillup station you compare the ammount pump gave vs amount Scangauge recorded) I have to correct the value by an enormous +11.6%. I have already corrected the speed on my Scangauge with my GPS. I wonder if that means is my truck is running too rich or something.
    How much % have you guys had to correct at fillups to get the correct value?
    For those who wonder what I'm talking about, go read the manual.
  2. Oct 12, 2009 at 7:11 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Very little, The pump may read 16.3 and the scangauge may read 16.6 or 15.9, something like that. I have had a couple where I don't change it at all. It helps if you are very consistent with your driving.
  3. Oct 12, 2009 at 7:28 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    too bad i cant afford a full tank sometimes so i gave up with that crap.. it kinda takes too long to adjust the gallons and percentage when its saying i just had a 4 gallon fill up
  4. Oct 12, 2009 at 7:36 PM
    fletch aka
    Gary
    Left Coast
    I went through the same thing at your age and gas was .65 to .70 per gallon and my gas tank at the time was 10 gallon's.
  5. Oct 12, 2009 at 7:37 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    During the first few tanks you have to change it quite a bit. Once you hit about your third tank you should be good to go mine is normally about +or- .2 gallons on. which probably just has to do with the pump you are at.
  6. Oct 12, 2009 at 7:50 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  7. Oct 12, 2009 at 7:50 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I think mine is set to be adjusted about 9% so i wouldnt be too alarmed by 11%
  8. Oct 13, 2009 at 3:06 AM
    supralight
    Dan
    Earth
    Well I guess it might be normal then. At this setting Scangauge reads within .1-.2 liters from the pump.
  9. Oct 13, 2009 at 5:35 AM
    911-3.2 Well-Known Member
    CT
    Sold - 2010 Access Cab 4x4 I4 SR5
    Curt Receiver Hitch, Access Literider Tonneau
    I also have to adjust mine to around the same amount. To get it dialed in make sure you fill up at the same pump at least twice and then you can pretty much leave it alone. I have found if you keep adjusting it when going to different pumps you will always be chasing the correct setting.
  10. Oct 13, 2009 at 6:50 PM
    supralight
    Dan
    Earth
    I fillup at same gas station/same pump everytime! And off-topic a but, now that the weather is colder here, near freezing, I get lower mpg figures that's for sure. About 1-2 mpg less than when it was 15 celcius (about 60 F i guess).
  11. Oct 13, 2009 at 10:17 PM
    Janster
    Jandy
    Lancaster, PA
    During summer, I've been getting 18-20mpg. In the winter, I've seen 15-17mpg. Same driving style, no 'warmup' time, etc.
    Winter here where I live is probably mostly in 20's-40's F. In January, you might see 0-20's F.
  12. Oct 14, 2009 at 1:16 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    It takes a couple fill-ups for the SG to be precise with its numbers. Try to use the same pump every time you fill-up. My gauge is .1-.2 gallons off at times.
  13. Oct 19, 2009 at 3:12 AM
    supralight
    Dan
    Earth
    small update: my adjustement is now 14.X%! always filling at same pump. I hope it stop getting higher... maybe colder weather getting here affects the %?
  14. Aug 31, 2011 at 11:52 AM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Use Amsoil 0w-30. It will improve cold weather fuel economy by 6%. Start the engine and drive at -20, and it will rum smooth as silk.
