Scanguage HP readout?
Discussion in '4 Cylinder' started by dually, Aug 19, 2008.
  1. Aug 19, 2008 at 6:26 AM
    dually
    dually [OP] Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    What HP does your scanguage say your tacoma is putting out? With my 2.4L, the scanguage says about 25-45 with normal driving, then about 80-100 when WOT. This cant be accurate, can it?
  2. Aug 19, 2008 at 7:01 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I think it's an estimate of the percentage of the available power being used rather than a horsepower number.
  3. Aug 19, 2008 at 8:10 AM
    dually
    Really? Then the info on the scanguage website is incorrect. They claim it is "actual" HP
  4. Aug 19, 2008 at 4:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW the 2.4 dynos I have seen are putting 99 to 100 h.p. to the tires. :)
  5. Aug 19, 2008 at 7:44 PM
    dually
    ahh alright, thanks!
  6. Sep 18, 2008 at 12:11 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Wow also most 42 HP lost in drive train on these cars?
    That is allot for 142HP rates truck...
  7. Sep 18, 2008 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For a 1998 truck, its about normal. My 2000 2.7, dynoed when stock at about 106, and it was rated at 150. All 2.4's and 2.7's I have seen ynoed are right in that neighborhood. :)
  8. Dec 22, 2012 at 9:35 AM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    Consider also, the HP rating is for a factory fresh engine, likely rated at sea level. Now factor in some loss of compression with age, air filters somewhat blocked, and, if you are higher than sea level, there is simply less air up there the higher you go. Humidity also robs engines of power. Wear and tear on spark plugs and less than perfect injectors also come into play.
